Will the Fox F29 G2 Geometry Fork work with my Fantom Pro 29er- Mtbr.com
Results 1 to 2 of 2
    I'm looking at getting a fox f29 fork. I found one with a fisher g2 geometry. Will that specific model work with my fantom pro 29er? Thanks.
    Yes it should work as your frame geometry is nearly identical to the Fisher's that use the G2 offset fork. You can also run a standard offset fork without issue.
