wide tires
Printable View
  • 11-16-2012
    coot271
    wide tires
    OK, anybody running 2.3 tires on your Outcast 29ers?? If you are, what brand and what kind of wheels? Thanks:D
  • 11-17-2012
    webb-o
    running 2.25s, but am looking to go 2.4s
    I am running 2.25s on mine now, but will try out 2.4s Ardents when I replace them soon. According to BikesDirect, the Outcast can fit most 2.35s. The measurements I took indicate that they can probably fit 2.4s, even on a wider rim, but rear clearance for mud shedding will be tight. I will update the thread once I get the 2.4s.
    Will be mounting the Ardents on Velocity Blunts.
  • 03-09-2013
    webb-o
    I am now running Vee Rubber Mission 2.4-inch wide tires on the Outcast. They measure at 2.4 exactly on the side knobs, and a tiny bit under 2.4 wide at the casing. They fit fine with the sliders in any position. I am running them on Stans Arch EX rims, which are about 24.5 mm wide. No clearance issues, and there is still slightly under 1/5-inch clearance between the tire and chainstay for mud on either side. It looks like it might actually fit 2.5's.
  • 03-25-2013
    coot271
    Thanks webb-o.
