Why no FLYS?- Mtbr.com
Results 1 to 9 of 9
Thread: Why no FLYS?
    Why no FLYS?
    I will be purchasing a Moto HT within a month. After reading many (too many, losing sleep) posts, I've noticed that the majority of you own Fantoms vs. FLYS. I really like the FLY PRO HT. It's lightweight, great comps/specs, and nearly identical geo as compared to the fantom elite, and it looks f'n awesome. There isn't a big difference in price (FLY team and FANTOM team are identically priced, for example), so why aren't more people buying FLYS? Is the Fantom a better bike?
    Missouri sucks...
    The FLY is a more race oriented geometry versus the FANTOM is more of a trailbike. Don't know if most owners even know that, just pointing it out...
    Quote Originally Posted by DFYFZX
    Correct, but not all of them. The Fly Team Ti and The Fantom Pro Ti uses the same frame.
    DynoDon
    Reputation: manabiker's Avatar
    I bought the Fantom Team because its Full Suspension, and it flies too..our trails get alot of use near Detroit and Ann Arbor, Michigan so the trails are rough and the FS treats my ol' body better. I also have a Fantom Comp, that don't get much use since I've gotten the Team, but it's a great loaner/backup bike.
    S*it Happens!
    Reputation: Moto Rider's Avatar
    Part of the problem is that a lot of FLY HT owner don't post much...I guess their too busy racing. The Fantom guy's have come out of the closest and made some post...
    Here is a photo.
    -_0
    _ `\<,_
    Like life…the trail is unpredictable...
    Nov 2008
    I own a 9357 FLY and I had it for about 3 years now. I bought it used for dirt cheap and still ride it up until 3 weeks ago. The frame and the components have taken a beating from me...all 240lbs of me, but the bike keeps going.
    The crank arm walked off the bottom bracket screw and stripped it so I have to fix it. Other then that the bike is solid. The guy I purchased it from actually used to xc race it.
    Regarding the FLY 9367, how much abuse can/would it take? I am interested in buying one but a bit two sided over weather it will take abuse along with the SIDS and XTR, would it be wiser to get a more durable fork like a Reba and exchange XTR for XT, get a stronger less race orientated wheel-set and maybe a XT crank set?
    So what do you use your Fly 9357 for?
    Cheers!
    Reputation: Broccoli's Avatar
    Quote Originally Posted by ScottAspect10
    If abuse is a concern, get the titanium frame. It will last. Better save on components.
    Lightweight aluminum does have a more limited lifespan.
    I did end up going with the Fly Pro. Great decision. I had to make some adjustments to the cockpit (got rid of the straight bars for risers, needed high rise stem) in order compensate for my 36 inch inseam (seat on 22 in frame is nearly maxed). Bike has held up to some serious abuse in 4 months. My body, on the other hand, isn't as resilient. Ride hard in the fall, heal over the winter, hit it hard in the spring...
