updating an older Motobecane hardtail- Mtbr.com
Results 1 to 6 of 6
    Have been thinking about updating my Motobecane hardtail - a 2000 model HT400. The frame is solid, comfortable and fits me well (a little better than my full-suspension XC race bike). So, I have some questions for someone who has updated an older model. The frame is not the same as the ones used now for the HT 300 - HT 700 series.
    - will the frame accept a 9-gear cassette? It currently has a 7-gear, although it looks like there is some kind of spacer.
    - is the frame wide enough to accept wheel hubs used now?
    - how do I know what length of steerer tube for the new fork? I don't think the original will guide me, because it is a discontinued RST fork with a quill and a threaded headset.
    - anyone know the frame weight?
    - how about the frame dimensions, especially the fork and seat-tube angles?
    Thanks in advance.
    A frame from 2000 probably has a 135mm rear dropout spacing which is what present day frames use and will work with a 9 speed drive train, you will have to upgrade your chain, your crank, your derailleurs, and your shifters. If the wheels use a free-wheel and not a cassette you will need new wheels for a 9 speed cassette. I know some 7 speed bikes (trek 820) still use freewheels. Since you have a quill stem it is most likely a 1 inch headset, which was more commonly used with quill stems, the modern standard is 1 1/8 inches. However, a lot of bikes had switched to 1 1/8 headtubes and threadless headsets by then, so I can't give you a complete answer without measuring the frame.
    If you are willing to part with the bike, consider that it might just be cheaper to buy a new bike with the components you want and sell the old one. Here's the cheapest 27 speed motobecane hardtail on bikesdirect website:
    http://www.bikesdirect.com/products/...om_trail08.htm
    Here's one for the same price if you want to try a 29'er
    http://www.bikesdirect.com/products/...antom29_08.htm
    Finally, another 29'er 27 speed for under $500 (this bike is a steal at this price):
    http://www.bikesdirect.com/products/...liff29comp.htm
    Oct 2007
    With the low price of Motobecanes, it seems to make much more sense to just buy a new bike. You can upgrade what you have, but you will probably spend as much as you would buying a new bike.
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    No-Brakes Cougar
    Reputation: Gary the No-Trash Cougar's Avatar
    Have you consider adapting it to a commuter?
    R.I.P. Ronnie James Dio ~ July 10, 1942 May 16, 2010
    Well, I did the math on buying the parts I'd need (or want) and you guys seem to be right. It looks cheaper to buy a new bike, even though upgrading parts SHOULD be a more logical way to go.
    Thanks for your input, guys.
    Oct 2007
    Quote Originally Posted by brass
    You have to realize that components are so marked up that it is very expensive to upgrade a bike. If you are patient and shop around there are some good deals to be had, but it is a lot of effort. Bike manufacturers buy in such a large quantity from the component makers that they get a HUGE discount over what you pay. So a bike manufacturer is charging you mostly for the frame, and throwing in the components at a very low cost. When you factor in a direct seller like bikesdirect, it is hard to upgrade for cheaper than the cost of a new bike. Some people buy Motobecanes just to use as build kits and then they sell the frame.
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
