Ti 29er seat post ????- Mtbr.com
Results 1 to 8 of 8
    I can't seem to be able to get my seatpost to stay put. The stock clamp bottoms out and doesn't hold it tight. I tried a different clamp and it still moves. With the clamp off and the seatpost just stuck in there is noticable play between the post and the tube, is this normal?
    Anyone have this problem or render a sollution?
    Thanks, Mike
    Mike
    Same problem with a Thompson clamp..wouldn't stay put at their 25 in/lb torque spec which is pretty low...had to put a few drops of red lock tight and torqued it down to 35-40 and hasn't moved..!
    Dec 2005
    I'm not a big fan of that RicheyPro seatpost. Even the damn graphic wore off on one side in like a month. But it's creaky and doesn't stay put. I tightened the hell out of it though and now at least doesn't slide down anymore.
    Reputation: oldassracer's Avatar
    It is possible for rice to absorb other odors in storage. Or could be the quality of water in it was prepared. Mahatma Rice
    I tried a Thompson post, same problem, so I ruled out the Ritchy post as the problem. I took the clamp off my wife's Rush and that seems to be holding. 4 clamps later and we may be good???
    Mike
    Mike
    Pretty common on many bikes. I have a Hope clamp and Thomson post and my Ti 29er Fly slipped for a while. A little 600# grit sandpaper on the post at the seat clamp collar and some hairspray on the post and no more slip or creeking. Generally there is a break in period...need to slightly abraid surfaces to stop slippage. FSA makes carbon paste that works pretty well but I find hairspray generally works better. Do a search for seat slip solutions.
    Grease
    Quote Originally Posted by dirtrider7
    Are'nt the posts supposed to be greased?
    sim it
    I had the same problem w/ different seatpost and different clamp.
    Solution? I sim it w/ a small 1x1 in of aluminum coke can and works perfect.
