Stuck pivot bolt fantom ds- Mtbr.com
Results 1 to 5 of 5
    Reputation: thunder's Avatar
    Anyone know what direction the suspenion pivot bolt turns on these things? Not where the shock mounts but where the actual pivot is. It takes a big allen key on both sides of that thing and it does spin but seems to tighten in both directions. I'm tracing down a pretty bad creaking my bike has developed.
    2016 Moto Fantom
    Quote Originally Posted by thunder View Post
    Nobodyd taken one out?
    Sent from my SM-G930V using Tapatalk
    2016 Moto Fantom
    My little friends
    Reputation: EABiker's Avatar
    I don't recall anything unusual about that bolt when I removed it: standard counterclockwise to loosen. The creak on mine ended up being the derailleur hanger of all things. Remove and grease it and see if your creak goes away.
    Thanks EAbiker.
    2016 Moto Fantom
    Reputation: Tunesoul's Avatar
    Sep 2015
    I had a pretty bad creak and I traced it down to the rear triangle pivot. The bolt unscrews counter clockwise like most bolts. It is rather tight, but it will come lose. Once I got it apart I noticed that one of the bearings had very little grease in it and the other one had no grease at all. Yikes! I repacked each bearing with plenty of high quality grease, reassembled the rear pivot (don't forget to put some loctite on the treads of the pivot bolts,) and the annoying creak was long gone! Hope you got your problem all worked out as well my friend! ~OCD Mountain Biking
    I have a channel that has a lot of info on the Motobecane Fantom DS Comp 29er if you'd like to check it out! Kirk
    https://www.youtube.com/c/ocdmountainbiking
  1. Stuck Pivot Bolt on my Tallboy LTc
    By ktothetothe in forum Santa Cruz
    Last Post: 04-02-2015, 05:25 PM
  2. Stuck pivot bolt - clockwise or counterclockwise ?
    By Froberg in forum Bike and Frame discussion
    Last Post: 08-23-2012, 12:32 PM
  3. Intense M1 Main Pivot Bolt Stuck ?
    By heavyp in forum Intense
    Last Post: 05-28-2012, 02:29 PM
  4. HELP!! Stuck suspension pivot bolt -- Loctite
    By checkpoint22 in forum General Discussion
    Last Post: 12-14-2011, 08:27 AM
  5. Rear Derailleur Pivot Bolt Stuck
    By jtmartino in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-18-2011, 05:16 PM
