Strange derailer malfunction yesterday.- Mtbr.com
Results 1 to 6 of 6
    Oct 2010
    So I just got my Elite last week and have ridden about 5 times so far. yesterday i was going on flat road and went to move the front derailer up on and the chain wrapped all the way around the front gear and pulled the rear derailer arm up. i was scared that something had broke. what would cause this?
    Reputation: TwoHeadsBrewing's Avatar
    Sounds like chain suck. It's happened to me before, but only when I had smashed the teeth on my small chain ring somehow. The teeth grabbed the chain and pulled the derailer cage forward. Check the teeth and see if any are bent or rough. If they are bend them back and then file smooth with a metal file.
    "Got everything you need?"
    Total Goober
    Did you clean the packing grease off the chain when you built the bike up? They come with veeerrry thick/sticky grease on them, and will collect gunk quickly.
    Quote Originally Posted by Fuglio View Post
    You guys suck im all bummed now
    Oct 2010
    i did not clean the chain. I will try that tomorrow
    Total Goober
    FYI, I used a Park chain cleaner w/citrus degreaser/cleaner. Good luck.
    Aug 2010
    Quote Originally Posted by BigSteve in CO
    IMO, those things don't do a good job. It's better to get a removable link (like SRAM's powerlink or KMC quick link) and take off the chain completely to dunk in a bottle full of degreaser and shake it up to get everything. Beforehand, I'd recommend wiping the chain down first, then dunking it in the degreaser. You don't get all the nooks and crannies with those chain cleaner tools.
