shock pressure on elite- Mtbr.com
Results 1 to 7 of 7
    Oct 2010
    I have been searching but can not find what the pressure should be on the tora tk for a 200 # rider. where would 1 find that info?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Start at 20 % sag .
    Oct 2010
    is there a place that tells you how to set it up? i am a newbie.
    DynoDon
    Reputation: manabiker's Avatar
    Youtube is a good place, sag is a starting point, good luck!!
    http://www.youtube.com/results?searc...tain+bike&aq=2
    Feb 2010
    Quote Originally Posted by ramjam
    tora tk is coil only, so you'll be setting preload, not pressure. Not a big deal, at 200# you should be within the range of the stock spring.
    Oct 2010
    is it set the same way about 2" of sag?
    Feb 2010
    yes, you still look at sag, but 2" is too much. rule of thumb is 20-33%. tora tk is 100mm fork (roughly 4"), so you should start at an inch or so. it will probably be quite close to the proper setting from the factory, since the biggest factor is spring choice, and most riders are going to be in the 180-200lb range.
