Review of Motobecane FantomDS Sport- Mtbr.com
Results 1 to 126 of 126
    Reputation: Forbin's Avatar
    Jun 2018
    This is going to be a long write-up because I'd like to give an in-depth overview of the bike. I was unable to Google any relevant info or reviews on this model, so I hope this will be helpful to others. It should be noted that the FantomDS Sport has the exact same frame as other (more expensive and better spec'd) Motobecanes...and this is why I ultimately chose to buy it over all other entry level bikes on the market.
    I received a Motobecane FantomDS Sport from Bike Island. I picked up a Dark Silver 16.5" (27.5" wheels) from them for $449 ($150 less than Bikes Direct). The listing stated the bike was new, but with scratches on the downtube. I ordered it on Tuesday night and it arrived in TN (from TX) on Friday via FEDex. I purchased this bike for my girlfriend. My current ride is a Diamondback Catch 2, so I'll use that as a point of comparison.
    Despite the description, the bike has no cosmetic blemishes at all. It arrived in a plain brown shipping container with no branding info and no "fragile" type markings. The box was undamaged. Internal packaging was sufficient, but very sloppy. The bike had sufficient foam and bubble wrap to proect it, but it sure wasn't packaged professionally (more on that in a bit). The rotors were in zip lock bags. The rear derailleur was unmounted and (well) wrapped in a gauze-like cloth.
    The unmounted rear derailleur was a nightmare. I'm a decent bike mechanic and the chain was just all twisted around and loose off the chainrings. It literally took about 45 minutes to just get the chain and derailleur untangled and mounted. Yes, it would have been faster if I had broken the chain, but I didn't have that tool handy. My buddies who were helping me joked it was like trying to do a Rubick's Cube. I'm hammering this home because this would be a show stopper for anyone unaccustomed or intimidated by messing with this stuff.
    The remainder of the bike assembly was straight forward. Just attach the handlebars and mount the rotors. The rotor screws, however, were non-standard and used a star-bit. Surprisingly, after getting the derailleur mounted (and the cable properly seated), the bike shifted flawlessly without any adjustment.
    The frame itself looks awesome. The welds are extremely high-quality--in fact, one of my mechanic buddies who was assisting is a welder, and that's the first thing he commented on. The wheels are WTB i25s (good) but the hubs are unbranded. The specs say that the hub can only accomodate an 8/9 speed cassette. I removed the cassette (to pull the dork disk) and it was way under-torqued and removed with hardly any force. This could be a safety issue, and not one that most people would catch. I took a photo of the hub without the cassette:
    The handlebars are okay, but the stem seems undersized with a noticable gap between the brackets. The WTB grips are cheap and short. I was shocked that the seat post didn't come with a quick release--I should have noted that in the specs, but it is a chintzy way to cut a few cents. The cabling is questionable at best. The cable retaining clips are pure garbage--2 of them have already just popped off on their own. I'll probably just remove them all and use zip ties.
    I didn't expect much from the 3x8 drivetrain, but it was actually okay. After assembling the bike I took it out in the mountains for a quick 4 mile ride up and back down. I mostly stayed in the middle chainring and had no issues.
    The biggest surprise was with the suspension. This model comes with a (coil) Suntour XCM with lockout up front, and an EXA Form 388L coil for the rear suspension. My Catch 2 has a RockShox Pike fork and a Monarch Debonair in the rear so I'm fairly spoiled. I really thought the FantomDS Sport's suspension would be a nightmare--it was not. It actually rode perfectly fine--both up and down the mountain. Granted, I didn't do any jumps, but for XC riding, it was good. The fork's lockout feature was critical. The rear coil shock is still a mystery. The lockout feature sort of works, but you have to flip it to open for it to actually lock out. This shock has settings options, but it's pretty much a mystery how to dial it in. Regardless, it provided a surprisingly smooth ride over roots and rocks, with minimal pedal bob when hammering uphill. The rear shock had been at the top of my list to upgrade but that leads me to the weakest part of this bike....
    The brakes are garbage. Granted, I'm used to having hydraulic LevelT's on my own bike, but I also own a Windsor Cliff with mechanical Tektro brakes--the ones on the FantomDS Sport barely stop the bike. This is unacceptable and really limit what you can do. I literally ran off the trail a couple of times because I couldn't slow the bike down before going into a corner. Even with the 3x8 drivetrain and budget suspension, this bike handles great--but without decent brakes, you're really limited to how and where you can safely ride. Brakes are going to be my #1 priority to upgrade.
    Overall thoughts: The packaging was sub-par. Compared to the way Diamondback ships their bikes "Ready to Ride," the rear derailleur fiasco would force an inexperienced person to pay for bike assembly. The fact that the cassette wasn't torqued on properly is also worrying. The bike itself is great. It handled very well even though it has a number of entry-level components. Of course the best thing about this bike (other than the price) is that it has a tapered headtube, a proven frame design, and will be easily upgradeable over time. I shopped for other entry level bikes, and forget it--nothing comes close. All of them come with the same fork (although not all have the lockout feature). None of them are dual suspension--and this is a humongous deal since you can easily throw an inexpensive air shock on and get a much plusher ride. Also, few entry level bikes come with tubeless compatible wheels, and I couldn't find any that have a tapered head tube. The brakes are the only component that infuriate me.
    Finally, here is a photo of the bike. Ignore the Motobecane box in the back--I ordered a set of 29" wheels for my Catch 2 and they're from the Motobecane Fantom Boost Eagle.
    Jun 2018
    I'm going to update this thread for a while in the event anyone stumbles across it in the future attempting to find information about this bike.
    I decided to begin to upgrade the bike. Although I had reviewed the specs prior to ordering it, I'll be honest, I wasn't as detail oriented as I should have been. Much of what I'll note might be obvious to someone who reads the specs for this bike with a close eye.
    One of the things I decided to do was to change this bike to a 1x setup. When looking over my options, I discovered some limitations based on the stock components. Of course, if money is no option, there's no limit to what you can do--but I'm on a budget.
    First, the rear hubs are going to limit you. They'll onlyaccomodate up to a 9 speed cassette (it comes stock with an 8 speed drivetrain). You won't be able to go to a 1x10 or 1x11 without switching the hubs.
    Edit: I was wrong--the rear hubs will accomodate an 11 speed cassette. See Update 8 below.
    The best option that I found was to swap the cassette for either a ZTTO (cheap) or Sunrace (not as cheap) wide-range cassette. You'd have the option of getting either an 8 or 9 speed cassette, but if you opt for the 9 speed, you'll need to swap out the rear derailleur and shifter as well. I opted for the Sunrace 11-40t 8 speed cassette (~$35) on Amazon. Note: if you go this way, you'll need to order the wide-range cassette with a derailleur extender. There are vendors on Amazon (and Ebay) who offer these packages. I've actually owned a Sunrace cassette previously, and they're well made--I can't speak for the ZTTO ones (which are priced $15-$25 less). The Sunrace line are extremely highly rated on Amazon as well, and are a favorite of people switching to a 1x.
    Going to 1x necessitates switching out the cranks as well. And the reason you'll have to change them is buried in the bike's specs--it ships with a square taper bottom bracket--and you can't run a 1x crank like this. You'll need a new 1x chain ring as well. I'm doing this project right now, and tonight I discovered that my Park Tool C44 crank arm puller is incompatible with a square-taper. I'll be hauling this bike into the shop because, quite frankly, I don't want to buy more specialty tools for a square taper BB just to pull outdated parts that aren't on my other bikes.
    I've ordered a used Fox Float rear shock and a new KS-eTen dropper post. I found the shock on Ebay so hopefully it both fits and works. The dropper post I got for half-off on Amazon ($50). I'll provide updates on both those upgrades once I get them on the bike. Note: the seat post is 27.2mm which is an older spec, so you'll be a bit limited on which dropper posts you can use.
    Looking at upgrading the fork got me the most frustrated. This is a pretty big bummer IMHO, and one I could have easily spotted in the specs had I paid more attention. The bike does have a tapered headset but it's using a straight tubed Suntour XCM fork with stanchions for a 9mm skewer. I haven't pulled it apart yet, but it's clear that they've used some type of adapter to fit the straight tube into the taper. There's nothing inherently bad about that assuming you could stick another 1 1/8 straight tubed fork in there--but since you've got a modern tapered head tube, it would be nice to just get a modern fork. Of course you can do that--but if you do it, you'll also have to rebuild or replace the front wheel since your hubs are set up for quick release 9mm skewers and not a modern axle. If you're new to upgrading--just go look at what air forks are out there--you'll see the vast majority of forks with a tapered heaset are made for thru-axles, and not the antiquated 9mm skewers. So again, the bike has upgrade potential, but when you get into the details, your upgrade path isn't quite as simple (or inexpensive) as you might hope. Now all that said, you can find some decent air forks with a straight tube and QR (like the Manitou Markhor) <$300. But if you're shopping for used parts, you're likely to be limited in what you'll find since most modern, higher spec'd bikes will be imcompatible.
    Other general observations after owning the bike for a few days--I still like the bike quite a bit, but even though I paid $150 less than what this model goes for on Bikes Direct, I don't think it was an awesome deal at $450. $450 seems a fair price for the bike--at $600, I'd recommend to look for used bikes, or to just save and buy a bike that is spec'd with a 1x11, a decent air fork & rear shock, and one that uses thru-axles (if not boost spacing) on the wheels. As it stands, I'm pulling off 3/4 of the drivetrain and replacing it to just achieve a rudimentary 1x8 setup. I bought this bike because I felt it had great upgrade potential--and it sort of does. But the problem is that they skimped so hard on some of the critical stock parts, that you're not really left with an easy, inexpensive path to upgrade. If you want to move to a modern 1x11, you'll need to replace the rear hub + rebuild the wheel or buy a new wheel with a hub that will support an 11x cassette. You'll need to not only replace the crank arms and chain ring, but also swap out the bottom bracket. You'll need to buy/install a new derailleur as well as a shifter because the 8 speed won't work (obviously) on a 1x11 setup. If you want to swap out that heavy coil-spring front fork you can do it, but you won't be able to get a modern fork with a tapered headtube (most likely) because 90% of those only support through-axles. So again, you'll need to rebuild that front wheel with a new hub or buy a new wheelset in addition to the fork.
    What you're left with is a nice frame as a platform but components that complicate your upgrade path fairly significantly.
    One last thought--the FantomDS Sport shares a number of components/compromises with other entry level bikes--but the full suspension sort of sets it apart. The closest other entry-level bike I can think of is the Diamondback Atroz 1, which is priced at $595 direct from DB (corporate pricing) and is also full-suspension. You can often find it cheaper on ExpertVoice. It has the same type of limitations the FantomDS Sport does (8x3, mechanical brakes, old-style BB, etc.). Although the DB has a straight head set, I'd recommend people seriously weigh it against the FantomDS Sport at $600 from Bikes Direct. I've purchased from DB before, and their stuff really does come "ready to ride." Assembly from DB is nearly idiot proof and their support is (in my experience) top notch. I didn't pay $600 for my Motobecane though--but if you are at that price range, I'd absolutely consider the Atroz 1--especially if you're intimidated by assembling the bike. There are exponentially more people who own the Atroz and have guides for upgrading wheras there are literally fewer than 5 people (myself included) on the web & YouTube who can tell you about the FantomDS Sport.
    Jun 2018
    Part III of my Motobecane FantonDS Sport journey. I've begun my upgrades and will share for anyone interested. So far, I've changed out the rear shock, as well as the cassette, bottom bracket & cranks moving to a 1x8 setup.
    The bike comes stock with an EXA 388L coil shock that weighed in at 671g. I swapped it out with a used Fox Float R air shock that I picked up on Ebay for $25 shipped. I ended up re-using the upper bushings from the EXA shock. The Fox actually came with an assortment of bushings--I was able to use one of those for the lower bushings. The Fox weighs in at only 232g. It's a basic air shock, but seems to be ok. If & when I have issues with the seals, I'll probably just swap it out for an inexpensive DNM shock.
    Next up is the cassette. I thought long and hard about whether to use the existing derailleur & shifter or swap them out for a 9 speed I have on another bike. I decided to just stick with the stock 8 speed because I really didn't want to get into canibalizing my other bike. I ended up ordering a Sunrace 11-40t widerange cassette from Amazon for $33.97. To get this to work, you'll probably need a derailleur extender, which the one I ordered actually comes with. I've had positive experiences with Sunrace cassettes previously and recommend them. When you switch to these wider range cassettes, you'll almost always need a derailleur extender--so my advice is to get one. I forgot to weigh the stock and replacement cassette.
    Next up are the cranks, bottom bracket, and chainring. I decided to order an inexpensive Shimano clone from Ebay. The entire set of parts ran me $62.28. The cranks are branded IXF, the bottom bracket is branded Jiantun. I also got a 32t oval chainring with this set--it is branded Deckas. FWIW, these components have (overall) great ratings on Amazon. They seem well made. The original cranks & chainrings that I removed weighed 881g. The new ones weighed 706g. The stock bottom bracket weighed 341g whereas the new external bearing BB weighs only 105g. Also, I removed the front derailleur, cable, and shifter--these weighed a total of 341g.
    If I've transcribed my weights correctly, my total weight savings is 1,191g (or 2lbs, 10oz).
    I also purchased a KS eTen R dropper post (27.2) but it doesn't work--I believe it needs a new air cartridge. I picked it up off Amazon as an open-box item (missing the remote & cable) for $39.95. I had a spare remote, and I ordered a replacement cable for $8. The vendor who sent me the broken dropper decided to just refund me and let me keep it (which was an overly generous gesture). I will eventually be getting around to working on this--but the drive-train issues were more pressing. I haven't weighed the dropper (yet), but I strongly suspect it's heavier than the stock post.
    I haven't converted the bike to tubeless and am on the fence about doing so. I run tubeless on my Diamondback Catch 2 27.5+ tires, but don't know if I want to burden my girlfriend with having to refresh wheels with sealant every month or two. I know there is more weight savings to be had so I'll decide in a month or so after I take a breather from these other upgrades. I've got a spare set of tubeless stems that I can use so other than buying some Gorilla Tape it won't cost me anything.
    I'll continue to update this thread as a resource on this particular bike. My feelings have changed a bit from my more critical 2nd post but I want to re-evaluate things a bit more before I correct some of my negative observations.
    Reputation: ilanoray's Avatar
    Apr 2019
    Fantom DS Sport
    FWIW, I was looking for this frame to build my MTB from scratch. Bike Island had it for $550.00. Then I found the entire bike for $450.00. It was a no brainer at that point lol! The first thing I did was remove the WTB Nano 2.1. I installed Conti X-King 2.3 up front and 2.2 round back. I'm in FL so these tires work very well. I'm running the tubes that came with the bike. I'm running 25psi in the front and 29psi in the rear. So far they are holding up well. I was going to go tubeless but the extra expense, the sealant mess, and having to break down, clean, and reseal them periodically was a turnoff. Next, I installed a Brand X externally routed dropper post. I wanted to convert to a 1x system so I found an Alivio crankset on eBay for $30.00. I then purchased a Race Face 32T Narrow Wide chainring, 104BCD, and bolted it on. I also swapped out the stock pedals for some spiked flats. I opted to keep the square tapered BB until it craps out. Then I'll upgrade to Holowtech II and Deore cranks. I was running the stock rear cassette and derailer (8spd) for about a week when I decided I needed a wider range cassette for some of the climbs. I know, when people think of FL they think flat. Our MTB trails here are built down in old borrow pits from the phosphate mining operations. So we have some impressive downhill, albeit short, and climbs. Also lots of manmade features. So, I purchased a Deore 11-42T 10spd cassette, Deore shadow plus derailer medium cage, and Deore 10spd shifter. I made certain to get the matching derailer so I wouldn't have to mess with a Goatlink or longer B screw. It just works out of the box. The stock 8spd hub will accept up to a 10spd cassette. Since mine was a Hyperglide C, I used the original cassette lockring. Now this bike shifts like a dream and I've got plenty enough climbing gears. Since I'm not riding on the road, the 32T chainring and the 11 sprocket give me plenty of top end. Just last week I installed the Manitou Markhor air fork and DNM rear shock. What an upgrade that was! The bike handles so much better, is quieter, and my confidence is boosted! I found the Markhor at Taheahike shop for $217.00 and the DNM on Amazon for $80.00. Installing the fork was simpler than I thought it would be. I just removed the reducer crown race from the crappy, heavy, Suntour fork and put it on the Markhor. I didn't want to buy a new headset so I opted to purchase the straight steerer tube version of the fork. Everything went together well and the performance is awesome! The DNM shock bolted right on in place of the KS. After reading lots of reviews of people having to reuse their old spacers or grind down the shock I was worried. I can say I am happy it bolted right on! I also swapped out the grips for lock ons. The only other thing I'm going to upgrade are the brakes. It's a toss up between Deore hydraulic or SRAM Guide. I'll wait until the BB and hubs crap out on me before I upgrade them. I love my Silver Fox, especially after the upgrades. It's cool to see someone else that has one! I would have posted this earlier but I was awaiting activation from a moderator.
    Jun 2014
    The Manitou Markhor fork might be a suitable upgrade. That fork seems to come with all the little variants (straight steerer, 9mm QR, etc.) for upgrading the $500 hardtail. A Suntour upgrade might work, too.
    Oops, mentioned this before I read the immediately preceding post, which also rec'ed the Markhor.
    Bikes Direct bikes, as opposed to the Bike Island scratch n dents, come packaged somewhat better than yours did, typically.
    Jun 2018
    Update 4 below, but first I'd like to address @ilanoray.
    That's great information! I've only found a couple of other people (on YouTube) with this bike--as you've probably discovered, there's just not a lot out there about this specific model. Thanks for sharing your experience--I may have more questions for you soon!
    @TwiceHorn--the Manitou Markhor seems like the best bet for this bike. You can get a less expensive Suntour air fork, but they don't seem as well reviewed (or spec'd) as the Manitou Markhor. Since this bike isn't even for me, I'm going to let my girlfriend decide if she wants to buy a new fork.
    FWIW, I weighed the bike twice yesterday--once at a friend's house (more on that in a bit) and once at mine. He had the bike at 34lbs, I had it at 34.6lbs (exact same weight as a stock DB Atroz 1). I'm disappointed the bike is still this heavy. I figure swapping the fork will save a couple of pounds, but I'm running out of ways to get it down to a sub-30lb ride. I'm open to suggestions. The only other things that spring to mind are stuff like swapping the alloy handlebars for aluminium as well as the stem. That won't generate significant weight savings though. Of course there is the option to go tubeless. @ilonoray, I do recommend you consider doing this. I run tubeless on my Catch 2 and it works very well. Yes, you will have to put sealant in periodically, but not only will it lighten the bike, it can save you a lot of time on the trail changing out tubes from flats.
    Update 4: I took the upgraded bike for a 9.5 mile test ride yesterday on a gravel greenway (and minimal single track). I live in the foothills of the Appalachian mountains, so there was a lot of steep climbs and decents. I let my friend's wife ride the bike, while I rode next to her to get feedback. She is a fairly novice biker who currently rides a Spot Honey Badger single speed. Her bike weighs 28lbs, so there's around a 6lb difference. The most important takeaway from the test ride was that the bike shifted flawlessly over the entire ride. That actually surprised me quite a bit since I had done the 1x swap less than 24 hours earlier and had only dialed it in by adjusting the shifter cable tension on the handlebar. As I mentioned, there were a LOT of big hills but she was able to get up most (not all) of them with the 1x8 11-40t drivetrain. Now she's coming from a single-speed, and she wasn't even used to shifting a bike, which caused her some initial confusion. Plus, she's a novice rider lacking many basic skills. But I considered the test a mechanical success. She had no negative feedback about the suspension or brakes. That surprised me a bit--her hardtail has a Manitou air fork with hydraulic brakes. Of course, riding the Motobecane FantomDS Sport on singletrack will be a much better test for this stuff.
    I am sort of regreting buying the $25 Fox Float R rear shock instead of the DNM. She didn't have any issues with it, but I honestly can't figure out how to set the sag, and it only has a switch for rebound (no lockout). It holds air, but the max PSI I've been able to maintain is ~150. It works, but with the DNM only costing $80 that seems to make more sense. @ilanoray--did you use the bushings that came with the DNM or did you re-use the ones from the stock coil?
    I'm open to any & all suggestions about future upgrades to the bike--especially ones that will result in weight savings. As it stands, I've got about $571($449 + $122 in upgrades) into the bike. I'm generally satisfied with it, but if we throw another $220 into an air fork, I think it's legitimate to start price-comparing it with bikes in the $800-$1000 range as it pertains to value & convenience. Now if you buy this bike from Bikes Direct for $600, it's not really a great deal IMHO, and I think you should consider either a used bike or a Diamondback Atroz 1, 2, or 3 (with a corp discount or ExpertVoice discount). If you can find it for ~$450 (like @ilanoray and I did) then I think it's probably a better, upgradeable bike than big box bikes like the Mongoose XR Pro, the GT Aggressor Pro, or the Nishiki Colorado Comp. The Motobecane FantomDS Sport is a beautiful bike and has plenty of upgrade potential if your budget restricts you to sporadic upgrades. But it's a heavy bike, and I haven't found a way around that fact.
    Apr 2019
    Review of Motobecane FantomDS Sport-silverfoxsus.jpg@Forbin, the DNM rear shock was a direct bolt on. I only used the original bolts.
    Jun 2018
    @ilanoray--that's a sweet conversion. I've got some questions if you have time...on the fork--can you walk me through swapping it with the stock? Is it as simple as just undoing the headset, dropping the stock fork, and removing the crown race? Speaking of the crown race--is that how they're adapting the straight-tubed fork to the tapered headset? Did you happen to snap photos or get a part number off it?
    What size frame did you get?
    Do you have an estimate on the weight difference between the stock forks and your new ones? If I'm reading the Suntour website correct, the stock forks weigh 2650g (5lbs, 13 oz).
    Have you weighed your bike since you completed the conversion?
    After seeing your killer 1x10, I'm sort of regretting cheaping out and just doing a 1x8, but I hope my girlfriend will be okay at least for a season while she builds skills.
    Oh, I should probably pass on to you that when I pulled the stock bottom bracket, I found everything to be well greased in there. You never know with mail-order bikes so FWIW, it looks like they paid attention in that area (unlike my loose cassette).
    Apr 2019
    @Forbin, with the fork I just disassembled the FSA headset, dropped the old fork, tapped the crown race off the old fork, placed it on my new Manitou, and lubed and reassembled. Before final assembly I measured the steerer tube 3mm above my stem and cut it with a plumbing tube cutter. This is the same height it came with. The crown race they use is a reducer so they could install a straight steerer fork in the tapered headtube. You can go either way, tapered or straight. I opted for straight just to keep from buying a new headset. I didn't see a part number on the reducer crown race.
    I purchased the 16.5" frame for my 5'8" height.
    The Manitou fork weighs about 3lbs. The DNM shock weighs about 1lb. I haven't weighed my bike or the sum of the takeoff parts.
    Jun 2018
    Update 5: Although I haven't made any other significant modifications to the bike since the last update, I did loan it out to a lady to give it a extremely thorough test here in the mountains. The terrain consists of 12 miles of single track, lots of climbs, lots of flow, berms, rock gardens--everything but downhill. The woman is 5'10" and stated that the bike fit her fine.
    Without any hyperbole, this gal smoked the rest of us. I mean, she literally took off out of the gate and rode super aggressive for the first 6 miles. She'd wait for the rest of us intermittently, and I'd get her feedback.
    She absolutely loved the bike and praised the way it handled. I specifically asked her about the stock (coil) Suntour XCM fork, and she said it was fine. She reported an issue with slippage in one gear, but I got that dialed back in for her on the last 6 miles. She had no issues whatsoever with the 1x8 gearing and was able to easily climb the more aggressive sections (I live in the mountains). She did say that she'd prefer a 1x11, but she obviously had no problem smoking me and my buddies (to be fair, the rest of the crew were riding single-speeds). Oh, (edit) she did state that my choice in using the stock shifter wasn't ideal--she said it worked fine, but she'd have preferred a more robust one.
    Also, I've held off purchasing hydraulic brakes for this bike--I've been ready to pull the trigger a number of times but knew that my girlfriend (who won't be back in town until June) won't ride aggressively--figured it was better for me to focus getting a new fork instead. Anyway, the gal who test-rode the FantomDS for me had zero issues with the stock mechanical brakes either. I actually swapped my bike with her for about 1.5 miles and can attest to the fact that the mechanical brakes are working much better now that I have them adjusted. I'll still probably order a set of Clark's M2s though....
    So that's the update for now. The gal who test rode the bike is an experienced cyclist who rode the hell out of it and gave it glowing a review. That was important to me for a couple of reasons. First, I wanted to make sure that my upgrades were "trail tested" and that nothing would fail. Secondly, I wanted an experienced rider who was the right height to give me honest feedback on how they felt the bike handled when pushed. This really validated the bike's geometry and quality of the frame. I'm actually a bit surprised in the feedback I got in this area in that I honestly thought I'd get some negative comments about the bike's weight, handling, or the crappyness of the stock coil fork. Now obviously I expect the bike to perform far better when I put a Manitou Markhor on there, but I'm very pleased that my test rider had no complaints or negative feedback after rock gardens, etc. The FantomDS handles great--like I said, that gal smoked all of us.
    That's it for now--this lady has actually asked me to let her take the bike to our downhill park in a couple of days. I'm going to let her do it with a caveat to not jump it on the black diamond trails. I just don't trust those Suntour forks enough for that. I'll report back for those interested.
    Apr 2019
    Awesome! Thanks for the update. Sounds like you're making sure it's gtg for your lady! I just wanted to chime in on the brakes and fork. I just installed XT M8000 hydraulics and all I can say is WOW! Night and day difference. I can feather the brake much easier than the cable actuated brakes and the stopping power is super good. It's a worthwhile and safe upgrade IMO. On the Markhor, after you adjust the travel from 100mm to 120mm, make sure to add the proper amount of 5w fork oil to the damper side. I found Maxima at the local motorcycle shop for a reasonable price. I had to add 6ml to mine to bring it up to 97mm. I would definitely not let anyone jump with the Suntour. They have a disclaimer saying they're not liable if someone uses the fork for jumping, freeride, or downhill. Basically, they're saying "don't use this as a mountain bike fork" lol! I've been riding the Markhor/DNM combo for a few weeks now and it's transformed my mediocre bike into a capable and confidence inspiring machine. I am now doing blacks, drops, and small jump lines. Stay stoked!
    Reputation: metalskool's Avatar
    Feb 2019
    Quote Originally Posted by Forbin View Post
    Thanks for that review! I put the Manitou Markhor(26" 100mm) on my old hardtail and I find it to be a great fork. I'm very happy for you and hope you guys continueto enjoy your Moto!
    Jun 2018
    Update 5.1
    This is just a minor update, but maybe an important one at anybody who stumbles across this thread and contemplating an upgrade path. Took the FantomDS Sport out to the downhill park tonight and let the same woman ride it. Although she was tearing it up, both up and down the mountain--I got some more pronounced negative feedback. Specifically, she wasn't at all happy with the 1x8 gearing. I knew when I made that modification, that it would really limit the bike to XC riding, but the take-away is that you may want to think twice about taking that short-cut to save some money. I'm not overly concerned about it since I won't be taking my gf to ride anything that aggressive. If she ends up enjoying the bike, I'll do the upgrade to a 1x11 next season.
    So the test-rider didn't like the 1x8 either in climbing OR in the decending. In the climbs, I think it was mainly because she didn't have the range of gears she wanted. On the decents, I think her issue was actually more with the (stock) shifter--it works, but she was really flying down the trails and was trying to rapid shift on that cheap stock 8-speed shifter. She rides extremely aggressively--to the point that I had to warn her to dial it back because I was concerned for her safety with the crappy stock coil fork and mechanical brakes. I did relent and let her go down a black diamond, but I told her flat out to ride that conservatively and not to try to do jumps because I was really worried about that XCM fork. That said, she came down it fine and had a blast doing it. We rode about 13 miles total--5 trips up the mountain and 5 down. Other than the compalints I've already mentioned, she didn't have any real issue. She really has put the bike through it's paces and other than the limitations of my modifications, the bike has more than held up to everything she's thrown at it.
    So here's my current opinion on the FantomDS Sport: It's a solid, legit bike that can pretty easily be upgraded to a legit mid-tier full suspension. You'll need to convert to a 1x (with a wide-range cassette and ideally a better derailleur and shifter), replace the coil shock, and get a legit fork. You'd probably want to upgrade to hydraulic brakes, but honestly, my test rider says the mechanical ones are performing fine. The biggest complaint I have about the bike is that the wheels take a 9mm QR skewer and not a modern thru-axle. Now you can upgrade that, but since one of the FIRST things you'll want to do with this bike is swap out the fork, you're immediately having to either decide from a handful of forks that accomodate those old school wheels OR invest hundreds more in upgrading wheels too. Thhe wheels aside, the frame, geometry, etc. is solid & legit--capable of doing serious trail riding. The FantomDS Sport is a great platform bike that you can upgrade as your skills improve. If you can buy it at an even bigger discount (like I did) and are on a budget, it's probably your best option. If you've got $900+ to spend, then you'll probably have some decent used options. Bikes Direct does sell the FantomDS Comp for $1099 which is the same frame, but with upgraded shock/fork/wheels--but it does still shockingingly come as a 3x10, but that should be simple and inexpensive to convert to a 1x10.
    Jun 2018
    I disassembled the headset today and snapped some photos. Just sharing in case anyone is interested.
    Attached Thumbnails Attached Thumbnails Review of Motobecane FantomDS Sport-img_20190510_191444.jpg
    Jun 2018
    Update 6
    As I might have mentioned previously, I ordered a KS eTen dropper from Amazon that came with a broken air cartridge. The seller refunded my purchase and let me keep the dropper so I ordered an air cartridge from Performance Bikes for ~$30. I've never worked on a dropper previously (although I have one on my Catch 2). Because I had already dissassembled the eTen a number of times trying to fix it, I also picked up a tube of Slick Honey lube from REI (that stuff is expensive). The air cartridge fixed the problem, but because I didn't have the collar sleeve nut (and screw) I had to get REI to order that for me too. I also messed up a couple of cables trying to jerry-rig it...so I had to get a new cable as well. Ugh.
    I also ordered a Manitou Markhor straight tube fork--I got it for $209 (with a rebate code) from Performance Bikes. I toyed with the idea of installing that myself, but my mechanic at REI told me he'd only charge me $15 to install it, so I went that route. I'm glad I did because he actually had the proper tools, and I know I would have run a risk cutting the tube and driving the star nut in without proper tools. He recommended adding about 20mm to the length of the new steerer tube in case future adjustment for comfort was needed.
    For those wondering, the stock Suntour XCM forks weigh 2761g (6lbs 1oz). The new fork weighed 1685g (uncut). After cutting, it weighed 1668g after cutting (3lbs 11oz). 1093g's (2lbs 7oz) total weight savings.
    So everything went together well, and I've test ridden the new configuration around my neighborhood (not on trail yet). It seems to ride great, but I'll withhold a verdict until I can get it properly trail tested with the new components. I will probably go ahead and convert to tubeless in the next couple of weeks. I just want to lighten the bike up as much as possible. The only other upgrades I see on the horizon are hydraulic brakes. I'm leaning towards a set of Clark's M2 or M3s from Chain Reaction Cycle.
    Apr 2019
    Good deal on the fork! Did you adjust the travel to 120mm? I finally went tubeless last Thursday and the wheels are much lighter. Not sure if its placebo but, my climbing has improved vastly. The rear grips better and doesn't spin as I reach the top anymore. I used Orange Seal, WTB tape, and WTB valves. No leaks at all so far. I just now replaced my BB and crankset with the Shimano Zee 1x 10spd with Hollowtech II bottom bracket included. Gonna take it to the trails tomorrow. These bikes are really fun to upgrade and they are definnitely trail capable! Thanks for posting the updates!
    Jun 2018
    Quote Originally Posted by ilanoray View Post
    I haven't done anything with the fork (yet) other than to pump it up. I'll have to look at YouTube to see how to adjust the travel. Is it difficult?
    Glad to hear you're liking tubeless. I run tubeless in both my 27.5+ tires as well as my 29" wheels. I held off going tubeless in my 29" for a long time (lazy) but was shocked at how noticable the difference was. I actually had to adjust my riding style because I was pulling my front wheel up off the ground when climbing?!? When I went tubeless in my 27.5+ tires, the weight difference was less noticable. In that case, the low pressure is actually what actually made a big difference. I'm still running the stock tires on the FantomDS Sport, and boy, they aren't great IMHO. I'm not going to change them out this year though since my girlfriend is a novice and I'd prefer to get some use out of them.
    What size tape did you use with your tubeless conversion? I used 1" Gorilla tape on my 29" wheels (I use Orange Sealant as well).
    What cassette are you using now? Will the stock hub take a 10 speed?
    Apr 2019
    There is a video by Takeahike shop that shows how to adjust the travel. I did it to mine just because the bike comes with 120mm stock and I didn't want it to handle wonky. It wasn't too difficult. You will also want to add 5w fork oil to the damper side to be 97mm clearance. I added 6ml of Maxima fork oil to achieve that level. YMMV. I got the fork oil cheap at the motorcycle shop. The lower fork oil is just full synthetic 5w30 motorcycle engine oil. I am contemplating adding the upgrade damper for 70.00 as well. It has high and low compression damping settings as opposed to just lock or unlock with the stock quick toggle.
    The first time I attempted to go tubeless I used the 1" wide gorilla tape, Stans sealant, and Stans valves. Could not get it to hold air for anything! This time round I used the i25 WTB tape, which is 30mm wide, since my wheels are the WTB STP i25. I also used the WTB TCS valves. I figured I'd have better success using WTB's stuff. I reckon I figured right lol!
    I'm running the Deore CS HG-500 11-42T 10 speed cassette. It fits right onto the stock freehub. Only thing is, since mine is a Hyperglide C, I had to use the stock lockring. It fits and runs flawlessly. I had a bad chainline just using the center spot (104BCD) of a 3 ring crank so in my uppermost 3 cogs I'd get chain jump and clunking. Since I installed the Zee 1x 10spd crankset, the chainline is much improved. I can backpedal in the top cogs without the chain dropping. I'll further assess it tomorrow on the trails while climbing. That's when I had the most problems with the chainline. Under stress going uphill.
    May 2019
    Glad to find this forum
    Hello everyone! I too am a Motobecane DS Fantom 29er Sport owner and I'm ready to do some upgrades so I can feel more comfortable riding. I've already upgraded the rear shock so I'm contemplating the front fork to an SR Suntour Epixon. Any thoughts?
    Jun 2018
    Quote Originally Posted by Sinfonian76 View Post
    I was considering the Suntour upgrade program as well, but it didn't make financial sense to me. Maybe I was reading it wrong.
    As I understood it, the upgrade program would allow you to purchase an Expicon for somewhere around $275--does that sound right?
    I have zero experience with the Expicon; I did some online research and there are decent reviews, but pretty much everything I read said the Manitou Markhor was a superior performing fork. Plus, it's cheaper, selling for anywhere from ~$180 (Aliexpress) to $223 (Amazon).
    Also, note that you can purchase an Epixicon via Aliexpress for around $150 (with remote lockout). A Suntour rep has verified that these are genuine Suntour products, but they are slightly different than the US versions. Specifically, these Asian Epixicons use a non-user servicable air cartridge (sealed) instead of a servicable one. They perform well (from everything I've read), but you'll have to either replace the air cartridge eventually or convert it to the US version. There are YouTube videos that explain the details. I was tempted to go this route myself, but ultimately I just opted to get the Markhor. It has a really solid reputation and I the price is decent. If money is a major factor, I'd absolutely look at ordering from a reputable seller on Aliexpress and getting either the Expicon or a Markhor that way.
    All that said, that's my my opinion. Hopefully some other FantomDS Sport owners will chime in with their experience as well.
    May 2019
    Thank you Forbin for your response! Sometimes when I ride in the group rides, I feel that my bike may be sub-standard in comparison to theirs or it could be my inexperienced riding (or both). I think maybe if I begin upgrading some of the components, I can gain some confidence with practice.
    Jun 2018
    The stock FantomDS Sport may or may not be a lesser bike that what your friends have, but it is certainly capable of being upgraded to a very solid mid-tier full suspension model. If your friends are riding $2000-$5000 bikes, you won't be able to hang on the stock bike, but after you do some basic upgrades, you shouldn't have any issues.
    Since you're already upgrading the forks (and have done the rear suspension), the only other thing really missing is the drivetrain. What I did was fairly inexpensive although if I had it to do over again, I probably would have opted for a 1x10 or 1x9 conversion. I went cheap and used the stock rear derailleur and stock shifter and just did a 1x8. If money is a real issue, then go the route I did at least for a season or two. If your budget allows, then do what ilanoray did and go to a 1x10.
    EDIT: See Update 8 below--anybody upgrading the drivetrain should just do a 1x11. The hubs do not limit you.
    What I will tell you is that the FantomDS Sport is a great platform to upgrade from. The frame itself is very solid and performs extremely well. Even with minimal upgrades, the lady who test rode my FantomDS Sport was able to smoke my friends and me. With the latest upgrades (fork & dropper), the bike is easily comparable to a $1200+ full suspension bike.
    Feb 2019
    Kev Central did a review of that fork on one of his bike builds:
    https://www.youtube.com/watch?v=GG-V0-Wg1UE
    I have the Manitou Markhor on a hardtail and I love it. I agree with Forbin about the Markhor- better price, better performance, and I think lighter.
    A review of the Manitou:
    https://www.youtube.com/watch?v=drvxGGtuTu4
    Jun 2018
    I was out of town this weekend (on a biking trip with my crew) and wanted to throw out a couple of things. First, I actually ran into a lady riding a FantomDS on our first ride!?! This was actually the first Motobecane I've seen in the wild, and it just happened to be the exact same frame and color as my girlfriend's bike! The lady I ran into had better stock components, so it wasn't the FantomDS Sport...I can't remember the exact groupset, but she had RockShox forks up front as well as an air shock in the rear.
    That aside, I also wanted to pass on to Sinfonian76 more information about the Epixon air forks on AliExpress. Here's a video where a guy explains the differences and what your options are.
    Again, if you're on a budget you should take a look at going this route because you can save a lot of money and you can upgrade the internals when the air cartridge eventually goes bad.
    May 2019
    Awesome! Thank you for all of your insight!
    May 2019
    Next I want to upgrade my 3x8 to a 1x 10. Any thoughts or experience on what I should get? I don't want to run into any hiccups during the install.
    Jun 2018
    I'd defer to ilanoray for 1x10 advice. What I will tell you is that I have been really happy with using the Sunrace extended-range cassettes as opposed to Shimano or Sram. They provide (as the name suggests) a wider range of gears. That said, some derailleurs will require an extender; there's a vendor called JGbike on Amazon that sells a variety of wide-range cassettes (both Sunrace & Shimano) along with the extenders. The prices are very reasonable. This is what I'm currently running with my 1x8 setup. I will almost certainly upgrade to a 1x10 next year if my girlfriend enjoys riding this season.
    Apr 2019
    HI. I am using the Shimano Deore CS HG-500 11-42T wide range cassette. I paired it with the Shimano RD M-8000 Shadow Plus derailer. Designed to work together so it's a direct bolt on. I am reasonably certain it will work on other wide range cassettes up to 42T as is. I'm thinking if the spacing is the same between brands. Not 100% sure though. I am currently using a Race Face N/W 32T chainring. After riding it a while I was having a bit of chain drop from the 3 uppermost (low) sprockets while climbing steep inclines. The chain would skip down to the next sprocket while under load. No bueno lol. I narrowed it down to crappy chainline. I just installed a Shimano FC-640 crankset designed for 1x10. It's a DH part so the crank arms and peddle inserts are steel, for strength. The weight is negligible to me. It came with a Hollowtech II bottom bracket. Instead of placing the 2.5mm spacers as 2 on the drive side and 1 on the non-drive side per Shimano for a 68mm BB shell, I placed 1 on the drive side and 2 on the non-drive side. This brought my chainline in a bit. I haven't tested this adjustment on the trail yet. I'll be going this weekend. If 2.5mm wasn't enough to cure the chain dropping/skipping I may transfer the remaining spacer to the non-drive side of the BB. Visually it looks good in the top 3 sprockets. Overall, I am enjoying the conversion to 1x10. The only thing I have left to do to this bike is lace in some DT 350 hubs and maybe convert the standard QR skewers to DT Swiss RWS. I hope this helps.
    Jun 2018
    Update 6.1
    Just a minor update based on my 1st ride after installing the fork & dropper. I took the bike out this afternoon for a short 6.2 mile ride here in the mountains. I spent Memorial Day weekend riding trails in the Chattanooga area, but took my own bike. Today was the first time I've ridden since returning--and the first time I've actually taken the FantomDS Sport out myself in a long while--also the first time it's been ridden at all since the fork and dropper installation.
    I took it up (and down) the mountain twice. Everything is singletrack with a good mix of groomed trail, some roots, and some small rock gardens.
    I had to dismount the bike a few times in the first mile to get the dropper's height adjusted for me. I should note that I'm 5'11" and this bike is 16.5" and supposed to fit someone 5'6"-5'8". That said, with the dropper pulled up fairly high, the bike fit me pretty damn good and I could see myself actually riding it in lieu of my own bike. Without the dropper, I had the seat post pulled up, but lacking the ability to adjust for up & down hills made riding it a lot less fun. The dropper is friggin' awesome. Now that said, note that the FantomDS comes stock with a non quick-release seatpost clamp. I'm glad I replaced that with a QR version, otherwise all the adjustments I did today would have required my bike tool.
    I don't really know what to say about the forks. They rode pretty darn well. I didn't lock them out ever and the bike still climbed fine. They provided ample cushion. I had the rebound adjusted to the fastest setting--I might dial that down a tad to try it. It's nowhere near as plush as my Rockshox Pike, but the Manitou Markhor does the job just fine. I can absolutely tell the bike is lighter. At this point, I have no trouble asserting that my (girlfriend's) FantomDS Sport handles fairly comparable to a bike that costs $1100-$1300 (with some caveats).
    The caveats are my cheap drivetrain upgrade diminishes what the bike is really capable of. The 9mm hubs up front are also pretty dated and devalue the bike, but they don't really impact the ride.
    A few other random notes. Despite my initial criticism of the stock brakes, I've got them properly adjusted now and they are performing very well. Mechanical brakes devalue the bike as well, but since they're performing okay for me, I'm in no hurry to swap them.
    The stock tires are not great on my local trails. In fact, as things currently stand, that's probably the weakest link on my bike. They're not horrible, but they're just a poor fit for the singletrack in my area. Still, I'm going to let my girlfriend ride them until she complains or I decide to spend more money.
    The only other issue on today's ride worth mentioning is I had trouble with the gears slipping and I actually had a chain drop after I used the barrel adjustor to try to dial things back in. I'm really starting to get peeved about cheaping out on that drivetrain.
    Jun 2018
    Update 7
    Went ahead and did the tubeless conversion today. I've done a couple before so it isn't really intimidating. I used Gorilla tape to seal the rims and some very inexpensive stems I got on Amazon (I got a set of 4, and used the other 2 on my 29" wheels for my bike).
    Going tubeless is pretty straight-forward and I personally recommend it. If anyone has any specific questions, I'll try to answer. As to the stock rims & wheels on the FantomDS Sport--they're made for tubeless. The tires have a hell of a bead on them, so be sure to wipe it down with soapy water before trying to pry them off (or put them back on). I gave up on trying to use a handheld pump to reset the wheels, although the stock tires on the FantomDS are so skinny, they might pop fine. I used a compressor. I actually did have an issue getting the first (front) tire to re-seal but once I put some soapy water on it the entire bead popped back on with the compressor. Oh, I also used the valve stem to fill the sealant.
    Once you get the tubeless tires mounted, you really should ride it immediately--and make sure to ride it pretty rough. The purpose in this is to get the sealant all over the interior and to also force the bead to really lock in place. Unfortunately, I didn't have time for that so I just took it for a spin in the parking lot for a few minutes.
    As I type this (about 5 hours later) I can tell that the tires aren't holding air the way I'd like. This is fairly typical, however--it might take a few days for the tires to permanently seal. I'm not concerned at the moment, but will keep an eye on it over the next few days.
    May 2019
    Question... Can I use slime as tubeless sealant?
    Jun 2018
    In short, no, do not use Slime in your bike tire. You'll probably want to use a product like Stan's (which is the most common). I've used Orange Seal Endurance on multiple wheels over the past year and it has been great. Do some online research about the various sealants available. Some seal better but have to be refreshed more often (i.e. more sealant must be added to the tire more frequently). Some last longer than others. Some are designed for cold-weather climants. Some work with Co2 whereas others don't.
    Back to Slime--they do market a tubeless tire bike sealant that might work, but be very careful to only buy that and not one of their many other sealants that are 100% incompatible and will likely destroy your tire and perhaps make a horrendous mess of your wheels. Stan's is probably cheaper anyway.
    Jun 2018
    Update 7
    My girlfriend (who I purchased this bike for) finally got back into town and has been riding it for the past couple of weeks.
    There's not an awfully lot to report, however, as she is a total novice rider. She did purchase some Ergon grips that I put on for her, and she also insists on using a gel seat-pad cover (which I am totally embarassed by).
    I've spent much of the past couple of weeks taking her out on gravel roads, but have recently introduced her to single track. She's pretty slow, but she's done fine. She's obviously not skilled enough to really push the bike anywhere near it's limits, but the bike is good enough that she's at least getting her sea-legs in the sport on a good bike.
    There's only one area of the bike that I'm totally dissatified with, and that's both my fault and my bad decision--the drivetrain. Sticking with that stock shifter & derailleur has continued to cause issues. It's not that it's complete trash--it just slips sometimes and the shifter is just not ideal for a 1x. The Sunrace cassette and the 30T chainring (and cranks) I put on are okay, but I should have just gone to a 1x10 and gotten a new shifter & derailleur. I think her experience would be much better.
    I have kept the mechanical brakes and that was a solid decision. They're fine--at least for her current riding skill. If you go back and read my original posts about this bike, I trashed the brakes as unsafe (they were). This points to a weak area with Bikes Direct--you really need to have some experience with bike mechanics (and own proper bike tools) to get on the road--otherwise you'll need to pay for assembly and probably frequent adjustments until you get it dialed in to your liking. Back to the brakes--they just needed some adjustments to get them fully operational but out of the box they were a real safety issue. I was surprised because my previous bike from Bikes Direct (a Windsor Cliff) didn't have this problem, nor did my Diamondback (another direct-to-consumer bike).
    Future updates on this project bike will most likely be slow since I'm pretty much done with tinkering with it for the season. I do plan on letting the lady who test rode the bike for me take it out again now that I've got the Manitou forks and dropper post on. I'll probably do an update for that because she's very skilled, rides hard, and will be able to provide useful feedback on those modifications. I wanted to document my experience with the Motobecane FantomDS Sport primarily because there isn't much information about it online so hopefully my ramblings will prove useful for someone googling in the future. If anyone ever has any questions regarding this bike or my experience upgrading, please just ask and I'm happy to give you my .02.
    May 2019
    Thanks for the update, I recently upgraded my fork and added WTB Trail Boss tires. I can really feel the difference in the weight of the bike. I also took heed to your advice and bought orange sealant. I'll try it out tomorrow on my first ride in a couple weeks!
    Jun 2018
    Update 8
    Big changes to the bike are currently in the works. But before I get to that, here's a report of how the bike has done with the previously done upgrades...
    My girlfriend rode the bike a decent amount this summer. Her skills are limited, but overall the bike performed okay--with one exception. She constantly complained about the drivetrain. Specifically, she had lots of problems with the gears slipping. This mirrors the feedback I've gotten from the woman who test rode the bike for me a number of times. No amount of adjusting ever totally fixed the issue, and a 1x8 with the original derailleur and shifter was just an asinine idea on my part.
    So I ordered a new drivetrain. I was really interested in getting a Box One or Box Two setup, but in the end I went with the less expensive SRAM NX 1x11 set--shifter ($29.95), derailleur ($70.95), 11-42t cassette ($66.95)and SRAM chain (~$24.00).
    I need to point out the fact that I was extremely worried that the rear hub wouldn't accept an 11 speed cassette. I believe in my first few posts I even complained that the rear hub would really limit the upgradeability. I need to go back and edit that. Apparently those Shimano hubs will take up to an 11 speed cassette--so if you've got this bike, don't be stupid and do a 1x8 conversion like I did--just spend the money and move to 1x11. Trust me.
    I've also ordered a set of Shimano M315 brakes from AliExpress ($32.89 shipped).
    I put the drivetrain on evening before last, but had difficulty with the chain. I exchanged the chain at REI and put the new one on today. It took me a while to get shifting dialed in (and I'm still not 100% happy) but it seems mostly good to go.
    I'll post some photos once I get the grips back on and have a chance to test it on the trail. Preliminary opinion is that it is a major improvement. The NX shifter is just far better suited for a 1x setup than the stock shifter.
    I probably should also point out that if you're thinking of doing any of these upgrades yourself, you're going to need to buy some specialty bike tools. Specifically, you'll need to invest in either a Pedro's or Park Tool cable cutter. Don't try to cut your shifter cable (or housing) with a non-specialty tool--it will likely end in tears. It might go without saying, but you'll need a good chain breaker tool--I recommend the inexpensive $15 Park Tool. Finally, I also recommend you get a set of bike chain pliers. This might not be as necessary as the other two tools, but it makes things a lot easier if you need to remove the quick link on your chain as you're adjusting it.
    I have no idea how long it will take to receive the brakes. I'll leave that for another update.
    Jul 2019
    just curious how your dropper post install went. I ask because when I got my bike the stock seat post for 1 was super long but even after cutting it down a couple inches it wont go down very far in the frame, I don't know if its a bend in the tube or paint either on the frame or the seat post itself. I have a dropper coming in the mail and don't want it to be too long to be useful when fully dropped. also, did your model have the internal dropper routing?
    Jun 2018
    Quote Originally Posted by GSREPTAR View Post
    The dropper post install was overall easy. I had some issues because the dropper post I ordered came with a bad air cylinder. Long-story short, the seller refunded my money, and told me to keep the dropper. I ordered a replacement cyclinder ($30), got it working, and installed it.
    The Motobecane DS-Sport doesn't have internal cable routing, but the frame does have external routing for a dropper. Unfortunately, the model also has an antiquated seat-post size (27.2mm) that will really limit you when choosing your dropper.
    My personal bike (Diamondback Catch 2) has internal routing and came with a KS Lev Integra. It's a pretty high-end dropper (compared with the E-Ten on my girlfriends Motobecane), but it can be a PITA because the internal cabling causes it to stick if the cable isn't positioned in exactly the right way.
    The frame on the Motobecane has a straight tube (no bend at all) so there's no issue fitting the dropper. If you're ordering a different model, then you might very well be limited...it's difficult to say.
    I will say this--every single friend of mine who has tried a dropper buys one and swears by them (as do I). Any mtb I buy in the future will have one. I use my dropper constantly while I ride. It makes a world of difference. I would recommend against buying any bike that won't accomodate a dropper.
    Jul 2019
    My ds sport does have internal routing though
    Sent from my SM-J737T1 using Tapatalk
    Reputation: Forbin's Avatar
    Jun 2018
    My girlfriend's bike is the 27.5" version...is yours 29"? I just checked the BikesDirect website and I couldn't immediately find a listing for the DS Sport, although Googling took me to a page (with only a 14.5" in stock).
    When did you order your bike? What size frame do you have? How long have you had it? Regardless, it's awesome you got internal routing--mine (or my gf's) has none.
    Although I can't see the entire rear triangle of your bike, assuming it's the same as mine, you shouldn't have any issue with the internal routing. Just make sure you know the post size before ordering--if yours is the same as mine, you're going to be limited.
    Also, if you've got any questions about the other upgrades I've done (and am doing) just let me know. Hopefully somebody will learn from my mistakes!
    Jul 2019
    It is a 29er in 17" frame and I got it about a month ago maybe. I've been eyeing your post and the gentleman who explains how he did his 1x11 setup.
    Jun 2018
    My gf's DS Sport is a 16.5" with 27.5" wheels, so that might be the difference. Regardless, you've got a better frame. If you can find the BikesDirect page with your specs, please post it. I'm just really curious about what else is different.
    So as to the 1x11 upgrade, mine is still a work in progress (hence why I haven't done another update yet). I had an issue with the SRAM NX derailleur I got and had to exchange it. Will be putting on the new derailleur tomorrow. I did have a chance to test the bike briefly prior to the original NX derailleur breaking.
    As I've said probably 100x in this thread--don't make my mistake and waste money on anything other than going to 1x11. The hubs will accomodate an 11 speed cassette so you have options with Shimano, SRAM, and Box.
    I kind of lucked-out with that cheap Fox Float rear shock I got, but I sort of wish I had just purchased the DNM that most people used.
    If your hubs have the same (antiquated) 9mm QR skewers mine does, then you'll be limited on your upgrade path for the fork unless you get a new wheelset. But you bought that bike for well under $1000 and Motobecanes generally have crap resale value so just ride the hell out of it--it's a great bike, and I'd wager the 29" version you have is even better than the one I have.
    Jul 2019
    Looks like they only have 27.5 left but i got mine from bikeisland.com under a scratch and dent sale.
    decided to grab a cheap cable set from the store and see how difficult its going to be for the dropper routing. unbolted 1 of the cable guides mounted to the frame (the one on the downtube) and had it routed in about 5 minutes. just waiting on the USPS now to bring me my dropper and lever!
    Jun 2018
    Please do post an update once you get your dropper installed. Feel free to take photos and share your experience in this thread...might as well make this a one-stop shop for people looking for info on the Motobecane DS Sport.
    For anyone who stumbles across this thread and is curious about Bike Island--it's a sister-site to Bikes Direct where they supposedly sell scratch & dent bikes. I've purchased 2 bikes from them and they were both in perfect condition. I suspect they also use it to blow out inventory without having to offer a site-wide sale on Bikes Direct. YMMV.
    I will post a real update on my upgrades very shortly. Long-story short, I had my LBS install my new SRAM NX derailleur because I had some issues. I got it back today. I also got my $33 Shimano M200 hydraulic brakes from Aliexpress today and just installed them. I've got a group ride in the morning and will hopefully be able to get somebody to ride the Motobecane in order to test it.
    Jul 2019
    Broke my rear derailleur yesterday and ordered a sram nx myself.
    Jun 2018
    Okay...gotta ask...how did you break your derailleur? Did you break the stock one? Are you going ahead and doing the 1x11 full upgrade (with the NX shifter)? If so, don't forget you'll need a new chain as well.
    Jul 2019
    Like a 1 foot jump. When I landed I think it flexed down and contacted the spokes (pretty sure the hanger was ever so slightly bent from day 1) and ripped it clean off bending the hanger even worse and even twisting the chain. I am going to finish the nx 1x11 setup but over time. I'll see how well I can make the sram derailleur work with my current setup and go from there.
    Jul 2019
    The aftermath
    Jun 2018
    Update 9
    Got the bike back from my LBS where I had them adjust the new SRAM NX 11-speed derailleur. Without getting into too many details, I had ordered this part but the B-screw somehow punctured through the plate where it adjusts and I had to return it. When I got the replacement, I mounted it to the bike and just let my LBS adjust it ($18).
    Yesterday, I received my Shimano M200 hydraulic brakes that I ordered off of Aliexpress ($33). After I got my bike back from my LBS last night, I put a headlamp on and mounted the brakes.
    Installing the brakes is fairly straight-forward. I just removed the old brakes and re-used the mounting brackets that were in use for the mechanical brakes. The only real "issue" is that I was unable to snake the rear brake through the rear-triangle suspension because the both the lever and the brake were too large to do so. I merely attached the brake hose to the cable-guides on the frame and went around that section. It's not perfect, but functional. I'll eventually fix this when I have to bleed the brakes and remove the hose.The brakes I ordered fit perfectly (i.e. hose-length) on the 16.5" frame.
    I had a 6 person bike-ride today and loaned the bike to a guy from Europe who didn't have a bike. I've ridden with him previously and he's a fairly skilled rider. We did ~15.5 miles with a solid mix of flowly single-track, gravel road, and highly-technical climbs & decents in the foothills. He had never ridden the bike previously, however the French lady who tested the bike thoroughly in the past was also able to ride it (briefly).
    I cannot stress this enough--the SRAM NX 1x11 drivetrain upgrade makes it an entirely new bike. It shifts flawlessly and can handle climbs with changing terrain with zero issues. I won't belabor the point other than to say that I consider this the most significant upgrade you can make to the FantomDS Sport--moreso than the the suspension system. The brakes also performed fine. There's really not much to say about brakes, but I rode the bike around a bit afterwards and for $33, I've got no complaints. That said, the mechanical brakes worked well too. Unless you're doing crazy downhill stuff, the mechanical brakes are probably the last thing to upgrade. The M200's I got are entry-level hydraulics, but I see no reason why they won't be more than adequate for even harder XC riding.
    Jul 2019
    Weird our rear triangles are in fact different. Look at the orientation of my dropout and cable housing
    Jun 2018
    Here's a LINK to the brakes I purchased. The price seems to fluctuate, but it's back down to $31.46 for a set as I write this. There are plenty of other sellers on AliExpress that sell them at a similar price-point.
    Here's my experience ordering these...they arrived in 14 days (to the East coast of the USA) after I placed my order. They came in a sturdy cardboard box and the brakes were individually wrapped in bubble wrap. Some sellers will offer different length rear brakes--I got the 1400mm version and it fits perfectly on my 16.5" frame. I recommend measuring your mechanical brake line just to be sure.
    I didn't use the included mounting bracket--I just used the ones that were already on the bike.
    The brakes seem 100% legit. I believe the M200 is the Asian version of the Shimano M315 brakes.
    Brakes came pre-bled and are basically just bolt-on. You can literally have them installed in 10 minutes or less if you have basic skills.
    As far as performance goes, they seem to work great. As mentioned in my previous update, my buddy took them on a 15.5 mile ride this weekend that included some real sketchy, technical downhill.
    It is still too early for me to 100% vouch for these brakes, but at less than $32 they seem to be a steal if you're a XC rider.
    Jul 2019
    so according to this the sram 12 speed cassette will fit on the existing wheelset.
    or am I reading something incorrectly? theyre both listed as 8/9/10/11 speed compatible rear hub.
    If they are in fact compatible then one could get an entire 12 speed drivetrain
    for less than $200 on aliexpressÖ..
    Apr 2019
    Fantom DS Sport (Silver Fox)
    Nice work on the mods Forbin. Hydro brakes really do make a difference. Since I never liked the dark silver color and planned on changing it anyway I stripped the paint off and liked the raw look so much I just kept it raw. If I tire of it I'll get it powder-coated. So far I'm liking it a lot. This bike is very upgradeable and trail-capable IMO.
    Attached Thumbnails Attached Thumbnails Review of Motobecane FantomDS Sport-silver-bacon.jpg
    Jun 2018
    The first link you gave (to BikesDirect) didn't work.
    I'll be honest, I have no idea if a SRAM Eagle NX 12-speed would work on the stock hub. I'd recommend taking the bike (or at least the rear wheel) into your LBS and ask them if you have an upgrade path to 1x12.
    I order a lot of stuff off AliExpress, but I don't know if I'd order a drivetrain. The reason is if you have a problem, there's almost nothing you can do about it. The NX derailleur I recently got (from Amazon) was damaged--I got a refund and had a new one at my door in 2 days. That's just my .02 though. I love AliExpress...my new Shimano brakes were a steal, and I've got a few other parts currently on the way. I'd just be antsy about expensive and delicate stuff. Oh--in case you're unaware, AliExpress does have a way to sort for "ships from USA"--I was unaware of this until recently when I purchased some watchbands. I'd at least check Amazon & Ebay as well--you might find some good deals domestically.
    Jun 2018
    Holy crap! How the hell did you strip the bike? It looks dramatically different! That "Motobacon" lettering is hilarious.
    What size is your bike? Is it a 29"er?
    Give me a rundown of your mods from stock. I scrolled up and read your previous posts, but I'd like to hear your current take on the value of each mod.
    Jul 2019
    well I wasn't saying I was going to buy a drivetrain from aliexpress (not yet anyway)
    I was just saying that if they are in fact compatible that is huge exciting news! oh and I fixed my first link so it should work now.
    Apr 2019
    I never really liked the dark silver paint job so I decided to strip it. I was going to powdercoat it white but I like the raw aluminum look for now. I used Klean Strip Premium Stripper. It took 2 applications. I had to scuff the clearcoat with wire wool first. Then I used wet sandpaper grits 320/400/600/800/1000 respectively, to get the black self-etching primer off. I then used a fine scotch brite pad with Fluid Film on it followed by a super fine pad with Mothers Synthetic Wax. When the decals came in I cleaned the downtube with denatured alcohol before applying them. When I had the frame apart I checked the pivot bearings and they felt sticky. Like the balls were square. This is expected as these bearings don't get the full range of movement. I bought a 10 pack of 6903 RS bearings for $17.00 from Walmart.com. I think the Jtech hubs use the same bearings.
    Mine is the 27.5 wheel size with the 16.5 frame. As far as the mods go the only thing left stock are the wheels and hubs. I do like the WTB wheels it came with. So far they are hard to beat. The Deore 1x10 drivetrain has been performing excellently. Shifting is crisp and the addition of a 30T oval AB chainring made a huge difference in climbing. The Zee crankset is rad and I prefer the Hollowtech II BB over the original square tapered. The XT M8000 brakes have been flawless as well. I added XT skewers to replace the stock ones as they have a more solid feel when locking 'em down. The Brand X dropper is awesome and works perfectly every time. I'm loving the Conti Cross King tires on the Florida trails. They give me plenty of traction and they roll pretty fast. I do have a pair of Maxxis Aggressors that Bikesdirect had on sale for $25.00 ea waiting in my closet if the Contis ever wear out lol. Overall I am very happy with the bike and I think I have upgraded all I can. If/when the hubs crap out if I don't rebuild them I may lace up a pair of DT350s.
    Jul 2019
    Just realized I never posted photos of my dropper installed, or my upgraded cockpit(32mm reach, 7* rise stem and 720mm carbon bars) so here you go!
    Aug 2019
    My FantomDS
    Thanks all for this thread. It helped me decide to purchase a FantomDS in August. I bought one from Bike Island. Itís a 27.5 with a 14.5 inch frame. It was described as being new but missing a chain. When it arrived, I was happy to discover that it came with a chain that was described as ďslightly rustedĒ. Easy enough to remedy. This is the bike as I bought it.
    Review of Motobecane FantomDS Sport-72e851e3-50e3-417e-bc71-5a94655042b9.jpg
    Since purchase, Iíve added a KS eTen dropper post and some RockBros pedals, both of which made a big difference. The cost of them brought the total investment to the cost Bikes Direct was asking for the bike alone.
    Review of Motobecane FantomDS Sport-f3b7c9b8-0176-4e89-8f38-1f51a81ae74d.jpg
    Review of Motobecane FantomDS Sport-f09419cd-353f-4d6f-a60f-14c497478aea.jpg
    Review of Motobecane FantomDS Sport-5a54f68b-e067-4c79-9d93-5cc5aaca71a3.jpg
    Iím going to ride the bike as is for awhile before making any further mods. Iíve been exclusively a road cyclist until now, so this mountain biking thing is all new to me.
    Jun 2018
    gsreptar...looks great! I really am curious about why you have a different frame with internal cable routing. I haven't researched it much....do you know if any of the higher end FantomDS bikes come like that? I haven't seen a FantomDS Sport advertised with it.
    fresguy...welcome to the club! I think you'll really enjoy the bike! The great thing is that you'll be able to upgrade components as your budget allows and your ride will only get better.
    Hey, I did notice that you have your dropper cable installed incorrectly. The other end of the cable (with the round connector) goes up with the lever. There is a tiny nut that you fasten on the other end.
    Jul 2019
    I haven't looked I to it either but I have noticed that the 27.5 dont have it but I'm thinking the 29ers do
    Aug 2019
    Thanks for the catch about the cable. I guess I have another project!
    Jul 2019
    Looking at getting a lightly used rockshox monarch rt3 for the same price as a new dnm. What's a man to do?
    Jun 2018
    That should be a good upgrade for you. I assume it's about $80? Just make sure it is 190mm eye-to-eye.
    Although I don't have the DNM, others have said they're great. Also important is that they come with bushings that will work on our bikes. I got a bit lucky with the used shock I bought--it actually came with a variety of bushings. But even if you have to order some bushings, it sounds like you're getting a great deal.
    Jul 2019
    I haven't pulled the trigger yet, I dont know if I have the spare cash but I'm gonna try and make it work
    Jun 2018
    Update 9.5
    I've been pretty busy/lazy and haven't ridden much in the past week, but tonight I took the FantomDS Sport out for a 12 mile ride. This is the first time I've personally taken it out after having completed the drivetrain & brake upgrades. I had a friend take it out on the same course I rode tonight (see Update 9 for details). The course I rode was a mix of single-track and gravel. I live in the Appalachian mountains so my riding always involves hills with a mix of flowy trails, rooted, rocky areas, both gradual and steep climbs (and decents), and some highly technical sections. What follows are my personal impressions.
    First off--holy crap, that drivetrain is perfect. That's not hyperbole. The new SRAM 1x11 system shifted flawlessly throughout the entire ride. It literally never once slipped a gear or had any hiccups whatsoever. Perfect. In fact, it shifted far better than my SRAM GX 1x11 on my Catch 2 (which, in fairness needs to be tuned up). I cannot praise this setup any more. Flawless, capable, and enjoyable are the most accurate ways I can describe it.
    The inexpensive IXF cranks and Deckas chainring continue to be solid performers. Many reviews on YouTube attest to the quality of the IXF cranks (which are Shimano clones). One thing I think it is important to note is that I verified some feedback I got from the guy who test rode the bike a week or so ago--the bike is very slightly lacking in the high-gear. This isn't a drive-train issue as much as it is a chain-ring and terrain issue IMHO. I live in the mountains, and flat riding is pretty darn rare, so the benefit of being able to go 10% faster on flat surfaces means almost nothing. The new SRAM cassette is awesome. However, if you live somewhere with flat terrain, you might consider going with a different size chain ring than I did. Mine is a 32t oval. A 34t, 36t, or even a 38t chainring might work better for you. I'm perfectly happy with this setup.
    The new $33 Shimano M200 brakes also performed perfectly. I have SRAM Level T (a much more expensive model) on my Catch 2. Honestly, I really couldn't tell the difference in XC riding. I'm not saying the $33 Shimanos are as good, only that in XC riding they performed great. I don't want to gush over them like the drivetrain--primarily because my sense is that brakes either perform satisfactorily or they don't (at least in XC riding). I initially had a lot of trouble with the stock mechanical brakes on the bike, but after I got them adjusted they worked fine. I do prefer these hydraulic brakes over the mechanical, however. There seems to be much more smoothness to them. The mechanical brakes didn't have much gradiation (is that the right word?) when you engaged them--meaning when you applied the brakes, they seem to lock the rotor pretty quickly. The hydraulics, on the other hand, seem more responsive to intermediate pressure--i.e. you can lightly apply the brake to slow you down without locking your wheel. You can, of course, fully apply thqe brake and fully lock them. For $33 this upgrade is a no brainer, but not necessarily the most essential (the drivetrain is).
    The Manitou fork and the Fox Float shock ate up the trail just fine. From rock gardens, to roots, to rolling over fallen trees--zero issue. In fact, I can honestly say that the ride seemed just as smooth as on my Catch 2 which has a RockShox Pike and a Monarch RT3. Again, I don't want to oversell this--the suspension on my Catch 2 is far beefier and is a lot more capable--if you ride harder. But for XC riding, The setup on the Motobecane felt awesome.
    The only thing really worth upgrading on my bike at this point are the tires. The stock tires aren't bad, but they're not great for the trails in my area. That said, I'm not planning on getting a new set until I've worn these out more. They work well enough, but I know the bike will perform even better once I throw some beefier rubber on there.
    Final verdict for the bike at this point is A+. The bike performs easily as well as a bike costing $1500. That said, there are still drawbacks to the bike--the hubs limiting the upgrade potential is the only important one I'd note. The bike is also still on the heavy side, but the upgrades have shaved off enough weight that I don't consider this to be a real issue. The frame is well designed and efficient. This bike is more than capable and easily performs as well as, if not better than, new bikes retailing for $1200-$1500.
    Other notes:
    I haven't talked a lot about how the bike fits me personally so now is probably a good time to do so. I purchased this bike for my girlfriend who is 5'7". The frame is 16.5 inches. I'm 5'11" and weigh 190. I have a 30" inseam. I generally ride a large (or 19" frame). This is why I've had other people test the bike for me. However, the bike actually fits me pretty darn well--which really surprises me. I think it probably has more to do with my inseam length than anything...who knows. The dropper post helps a lot with that because it lets me dial-in on the fly. I really wouldn't hesitate to take this bike out on occassion as it really is fun and nimble in a way that my Catch 2 isn't (I run either 27.5+ or 29" wheels on my bike). All of that said, I have discovered some limitations for my size on this 16.5" frame. First, the e-Ten dropper works great, but the 100mm travel isn't quite enough for my full comfort. If I adjust it to drop low for the downhills, then when it is fully up it is still a tad bit short for me to fully extend my legs (maybe 1"). That's a very minor issue, and one I could probably adjust--but a longer travel dropper would be bettuer for me on this bike. I did have some trouble on a steep, extended climb tonight. This trail isn't cut for mtb'ing and goes straight up a mountain. My 5'11" body just couldn't establish a solid center of gravity on that 16.5" frame and I ended up pushing. Now that section gives me hell on my own bike, but I can make it. This is an extreme case, but figured I'd note it. Towards the end of my ride I noticed my quads were aching a bit--not sure why, but I think it's safe to say that the geometry of the smaller frame required different muscle engagement than my regular bike. Again, not a big deal--but when I ride the Motobecane in the future, I'll probably keep it at 15 miles or less of XC.
    Jul 2019
    Good to hear about the sram setup! Can't wait to 1x swap mine and put the dropper on the left. Speaking of cockpits. I am looking for some lock on grips that have slightly thicker grips. I dont like having thin/narrow grips that feel like I have to squeeze to keep from my hand slipping off. Preferably without the crazy patterns or anything. I wish I could remember the name of the bmx grips I used to use. Thick soft/tacky and lasted forever
  67. #67
    Reputation: ilanoray's Avatar
    Apr 2019
    FWIW I am using Specialized Enduro XL lock-on grips. They are comfy for at least 4-hour rides. They didn't break the bank either.
    https://www.specialized.com/us/en/en...=230973-156055
  68. #68
    Jun 2018
    I switched to Ergon GP1s on my bike and really like them. I was a bit skeptical before getting them, but they're perfect. My girlfriend bought the Ergon GP2s for the Motobecane, and I don't care for those much because they restrict my hand placement.
    My only advice on grips is to just buy a well known name-brand pair (like Ergons or ODIs) and don't get some cheap no-name brand off Amazon or Ebay. Name brand grips will only run you from ~$20-$30 and they make a world of difference.I don't trust the reviews for knock-off grips on Amazon--at best they're submitted by people with few miles on them. Brands like ODI, ESI, RaceFace, Ergon, Fifty-Fifty are still relatively inexpensive and have a great reputation with serious cyclists. I'm willing to take a risk with $33 Shimano hydraulic brakes from China, but I'm not willing to do so with grips. Cheap, knock-off grips will generally wear out within a year or just fail.
    Also--make sure to buy lock-on grips. That's a necessity.
  69. #69
    Jul 2019
    ive never really been a fan of the ergonomic, oblong shaped grips. I did find some that
    look like what id like. the ODI Ruffian (non mx) ones are probably the ones!
  70. #70
    Jun 2018
    I won't call this an "update" because it pretty much just echos my previous post on the state of the bike.
    I was so impressed with the way the Motobecane rode on Wednesday, that I decided to forgo riding my own bike today (Sunday) and instead opted for the FantomDS Sport.
    I went out to one of the trail systems that others have tested it before--12 miles of nothing but flowy trails with some solid climbs (and decents) along with a section of rock garden. This particular system is actually 2 connected loops of about 6 miles each--one purpose-built for mountain biking and the other an older, established hiking trail that is open to bikers.
    I've ridden this system a ton of times over the years--it's one of the most popular in my region. Today, the trail was 100% dry and, surprisingly, few riders were out.
    Again, the upgraded Motobecane performed flawlessly. In fact, Strava says I got a PR on my 2nd loop (the old hiking trail loop)?!? That really shocks me as I certainly wasn't pushing it in the least. That side is far less flowy and mostly consists of climbs and decents. I have no explanation why the 27.5 FantomDS Sport outperformed my other bike with either 29" tires or 27.5+ tires.
    Anyway, the FantomDS Frankenbike (it's really not proper to call the upgraded bike 'Sport' at this point) chewed up everything. The suspension floated over everything and didn't cause any pedal-bob at all, the drivetrain was, again, flawless. Not a single slipped-gear, no issues climbing, absolutely nothing I would change. The dropper worked perfectly--I wouldn't be able to really ride the Motobecan were it not for the dropper. my 5'11" body on a 16.5" frame just wouldn't work without the dropper. That said, I was slightly more comfortable over the 12 miles than I was on Wednesday, but there's no denying that as much as I enjoy riding this bike, it's not the right size for me.
    The brakes got a far bigger test today than they did previously. I'm shocked they're performing so damn well. I spent less than $33 on these hydraulic brakes!?! Those cheap AliExpress brakes are a steal. Don't sit on the fence--order some now.
    I guess I should comment on the stock tires as I mentioned previously that they are the one item I still plan on upgrading. The stock tires are still more than adequate, even on the harsher terrain I hit intermittently. I do believe knobbier tires will increase my confidence in tight switchbacks, but I actually haven't had a traction issue to speak of.
    At this point I'm considering writing up a Final Verdict type of report on the bike. As much as I really like the bike, and as much as I've really enjoyed building it up, my feelings are still a bit mixed and I need to sort it out. Basically it boils down to would I recommend this bike, why, and to who. My conflicted feelings stem mostly from the fact that I put a lot of extra money into building out the bike. Before I give my final verdict, I want to add it all up and compare the base FantomDS Sport to something like the Diamondback Atroz 1 and/or some big box bikes with upgrade potential. One thing is undeniable though--the FantomDS Frankenbike is a legit full-suspension mtb that handles great and is a blast to ride.
  71. #71
    Jul 2019
    Contrary to what my LBS says "oh full suspensions bikes start at the 1200-1500 dollar range" man do I dislike that guy
  72. #72
    Jun 2018
    He's not entirely wrong though--and that's why I need to add up how much I spent to get the Frankenbike into the shape it is currently in. Just off the top of my head, I paid $450 for the bike ($550 I think on BD). Then $200 for the new forks, then around $65 for the cranks/chainring/bottom-bracket. Then a wasted $45 for the 8-speed cassette (now retired). Then somewhere around $185 for the new shifter and derailleur and 11 speed cassette. Then $25 for the 11-speed chain. Then there's the $33 hydraulic brakes. That's got me up to $1038 right there and that doesn't even include the labor costs from my LBS to do certain things for me like cut and install the new fork and dial-in my new derailleur correctly. Nor does it include the specialty tools I ended up having to purchase to do the upgrades.
    That's why I really need to contemplate whether I can recommend this to others. And since I got the bike $100 less than Bike Direct's price, I need to see what $550 buys you. It will probably come down to two things: First, if you only have $550 to buy a bike that is upgradable, is the FantomDS Sport the one I recommend. Second, if, like me, you invest more in the bike immediately, would that money be better spent on just buying a stock bike that doesn't require upgrading. It's a tough call, and one that I'm going to ponder.
  73. #73
    Apr 2017
    but don't know if I want to burden my girlfriend with having to refresh wheels with sealant every month or two.
    I know you have already gone tubeless on this bike but I still want to comment on this point. I don't know what your weather is like but I am in the desert of SO Cal, it get's above 100 degrees for weeks on end here and I have been tubeless on my bike, my wife's bike and both my kids bikes for 2 years now. I just refreshed the sealant a couple weeks ago for the first time because it had gotten to the point that I had to add air to my daughters bike every couple days and my rear tire would go limp in a half hour. I did some research and was lead to believe that you do not need to break the tires down and clean them, just add some sealant through the valve stem. I wanted to take a look though so I broke down my tires. Man, what a pain in the ass and completely unnecessary. The sealant had dried like a layer of latex paint evenly coating the rim and tire. I won't be doing that again because it's just a lot of pointless work. I did not brake my kids tires down and just added a few ounces. Both bikes hold air fine.
    The real point for me about your feelings is this. Even if she had to add sealant once every six month, which is what everyone recommends, but I think today's sealant has improved and needs to be refreshed less often, say once a year, it's better than changing a tube on the trail. For me it is not even a discussion because we have goatheads everywhere here and you pretty much ride flat if you're not tubeless. I stopped riding for years until I hard about it because I was changing all the tubes on all the bikes EVERY SINGLE RIDE, even with the old slime tubes. If she has no bike mech skill than changing tubes would really suck for her on the trail.
    I was going to go tubeless but the extra expense, the sealant mess, and having to break down, clean, and reseal them periodically was a turnoff.
    I have found through much reading that all that work is pointless. Get a big syringe with the tube and stem adapter and inject 2 oz every 6 to 12 months. you will wear the tire our before the buildup becomes an issue. If the weight bothers you atop skipping leg day at the gym.
    Contrary to what my LBS says "oh full suspensions bikes start at the 1200-1500 dollar range" man do I dislike that guy.
    1st, you local bike shop is probably a bunch of deuche bags, 3/4 of them are worthless unless you are 100 percent incapable of learning to work on your own bike at all and know nothing about bikes. And then they are really going to take advantage of you.
    2nd, the only reason bikes direct is so inexpensive is they are not paying for a building or a staff like the LBS. They have handful of people running the whole international operation out of a gigantic warehouse in a low cost area. Their economics of scale is impossible for any LBs or even a conventional chain to compete with. A 1200 full sus from any LBS is only suitable for a teenage girl. A grown man will destroy it in a season or two. AS will a grown woman who rides aggressively and definitely a teenage boy who knows how to ride. The suspension and wheels on those 1200 dollar full sus bikes are very bottom end. For 1200 a the LBS you better stick with a hardtail.
  74. #74
    Jul 2019
    Well when I talked to him about swapping cassettes he looked at me and said "I dont think that can be done, I just do this for a living though what do I know. You can't put an 11 speed cassette on a wheel with an 8 speed on it." At which point i walked out because of his condescending attitude.
  75. #75
    Apr 2017
    You pretty much summed up the majority of LBS staff. They are slowly making themselves obsolete. Everything you need to know is available on youtube and these forums. They really need to re embrace the concept of customer service and start looking at their customers as assets that need to be treated well instead of dumb asses that are there to be taken advantage of. Every employee at one of my LBS (the only jsensen usa retail location) is between 16 and 25 years old and is a current or former team member of the local high school cross country team, which means they are all skinsuit snobs that bring the roady attitude to mountainibikng and bring that attitude to work. The other LBS is a 2 man show, everything is 20% markup from amazon and one of the mechs only works on anything shimano and is a total emo asshole. You can smeel the contempt rolling off of him like you are not worthy of being is the same time zone. My local bike shops are why I own close to a thousand bucks in tools that I can only use on bicycles. And I don't even like working on bikes.
  76. #76
    Apr 2017
    I was saying 1200 dollars is not even a good full sus, look at this, just clicke d the add to the right. 1500 dollar hardtail for 5 year olds, WTF!!!!!!!!!!!!!!!
    https://www.trailcraftcycles.com/pro...lue%20Sky%2020
  77. #77
    Jul 2019
    so just to touch on what I mentioned earlier HERE is some reading. according to this,
    on shimano freehubs, the 7/8/9 speed cassettes are actually wider than 10 speed
    and 11 speeds can drop right on, as we all found out. but scroll further down and read what they have to say about sram cassettes. or for those not interested in finding what I did.
    "As of mid-2018, SRAM has introduced NX Eagle groupset, that includes 12 speed cassettes compatible with Shimano (and SRAM) standard freehubs (for 8, 9, or 10 speed cassettes). However, they donít allow for the smallest sprocket to be smaller than 11 teeth."
  78. #78
    Jun 2018
    Okay, so I've put a little thought into whether I'd recommend this bike and the point is kind of moot--BikesDirect seems to have phased this model out and is currently only offering it in a 14.5" at $499 (down from $599). I paid $450 (from BikeIsland). At $600 I can't really recommend the bike. At $500, it's still sketchy, but probably your best bet if, and only if, your initial buy-in budget is limited to $500. If you have more than that you can spend, you will be better off buying either another model from BikesDirect or from someone else. I'll give some examples based on the premise that you want a full-suspension bike.
    BikesDirect carries other brands besides Motobecane, and the only other analog to the FantomDS Sport is a Gravity FSX line. The 29" version might be getting phased out as there are few sizing options currently available. Price for the 27.5" FSX is $500. Downsides to this bike is that the wheels aren't tubeless ready, it doesn't have a tapered headtube, it has a Suntour XCT fork (which I believe is lower spec than the FantomDS' XCM). The only other full-suspension bike that BD currently carries that is sort-of in the same league would be the $900 FantomDS Eagle. It's the same frame as the FantomDS Sport (albeit with internal cable routing), but is upgraded to a 1x12 which saves you probably $250 bucks. It also has hydraulic brakes (same model as the $33 pair I ordered). That's pretty much where the differences end (AFAIK)--virtually identical low-end coil suspension & hubs, although the wheels are tubeless ready.
    Looking elsewhere, you might consider a Diamondback Atroz 1 or Atroz 2. Like Motobecane, their frames are also made by Kinesis. I'll be using corporate pricing at Diamondback which you won't see/get unless you set up a corporate account--doing this is an open-secret (easy to find info if you Google it) and Diamondback is cool with it.
    Upfront, the Diamondback Atroz 1 & 2 lack tubeless-ready wheels and they also have 9mm skewers so you're going to be limited just like with the FantomDS sub-$1000 bikes. The Atroz 1 sells for $560 and is spec'd much like the FantomDS Sport (coil suspension, mechanical disc brakes). It has a straight headtube. Seeing that the FantomDS Sport had a tapered headtube but a straight fork and hubs that were incompatible with most tapered forks, I'm not too negative about this.
    The Atroz 2 is far more enticing at $719. It is a 1x9, has a tapered headtube, hydraulic brakes (same as the $33 set I bought) and has a Suntour Raidon-R Air Shock. It also comes with a chain guide and has internal routing for a dropper. The front hub looks like it might be an axle, although the specs aren't clear. If so, that would be a pretty big deal IMHO. At $180 less than the Motobecane FantomDS Eagle, the Atroz 2 is pretty enticing.
    Ultimately, trying to get a full-suspension bike under $1000 is going to require compromises--some of which will really limit you going forward. I spent well over $1000 (the first season) on my $450 FantomDS Sport; I don't recommend that at all. You can easily find bikes (e.g. the Marin Hawk Hill) on sale at Chain Reaction Cycles for probably about what I put into the FantomDS Sport. Heck, I could have purchased a HAL5 bike. If your budget is under $800, get the Atroz 2. If your budget is less than that, I'd probably wait and save some more money or look at used bikes.
  79. #79
    Reputation: metalskool's Avatar
    Feb 2019
    As for cheap full sussers- What about Polygon Bikes? I just watched a GMBN video where they showed 2 bikes at the Eurobike and one was 1200 & the other 800 ?
  80. #80
    Jun 2018
    Quote Originally Posted by metalskool View Post
    Pretty interesting and thanks for sharing that! I've never heard of Polygon bikes before, but I took a look at their website and watched a few videos on YouTube. Their only full-suspension bike under $1000 is the Siskiu D5. Although the website doesn't outright say it, SingleTracks has an article that states it is a 2x9. It seems like a legit bike, but a couple of things trouble me. First is the website avoids giving a lot of important specs--it has scant info about the wheels/hubs and literally nothing about the front derailleur or BB type. The other thing that makes me skittish is Polygon bikes don't seem to have much presence in North America (maybe I'm wrong). Every video I found on the Siskiu D5 was from a non-English speaking country.
    The D5 seems similar to the Atroz 2 which can be purchased at $719 with the corporate discount. AND Diamondback will actually ship the bike to a local dealer and have it professionally assembled for you for free. Personally, I'd probably go with the DB because it is already setup as a 1x, has a tapered headtube, and is from a manufacturer with a large US presence.
    This discussion has now gone beyond the hypothetical for me, as my girlfriend (who I purchased the FantomDS Sport) called me last night asking about buying another mountain bike so she can ride (she lives across the country from me over half the year) out in ABQ. She wants to keep the price less than $1000 so now I'm struggling with giving her a recommendation. TBH, I'm leaning towards a hardtail because it is so tough to get a full suspension at this price-point. But I'm going to start looking to see what all I can find.
  81. #81
    Jun 2018
    Off-topic post, but I had recently mentioned that I was in the market for an additional bike for my girlfriend (besides the Motobecane FantomDS). She lives part of the year in the Southwest so she wanted a bike to ride while out there.
    I learned quite a bit by my experience building up the FantomDS. I went into that project primarily wanting to buy an inexpensive bike that could take upgrades. Overall, I'm very satisfied with the result. That said, when the opportunity presented itself to purchase yet another bike, I needed to adjust-fire a bit because I wouldn't be there to do upgrades--the bike needed to be 1) reasonably priced, 2) need fewer upgrades than the FantomDS Sport, and 3) be available for me to have it shipped to her.
    I immediately started checking BikesDirect, BikeIsland, and Bikeshopwarehouse to see what decent options they had. To be honest, I couldn't find anything that fit that bill very well under $1000.
    I then went to Diamondback. I was tempted by the Atroz 2 which I could get for ~$719 with the corporate discount. But that bike has a straight headtube. It is a 1x9 and has an air shock in the rear (coil up front). That bike was in stock when I was shopping, but now is OOS. I wasn't really wanting to get another dual-suspension bike for her since she's got the FantomDS Sport.
    I then came across the Diamondback Mason 1 which is a 27.5+ bike. It ticked off all my boxes...Boost spacing front & back, tapered headtube, 1x...but alas, at $639 it was too popular and OOS. I contacted Diamondback and they confirmed it won't be restocked in 2019.
    On a whim, I visited Raleigh bikes. Raleigh is now a sister-company to Diamondback and literally 1 minute of Googling gave me the info to set up a corporate account with them. If you're in the market to buy a hardtail, you should check them out. They had 2 models which really interested me--the Tokul 2 and Tokul 3. The Tokul 2 was only $560. It has a 1x9, hydraulic brakes but unlike the Tokul 3 (which sells for $900) it doesn't have a tapered headtube. Still, it's a beautiful looking bike IMHO.
    I checked a bunch of sites & bikes out, but I ended up going to Chain Reaction Cycles. My friend ordered a Marin B-17 from them last month at a killer price and I know they have great closeout deals. I ended up buying the Felt Doctrine 6 for $868 delivered. It's a carbon 29'er with Boost spacing in the rear. It's a 2x11, has hydraulic brakes, tubeless ready wheels, internal cable routing, an air fork with remote lockout, and a tapered headtube. The only real downside is that the front hub is 100mm (9mm skewer) but at least we've got a decent upgrade path.
    I know this post is really off-topic from my thread, but I wanted to provide some insight into how my experience building up the Motobecane impacted my next purchase. I learned quite a bit from the wrenching I did on the FantomDS, but the cost of the upgrades adds up quickly. If your budget absolutely restricts you from purchasing a bike with higher-end features, then doing what I did with the Motobecane is both fun and practical. But if your budget allows, shop around for sales & closeouts. $860 for a feature-packed carbon bike that requires almost no upgrades out of the box made the most sense this time. All that said--the build I did with the FantomDS is still spectacular--that bike rides & handles like a dream and I enjoyed the project immensely.
  82. #82
    Jul 2019
    so just wanted to put this out there. if you buy CHEAP lock on grips from say aliexpress be sure to use a tap to chase the threads before install. I broke a bolt off in one of the locking collars before it ever tightened. now that the PSA is over does anyone have A single locking collar theyd part with? lol
    nevermind, ordered one from aliexpress for $0.30 LOL and ill be chasing threads before I install it obviously.
  83. #83
    Jun 2018
    If anybody is looking for tires for their Motobecane, BikesDirect has an awesome sale on currently. They've got Maxxis Minion High Roller II's for $30 each. They had Maxxis Minion DHF 27.5 x 2.3 EXO TR 3C MaxTerra for the same price, but they sold out of those (I got 2, already delivered). Jump on this if you need some new tires.
  84. #84
    Jul 2019
    Got a rockshox monarch coming, also pulled the trigger on a fork from aliexpress. I know how most of you will feel but it was 96 bucks for a 29er air fork with tapered steerer tube, lockout, rebound adjustment, and 9mm qr. Ordered some stans sealant to go tubeless and a cane creek sealed headset too.
  85. #85
    Jun 2018
    Can you post a link to the fork you ordered? Just curious.
    Going tubeless is great. The FantomDS rims work great with 1" gorilla tape--it's a helluva lot cheaper than buying tape elsewhere. If you've never done it before, just watch videos, ask questions here, and be prepared for air loss for the first few days.
  86. #86
    Jul 2019
    https://s.click.aliexpress.com/e/pLh8qZ7i
    This one here. Thanks I'm sure I'll get it.
  87. #87
    Jun 2018
    Interesting. I looked at those forks myself previously.
    If you haven't purchased yet, I'd highly recommend you check out Suntour Epixicon forks on AliExpress instead (not necessarily from that vendor).
    I went down a rabbithole researching air forks and to make a long story short, a Suntour rep confirmed that these really inexpensive Epixicons are legit Asian versions of the fork. The difference is the air cartridge--the Asian versions (IIRC) aren't user-servicable, but they can easily be converted when the time comes.
    Also, in case you're unaware, Suntour has an upgrade program in the US where they'll sell you a higher-end fork at a discount. There's info on their website. I looked into it, but although the discounts were pretty good, I was happier with the Markhor that I purchased.
  88. #88
    Jul 2019
    I did already purchase. We will see I guess haha
  89. #89
    Jul 2019
    just noticed the headset I ordered may not work. its a cane creek is3 e2 and apparently is designed to be used in frames in which headset cups aren't used? well that sucks, good thing amazon has a great return policy
  90. #90
    Jul 2019
    Anyone know where to get bushings for this thing? Lol they're almost as much as I paid for the shock!
  91. #91
    Jun 2018
    A quick search online shows lots of options, but it looks like you need to know the specific size bushings you're looking for. My advice is to talk to your LBS--I bet they have a ton of old bushings laying around.
  92. #92
    Jul 2019
    I contacted the guy I bought the shock from and he's going to see if he has some, and I contacted bikesdirect.com to see if they would sell me a set since the fantom ds comp has a rockshox on it. Of none of those pan out I'll order some from Amazon or something
  93. #93
    Jul 2019
    so bikesdirect.com wasn't any help they said used the old bushings (wrong/different size altogether). however the guys over at bigboxbikes.com were helpful enough to give me the sram/rockshox part number for the 8x22mm bushings needed!
    710845622090 for those of you that need/want to know. just waiting to hear back from the gentleman I bought the shock from to see if he has them by chance before ordering them for ~13$ each!
  94. #94
    Jul 2019
    Finally got the monarch mounted, filled, just havent turned rebound damping yet. For my 185ish lbs it took roughly 200psi to reach 30% sag. your results may vary of course. Also got this work stand on aliexpress for less than 40 bucks and am blown away at the quality
  95. #95
    Jul 2019
    Bike hack! If you carry a pump on your bike, and it has a presta/Schrader valve adapter, a valve stem tool will fit snugly into the adapter! Also keeps mud and crap from getting into that adapter on those wetter rides
  96. #96
    Jun 2018
    Glad to see that you got it fitted. I was a bit surprised that after changing the stock coil shock on mine to an air Fox Float that the difference wasn't dramatic. The weight savings was dramatic, but the cheap stock suspension--although certainly not ideal--was actually not as bad as I'd feared.
  97. #97
    Jul 2019
    Mine was making an audible clunk that you could also feel in its first quarter inch of travel so the monarch has made life quite a bit better.
  98. #98
    Jul 2019
    got my cheap Chinese fork finally. cut the steerer tube down today and will install the star nut tomorrow when the driver shows up. (lbs wanted $15 to drive a star nut, I cant stand that place)
  99. #99
    Jul 2019
    All done and installed. Total weight is down to 32lbs
  100. #100
    Jun 2018
    Looks good. How is that fork? Test that sucker out and give us a review!
    Also, like some of you, I got an email advertisement from BD today and see that the FantomDS Sport is back. With just a cursory look through the specs, I can't spot anything that is changed. The photo shows internal routing, so I'm assuming that's what GSREPTAR got.
    They're charging $600 for the DS Sport now. I'm not really upbeat about that. What do you guys think?
  101. #101
    Jul 2019
    I got a quick ride around some urban stuff and so far it feels great. not springy and harsh like the suntour was. the lockout knob is also like a bound/rebound knob ranging from fully open (fast) to locked out. on the recommended pressure setting I found I had to run it just 2 or 3 (out of 7) clicks from locked out or it felt a bit too soft for anything aggressive. more to come once I can get it out on a trail!
  102. #102
    Oct 2019
    This model just doesn't make sense financially. Most entry level riders would be better off with a model like the Giant Stance or Vitus Mythique, both of which start at $1500 with hydraulic brakes and far superior suspension spec.
    The giant of course is shop supported, which could make a huge difference. The vitus isn't, but the spec is probably even better.
    I was window shopping motobecane's $2K fullsus with SLX, but they can't even be bothered to put up a geometry chart for their current model! BD is a very strange company. Bare bones to say the least.
  103. #103
    Feb 2019
    Every so often someone who doesn't even own a Moto gets on these forums only to troll. Usually you can click on their profile and look at their current posts and see they quite often are posting controversies in other threads. Lastly, rep points sometimes tell a story as well.
    Edit: And now I see a recent poster/troll below is banned.
  104. #104
    Jul 2019
    1500? Even after I add hydro brakes I'll be under a grand for something I'm sure is comparable/equivalent/competent for under 1000.
  105. #105
    Jul 2019
    the Sram cranks I bought came with a steel 30t 3mm offset (boost) chainring. if anyone wants it hit me up to work out a deal!
  106. #106
    Jul 2019
    Got my sram crankset installed and chain shortened (may add a link or two back in) and my bday present from my girlfriend installed, a matching rockbros seat! Its coming together I think!
  107. #107
    Jun 2018
    Looks good. Are you still liking your fork? Did you swap over to tubeless? It looks like you're still rocking the original derailleur....are you planning on upgrading that next?
  108. #108
    Jul 2019
    Still like the fork, did go tubeless, and yes groupset is the next upgrade lol sram eagle is the plan
  109. #109
    Jun 2018
    Just wanted to provide an update because this Motobecane has been on my mind a LOT recently. As I've previously discussed, the Moto isn't my bike--I bought it and built it up for my girlfriend. She's 5'7" and I'm 5'11." I can ride this bike, but it isn't a great fit.
    Currently my KS Lev Integra on my own bike has been broken. I've had a lot of problems since I've had that dropper (~2.5 years). When it works, it is great...but when it is broken...I can't ride that bike. That dropper cost as much as the Motobecane I purchased (not including the upgrades).
    So during this time whilst my own bike(s) are out of commission, I've resorted to riding the Motobecane. And I've been riding A LOT because of this COVID-19 shutdown.
    Here are the takeaways....I am amazed at how well this Motobecane performs. The shifting is far, far better than on my bike (which has a GX drivetrain as opposed to the NX I put on the Motobecane). I can't stress this enough...shifting remains perfect and virtually silent. The super cheap cranks, bottom bracket, and chainring that I used are likewise performing flawlessly. If you're on the fence about those inexpensive Chinese components--don't be. I've got hundreds of miles on them at this point and they have given me zero issues.
    The Manitou Markhor fork, likewise, is great. This is sort of to be expected, but I just wanted to throw that out. Now, I'm not suggesting that the Markhor is the most versatile fork on the market, but for basic XC riding, I consider it the best ~$200 air fork out there.
    Okay, that's pretty much all the positives. The one negative that I notice is the stiffness. Specifically, the old-school skewers are noticeably not as stiff as my robust boost axles. Again, this is to be expected. I live & ride in the mountains so cornering downhill I notice it a lot. It isn't a deal-breaker, but I do note less confidence. Part of that might be due to me still running the stock tires, which aren't aggressive. I've got a set of brand new Maxxis Minions for the bike, but haven't put them on because I want to wear out the stock tires first. That should improve confidence quite a bit, but it won't do anything about the stiffness.
    So the question still remains on whether or not I would recommend this bike, and that answer remains complicated. Insofar as the bike can be upgraded to a tank of a XC bike, then hell yes. But the question ultimately hinges on the price you pay. I got mine cheap from Bike Island, but Bikes Direct sells these things at a much higher price--and at that point you're still smart to look at other stuff (like the DB Atroz or various hardtails) or buy used. If somebody stumbles on this thread who is thinking about buying this bike used (cheap) then jump on it if you're willing to do the upgrades.
  110. #110
    May 2019
    Hello! I'm looking to upgrade the drivetrain on my DS Fantom sport as well. What size components should I get. Looking to go from 3 x 8 to 1 x 11. Any thoughts guys?
  111. #111
    Jun 2018
    Quote Originally Posted by Sinfonian76 View Post
    I know my write-up is pretty long, but ultimately I went with a SRAM NX 1x11 drivetrain and it continues to be flawless. It is the less expensive version of the SRAM GX (which I also have on 2 other bikes). Honestly, the NX is every bit as good. None of my bikes have Shimano drivetrains so I can't recommend anything as it pertains to that brand, but the SRAM NX has been a champ.
  112. #112
    Jun 2018
    @GSREPTAR... Nice looking bike!
    @Forbin.... Super cool write up! I spent an hour or so reading through at work a couple nights ago.
  113. #113
    Jun 2018
    Quote Originally Posted by hrdrokn View Post
    Hope you found it helpful. I know it is long....probably too long. There's just so little information about Motobecane bikes available, I wanted to go into detail so that when people were googling this bike it might pop up in the search results. If you have any questions about my build, please just ask. I still really enjoy the bike and have nothing but positive things to say about it. I've been loaning it out quite a bit recently on group rides and everybody who rides it has positive things to say.
  114. #114
    Jul 2019
    Thanks man, now that its drying out here in the pnw maybe I'll get to ride it
  115. #115
    Jun 2020
    Weight?
    Thanks for doing this excellent review / build tracker!
    What is the final weight on the bike?
  116. #116
    Jun 2018
    Quote Originally Posted by CheapSkate View Post
    I'm not sure...I can't remember if I weighed it after all was said and done. If I did, I would have put it in one of my long-winded updates. I'll try to remember to drag a scale out and check.
    I haven't gone back and re-read this thread in a long time, but I learned quite a bit building this bike up. I went into it with basic skills, but this project gave me a lot more confidence. I ended up building a carbon bike with a frame I sourced directly from China earlier this year. I don't know if I would have been as comfortable doing that if it hadn't been for my work on the Motobecane.
  117. #117
    Jun 2020
    Quote Originally Posted by Forbin View Post
    Hi, could you pls elaborate about that frame? is it a BXT frame by any chance? which one? did you do any research of which ones are worth getting?
    i saw quite a bit of negative reviews about them - people say they - almost all of them - eventually develop cracks, due to the way how those cheaper carbon frames are manufactured.
    PS. thanks for the review - it was extremely helpful to see, as i tried to decide if it was worth paying $900 for the bikedirect DS Eagle. i ride a (very) old stumpjumper - and just curious to try out a full suspension bike, but, still not sure if it`s worth the effort.
    I was looking at something like that, but, at this price it seems too dangerous to experiment.
    https://www.aliexpress.com/item/3283...4%239976%23242
  118. #118
    Jun 2018
    Quote Originally Posted by utkinpaul View Post
    I purchased the frame from Ican. I've been very happy with it, although I did learn quite a few things. Most importantly, make sure you order a rear axle and extra derailleur hangers when you purchase the bike. If I had it to do over again, I would have had them paint the frame too. I've seen the BXT frames and considered them, but opted for the Ican instead. Mine is a hardtail. I might end up ordering the Santa Cruz Hightower clone in the group buy over at Chinertown. If you're unfamiliar with that forum, just google it. It's the best resource I've found for folks interested in Chinese carbon frames.
    As to you buying a Motobecane DS, if you get the higher end versions that already have an air fork and 1x drivetrain, you'll probably be happy. I did see that they're selling what appears to be the same frame also under the Gravity brand for 2021 (preorders).
  119. #119
    Jun 2020
    Yeah, I looked at all that again, tried to price out the build with carbon, then with aluminum frame, and just gave up - too much effort for my mediocre skills.
    I ordered this for $1499 - I think it has overall $300 max over comparable build with aliexpress parts. Hope it will work OK. Will see
    SRAM Eagle Full Suspension 29er Mountain Bikes Save Up to 60% Off 29er 140mmTravel All Mountain SRAM Eagle 1x12 , 2021 Motobecane HAL29 Comp Eagle LTD 1X12 29er Full Suspension Mountain Bikes SRAM Eagle 1x12 Speed Shimano Hydraulic Disc Brakes Rocksh
  120. #120
    Jul 2020
    Hi all, new here to this forum. I too am looking at buying a new mtn bike. My last one was a Trek 6000 that i'm giving to my kid. Shortage of bikes and huge price ranges, someone referred me to look at bikesdirect and at Motobecane bikes. As I've been reading and researching this and other sites about these bikes, there's just not enough info out there on them and hard to make a decision on whether to buy these bikes or spend more $$$ on known brands.
    With that being said, i did a comparison on Motobecane Fantom DS Eagle SX pro build ($1200) (Save up to 60% off new Mountain Bikes - MTB - Motobecane Fantom 2729DS Disc brakes, Tubeless Compatible Rims) to a Trek Top Fuel 7 SX ($2700). After comparing the parts and price.... IMO the Motobecane seems to be a far better buy! Per my research it seems like a no brainer, but not knowing much about Motobecane, just hard to pull the trigger.
    Reading this posts, you guys seem to have this brand nailed down. Any help, suggestions, recommendations would be much appreciated!!!
    Thank you in advance and thx for the add.
  121. #121
    Jun 2020
    That frame does not let you to mount a water bottle. As silly as a reason - for me it is a deal breaker - i need my water on a trail and do not want a frame that will remind me of that every time i ride it. I looked initially at those frames also, and decided to revert to hal29 which looks like a knock-off from trek fuel ex type of bikes, i think - rear shock is set vertically and uses a rocker link. i think it is a superior design.
    realistically i do not know of any other way to get a bike for a reasonable price other than to order all parts from aliexpress directly, or use companies like bikesdirect or similar - if 'similar' even exists. i order from aliexpress from time to time, and so far for electrical components and drone parts success level is somewhat around 60% - with returns or exchanges virtually almost impossible - they really do not have a customer service concept there... so, it is what it is, a gamble - but i think with this bikedirect success probability is a bit higher. their team responds to emails sometimes - i sent a couple, but, they do not seem to be very friendly to me.
  122. #122
    Jul 2020
    Thx utkinpaul - too looked at the hal29 in your previous post. Only issue is that bike frame does not come in an XL size. I'm 6'4" - 6'5".
    Other than the water bottle mount, see any other components or frame setup (rear suspension setup - vertical vs horizontal) that i should consider? Is the Motobecane Fantom DS Eagle SX Pro solid/good buy?
    My idea is that I would get a bike that I wouldn't have to upgrade (famous last words i know. I have a jeep wrangler - lol) and I'll be ready to hit the trails with competent components.
    Again thank you!!!
  123. #123
    Jun 2020
    sorry, i am not that proficient in frames design to respond to that.
    Eagle SX - if you google it - suffers from the plastic in the derailleur - it may snap, so, most folks replace it with GX - a $125 part. Some folks say that shimano deore m8100 or m7100 shifts way better under load.
    i am overall hesitant to pay too much for those builds from this retailer - so, it probably would be a common sense approach to spend as much as you can afford to write off and deal with subsequent upgrades later.
    i myself ordered a non-boost frame - some say it is not a good idea, as 142mm hub gets obsolete. but, i think, for my use and life it will be just fine. rest of those parts are difficult to judge - like sport auto shocks can go from $1k to $20k per set - with bikes it is a same way, but, one has to be realistic on what will be a point of a diminishing return per $ investment there - like, i run jrz rs two coilovers on my car and are perfectly happy. some other folks prey by coilovers with external canisters, and some put in moton set with remote controls - i do not have any of them and race just fine for 5 years now, so, go figure. there is always something better and more expensive out there.
    if you are ok with pricepoint of $1.5k and late september delivery - that one seems to have 52cm option
    http://www.bikesdirect.com/products/...tain-bikes.htm
    it is hal29 with boost hub and sram nx - that is way better than SX, no need to upgrade derailleur for safety reasons.
    i wanted a bike in august - hopefully, so, got a cheaper one.
    others for $2k and $2.4k frankly get me quite out of my comfort zone money wise, your mileage may vary. i did not want to risk more than a $1.5k on this toy.
    PS. quickly looking at parts for required keywords - look for those - ROCKSHOX , DROPPER POST, Tubeless Compatible.
    RockShox is a good brand and will be only used on bikes of more or less proper builds, rest of how they toss other components is difficult to judge. i tried to put a list of comparable items at aliexpress and when i get shipping added it went over the price of the bikedirect builds, so, they must cheat somewhere to get their margin but i am not good enough to see where they cut corners. probably, it is there, but, considering price of the new TREK bike - i better get this mongrel for $1.5k - i know it will be more than enough for me.
  124. #124
    Jul 2020
    thanks for the info!
  125. #125
    Jun 2020
    deleted
  126. #126
    Jul 2020
    Quote Originally Posted by mtnbiker3994 View Post
    I do not have a MB mountain bike, but did just get a gravel bike. I love my new bike. The only wild card is the frame geometry so that it will fit you. Without being able to try before you buy it is a little more challenging. However, I think that if you pick a frame size with the correct stand over height you will be ok as long as you understand how to fit the bike to you with seat position and maybe a stem length change. Same factors in play if you buy from LBS, but you are more on your own with a MB purchase. If you are handy and do some research you will be fine. The components are exactly the same as the big names and from what I can tell the frames are plenty good. As you have seen you can get much better components for the same money with MB or same components for much less.
    I would have a MB mountain bike right now if they had any in stock. Went with an Alaskan fat bike from Framed Bikes. 3 weeks for the build, but that is faster than MB right now.
    https://www.framedbikes.com/collecti...bike-27-5-2020
    Sent from my SM-A505U using Tapatalk
  1. Replies: 0
    Last Post: 04-03-2019, 06:16 PM
  2. Just bought me a fantomDS x4
    By thunder in forum Motobecane
    Last Post: 04-30-2017, 08:47 PM
  3. Replies: 0
    Last Post: 10-30-2014, 12:11 AM
  4. Replies: 55
    Last Post: 12-22-2012, 08:45 PM
  5. Replies: 7
    Last Post: 06-11-2011, 02:14 PM
Members who have read this thread: 41
