Pedal size on 600HT- Mtbr.com
Results 1 to 6 of 6
    Pedal size on 600HT
    Hi everyone,
    I recently purchased a 2010 Motobecane 600 HT through my local classifieds for $350, it only having been used once. It has these cruddy "ATB Beartrap platform" pedals, and I've torn up my shins a few times while riding.
    It is time for new pedals, and all the bikes on Moto's website list 9/16" pedals, but not for the 400/500/600/700 HT - they just say "ATB Beartrap platform."
    Does anyone know from experience if these are also 9/16" or are they 1/2"?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    They are 9/16".
    By the way, I'm buying Diamondback Sound Pedals 9/16" from Amazon as replacements, assuming 9/16" is the right size. But then what size pedal wrench do I need? 15mm or 9/16"? I hope someone knows and can help me.
    Oct 2007
    1/2' pedals are for one piece cranks. All modern 3 piece cranks (many are now 2 piece though) use 9/16". You need a 15mm wrench to actually put them on or remove them. It seems a little counter intuitive I know. Also don't forget that the non-drive side crank uses reverse threads.
    2020 Canyon Neuron 9.0 LTD
    2015 KHS Sixfifty Team
    2019 Salsa Warbird
    2019 Canyon Endurace
    1987 Haro RS1
    Is a pedal wrench generally the only way to remove and install pedals?
    Oct 2007
    Quote Originally Posted by akamarcus View Post
    A regular 15mm wrench normally works well, but a good pedal wrench does work better. My pedals all can be removed with allen wrenches, which I find much better than a wrench.
    2019 Salsa Warbird
    1987 Haro RS1
  1. pedal size?
    By JellyLegs in forum Beginner's Corner
    Last Post: 05-23-2011, 06:24 PM
  2. What pedal size?
    By tmc13 in forum Cannondale
    Last Post: 03-10-2010, 09:17 AM
  3. 600HT Frame Size - 33 inch inseam
    By subigo in forum Motobecane
    Last Post: 09-17-2009, 07:22 PM
  4. pedal to crank tap size?
    By calgarydave in forum Tooltime
    Last Post: 06-03-2004, 01:37 PM
  5. Pedal thread size?
    By 2big2ride in forum Singlespeed
    Last Post: 04-19-2004, 02:58 PM
