Motobecane Outcast Rear brake adapter? for tabless- Mtbr.com
Results 1 to 9 of 9
    I have a Motobecane outcast. I'm not sure what year the frame is, but it has horizontal dropouts, are there any disc brake adapters for this frame? i've been looking but cant find anything
    thanks for your help
    Plays with tools
    Reputation: customfab's Avatar
    call bikes direct I'm sure they can help you
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    what color is it? if its the gold/bronze one you will probably have the get that a2z adapter
    "If women don't find handsome , they should at least find you handy."-Red Green
    thats it
    Uploaded with ImageShack.us
    Reputation: boomn's Avatar
    that's a disc only rear wheel, isn't it?
    Normally I would recommended with those potentially problematic disc adapters because the majority of your potential braking power is in the front wheel, so a front disc and v rear will get you most of the way there.
    SuperClyde
    a2z works
    I'm using an a2z adapter on my tabless frame and it works just fine. Be prepared to do a lot of adjusting to get caliper aligned right, but once you do, it works.
    Would the A2Z DM-UNI Frame Adapter work on my frame? (in the pic up there)
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    http://2btherapy.com/bikes/brake-therapy-conversion-kit
    canti to disc conversion 149 smackers plus the wheel build if needed. I would contact them or alternatively search out a new cheap singlespeed compliant frame and do a swap. Might cost the same anyway.
    MTBR Posting Guidelines
    calories>electrons
    Reputation: frankenmike's Avatar
    The new outcast has disc sliding dropouts, BTW. Bikeisland sells just the frame.
    Missing the Zunis...
