How to remove decal from Fantom Pro 29er?- Mtbr.com
Results 1 to 9 of 9
    Anyone know how to remove the painted on frame decals on the fantom pro 29er? I know you can't just peel them off. Thanks for your help in advance.
    Reputation: CarolinaLL6's Avatar
    Mike
    2011 Moto Fly Pro
    They're talking about ti frames in the link. How about a frame that is painted? If you use paint removal stuff for the lettering won't it also remove the frame paint?
    Reputation: Slee_Stack's Avatar
    Aren't the Ti frames clear coated? In other words....painted?
    If you mess it up, you can always powder coat it for about $100.
    Depends how important destickering is to you.
    Blowtorch would work
    Blowtorch would work.
    A more gentle approach would involve soaking some paper towels in acetone, wrap them around the tube, get your trusty duct tape and wrap it. Let it set for an hour and the decals ought to start to fester and puss, just like that future trail rash battle scar on your forearm that you'll get from riding your fine new steed.
    Wipe it with the towel. Rinse. Repeat.
    Maybe the towel wrap needs to stay on overnight.
    dunno, maybe try a 50 percent solution of acetone with water for the first try, just to be really gentle.
    -c
    Oct 2007
    The decals are under a clear coat, I assume a clear powder coat. The only safe way to take them off is to slowly sand off the clear coat over the decals, and then remove them once the clear is gone. But then you would need to re-clear those sections if you want the paint to look okay. You could try the acetone method, but I don't know if acetone can remove a powder coat clear. You could also try some diluted paint stripper and try to only strip off the clear without damaging the color coat.
    None of the methods are paticualrly easy, so unless you are dead set on not having decals, its probably better to just leave them.
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Jun 2010
    Acetone is a pretty strong solvent so you'll want to be careful that you don't dissolve too much. Also, you may want to wear latex gloves when you handle the acetone.
    newfydog
    Mine were all scraped up so I Scotchbrighted them off. Left the tubes a bit dull, and well, looking like titanium.
