which holes equal 3/4/5 in of travel on Fantom DS frames?- Mtbr.com
    Which hole is equal to the following settings of travel in the rear?
    Back hole (closest to rear tire)... Is this the 3" or 5" hole?
    Middle hole: 4 inches of travel
    Front hole (closest to front tire)... Is this the 3" or 5" hole?
    Reputation: broz's Avatar
    Feb 2007
    whichever compresses the throw most at full-extension/zero-sag is 3". I'm guessing the front most is 3".
    The back hole (closest to rear tire) is the 5" hole. If you think about the rocker linkage as a see-saw, shortening the length on one side increases the leverage ratio and reduces the amount of travel on that side relative to the fixed side.
    I find that the additional leverage in the 5" configuration tends to overwhelm the preset pedaling platform on my Monarch 3.3 too easily, making for a bouncy ride even with increased pressure. A shock with a firmer platform, or adjustable platform may work better for our frames in 5" if you like to hammer uphill.
    YMMV.
    Ok, I was thinking the back hole was the 5" but just wanted to make sure
