Front Derailleur Size?- Mtbr.com
    OK, so I shipped my Fantom29er to my little brother in the Air Force in Japan...I had it built up as a single speed, but he wanted gears, so I put it together with what I had...everything works but the Front Derailleur is a POS...and I cant remember exactly what came on it..
    Best I can remember it is a 31.8 size and I need Top Pull, bottom swing?
    Any help would be much appreciated...
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    I believe that you are correct .
    thanks!
    Jan 2009
    Is that the same one for the Fantom DS series? I need to replace mine as well.
