Which frame is better, Fantom 29 or Cliff 29?- Mtbr.com
Results 1 to 2 of 2
    Is there an obvious better frame between the Motobecane Fantom PRO 29er and the Windsor Cliff PRO 29er?
    Fantom:
    MOTO29X Aluminum with TrailTuned PowerStay Design, DualProfile Downtube with reinforced Gusset, replaceable rear derailleur hanger, 2x H2O bosses
    http://www.bikesdirect.com/products/...om29pro_08.htm
    Cliff:
    Altair 2 custom butted aluminum with PowerSection down tube, top tube/seat tube gusset, Hydro-formed top and down tube, Integrated head tube, double water bottle mounts. Rear triangle is Altair 2, custom tapered 7005 aluminum with Edge S-bend MonoStay, Cold forged dropout with CNC'D disc mount and replaceable hanger
    http://www.bikesdirect.com/products/...cliff29pro.htm
    Nov 2008
    You probably know, but Cycle Spectrum in Houston (there are four stores) generally stocks some of the Fantom29ers. If you wait a couple of weeks, I should have a Windsor 29 Team Size Large to check out as well.
    I've heard pretty good comments about the Fuji-based Windsor frame. The Fuji is pretty well reviewed. The Windsor is reportedly identical except for the non-hydroformed downtube.
    With regard to the Fuji Tahoe 29 Pro, which I rode at Performance Bikes in size Medium (they had a really great price, but I thought it was too small, and I wanted the Team/SL), it is supposedly a fairly compliant frame as far as aluminum frames go. I saw it described as less harsh that the steel GT Peace 9r Multi, which really liked and almost bought.
    Bob
