Forks RockShox on the HALx 2018- Mtbr.com
Results 1 to 3 of 3
    Reputation: biked2school's Avatar
    Aug 2017
    There are quite a few different options when looking at choosing a new HALx and even more options on forks.
    The RockShox site is very good in spelling out the different technologies/features for each line/model of their forks.
    https://www.sram.com/rockshox/family...sfwufvult7a8qk
    This article is helpful and educational as well
    https://www.bikerumor.com/2017/04/13...-yari-updates/
    I like the Revelation RC 160mm with 35mm stanchions for added stiffness. It doesn't come with remote lockout or different lockout positions for travel though, like the Revelation RLT for example.
    Any takes on the importance, preferences, likes or dislikes of remote lockout (RL vs crown adjust (RC line), different travel adjustments (T3 line) etc. etc. ?
    Aug 2017
    Tire size accommodation varies as well. Only the RC line specifies:
    "2.8 maximum tire compatibility for both 27.5 and 29 models (27.5x3.0 tires fit in the 29 model)"
    2.8" tires go with the 35mm stanchion model.
    Aug 2017
    The RC line of forks is remote lockout compatible though as seen under
    Specs
    Options " Remote with 2-position compression (open/lock) via OneLoc remote "
    One thing to keep in mind is that the OneLoc is a Shimano shifter like lever meant to go with a 1x drive-train.
    For a 2x drive-train one could look at/adapt a different style remote (none shifter type) because of the shifter for the front derailleur.
  1. 2018 Pike OR 2018 Push Fox 34 Factory?
    By almazing in forum Shocks and Suspension
    Last Post: 01-25-2018, 12:35 PM
  2. 2018 fox float 34 forks - 29 or 27+?
    By Mhpepper in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 07-07-2017, 01:23 PM
  3. Rockshox Dart 2 forks Better than Sunfork XCT forks?
    By max3 in forum Beginner's Corner
    Last Post: 07-08-2014, 01:46 PM
  4. Upgrading 150mm forks to 160-180mm forks
    By timng85 in forum Shocks and Suspension
    Last Post: 09-24-2012, 11:37 AM
  5. 29er forks more likely to snap than 26 inch forks?
    By Alastair78 in forum 29er Bikes
    Last Post: 06-05-2011, 06:15 AM
