FLY Team Ti '10- Mtbr.com
Results 1 to 3 of 3
Thread: FLY Team Ti '10
    FLY Team Ti '10
    First post, lurked a few... dropped the $$ for the November shipment.
    Guess I will finally join the Titanium crowd after 10 years of dreaming.
    Hoping bikes direct can add some tech specs on the stem size on the 2010 model.
    I suspect that it's only 90mm lenght (or even 70-80 for wieght), would any one in the know please verify the stock stem lenght?
    6, 8 or 10 degree?
    With +/- option?
    Need a larger cock pit, 110 would be good, but 120 will keep the "sit up and beg mode" to a minimum
    FWIW, my '09 came with a 100mm Ritchey WCS 4-Axis (31.8mm bar clamp), which I switched out to 130mm and ride flipped.
    Thanks Jim,
    I already plan to use my Easton Monkey high rise with full 650mm width.
    The chances are high they will use the same size, but they have the "Ritchey PRO aluminum" listed (25.4mm).
    Suspect it will be the Pro 4-Axis 44, which is what Ritchey list as the 31.8 size.
