Anyone running Vuelta's Tubeless?- Mtbr.com
    HTFU!
    Reputation: S.O.B.'s Avatar
    I am considering running my Team SL's tubeless with a Stans kit. Has anyone done this? Any problems or advice? I would like to read on some experiences before venturing into the world of tubeless.
    Thanks.
    I no longer deserve a signature. :skep:
    Oct 2007
    I have run them tubeless. I was using tubeless ready tires. I tried just using Stans yellow tape and valve, but the tires burped way to often and a couple of times blew off the rim. The Vuelta rims do not hold the beads tight enough to run them like this even with tubeless ready tires. They do however work great if you use Stans rim strips. So if you are going to go tubeless my recommendation is to use the rim strips.
    2020 Canyon Neuron 9.0 LTD
    2015 KHS Sixfifty Team
    2019 Salsa Warbird
    2019 Canyon Endurace
    1987 Haro RS1
    I've been running mine tubeless with no major issues. I used a stan's 29er kit and put one layer of the yellow tape under the rim strip and then the Stan's rim strip. I did this becauses I wasn't having luck seating the tires without all three layers. Since setting up like this no issues at all in various terrain and with different tires (smalll block 8 and specialized fast trak). If you haven't set up tubless before keep in mind that an air compressor makes the initial setup a whole lot easier.
    Blogging about nothing since 2005
    http://devinrides.blogspot.com/
    HTFU!
    My hope is to run regular tires with the Stans kit (not tubeless tires) I will be using Racing Ralphs, WTB Woverines and or Maxxis Larsen TT's. I suppose I should stop thinking about it and break down, buy the kit and give it a try. I will report back (in a few weeks+) if I actually do it. Good to hear I won't be the first to give this a go with these rims.
