About to order, need some help!- Mtbr.com
Results 1 to 5 of 5
    Jan 2011
    Ok. Finally got all my money in check and am ready to order my bike from bikes direct. However, I am stuck in between 3 bikes all around the same price.
    http://www.bikesdirect.com/products/...om29pro_08.htm
    Around $800, and comes with a tora fork with soloair. I have no idea what soloair is, but I can assume for some reason it is better?
    http://www.bikesdirect.com/products/...9_elite_xi.htm
    http://www.bikesdirect.com/products/...ff29pro_xi.htm
    Seems to me the windsor is close to the elite...Just smaller brakes and $100 less? Since I need a 17" it really limits what I can get from them.
    Jan 2011
    Also, a note that I am a fatty at 230lbs. I'm not sure if that would make the tora soloair fork a better choice or not.
    Reputation: Ítzi's Avatar
    Sep 2004
    The windsor is the best deal in your list. Here is a decent post which lists the differences;
    http://forums.mtbr.com/showthread.php?t=671682
    The Good Times are Killing me
    Quote Originally Posted by gaveup
    I went through the same process a month ago. I settled on the first one listed because it came with the Tora 318 solo air shock which has gotten great reviews. For 2011 the Tora solo air is now moved up to the Recon line. Its more adjustable than the sprung Tora TK the other two come with and is marginally lighter as well. It only has one air chamber vs the Reba which has two for more adjustability. I dont think you can go wrong with any of those choices, though. One thing to consider is the first one comes in a slate color and looks pretty cool. I'm not a fan of the yellow windsor
    Jan 2011
    Went with the Phantom Pro, should be here tomorrow! thanks guys
