• 01-23-2009
    wscott
    8 speed vrs 9 speed set up
    Ive been doing a little upgrading on my Fantom. My 8 speed cassette is about worn out and needs to be replaced. Question is, since I'm replacing it anyway, should I just go to a 9 speed set up or is there not that much of a performance difference between the two.
  • 01-23-2009
    milo8172
    Not much performance between the two. the gears can still be 11-34. you will be missing the 27 or 28. 8 speed will be lighter. If you go with nine speed, then you will probably need new shifters, possibly new derailleurs if not already compatible with 9 speed.
  • 01-24-2009
    wscott
    Ok, thanks, Ill just stick with the 8 speed then.
  • 01-24-2009
    boomn
    Like Milo said there isn't much performance difference. The real reason these days to go 9spd is that that there aren't many mid-level 8spd components any more and there are no top-of-the-line 8spd components at all
    If you don't feel the urge for fancy components then 8spd is still great
  • 01-24-2009
    rkj__
    yeah, it's tough to get a hold of anything better than an alivio shifter in 8 speed.
  • 01-24-2009
    milo8172
    Get a shimano XT 8 spd cassette
  • 01-24-2009
    wscott
    Thanks for all the info guys, Im gonna get the shimano 8 speed cassette and maybe some sram attack shifters and hold out as long as I can.
