33 tooth Outcast chain ring/crank failure- Mtbr.com
Results 1 to 6 of 6
    mtbr lurker
    Reputation: Drew69's Avatar
    Aug 2010
    No good 33 tooth Outcast chain ring/crank failure
    I use my V brake outcast to commute and it is my only mtb, when I take it to the trails I ride it hard but this happened when I was leaving campus after being stopped at a stop sign. I heard a aloud pop and then the clink of the chain ring bolts hitting the pavement. and then a scratch as the bent chain ring dug into my frame. Has anyone else had this problem? Why would this happen, cheap chain ring or crank? One of the four mounting points for the bolts on the crank is bent so my outcast will need at least a new drive side arm but after this experience I think its time to upgrade the part... not something I really wanted to do on this $350 bike.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Loose chain ring bolts. Did you use blue Locktite?
    mtbr lurker
    Aug 2010
    I used standard assembly grease
    AZ
    AZ is offline
    FWIW, I alway's Locktite them, the blue stuff (242). The bent ear may be able to be straightened, use a large adjustable wrench and go slow.
    mtbr lurker
    Aug 2010
    thanks for the tip, I think I'll give that a try. What bolts do you use? I had origin 8 bolts on it
    AZ
    AZ is offline
    Use any steel chain ring bolts, I have broken alloy bolts.
