29PRO SL with 2.4 Mountain King in back?- Mtbr.com
Results 1 to 3 of 3
    Has anyone used this tire with success? I was wanting to try but didn't know if it would fit in the frame in the rear.
    Missouri sucks...
    Do you run one in front as well? If so, buy one and try it in the rear and if it doesn't fit then you can use it as a new front when your current one wears out
    Pimpmobile
    I've run Panaracer Rampage 2.35 in the back with plenty of clearance... You should be good to go!
    "Fear not the ob-stackles in your path"
