Is there a cheap way to set this 26 MTB Mongoose to a front fixed gear?- Mtbr.com
Results 1 to 5 of 5
    May 2020
    New question here. Is there a cheap way to set this 26 MTB Mongoose to a front fixed gear?
    The front gear is stamped, so I cant just take off the little and big gear to make it 1x drivetrain in the front.
    Its a 2012 Mongoose Switchback.
    Attached Thumbnails Attached Thumbnails Is there a cheap way to set this 26 MTB Mongoose to a front fixed gear?-mongoose.jpg
    Jan 2009
    "fixed gear" is not the right term. look up "fixed gear bike."
    you want to convert it to a "one by" or 1x drivetrain. a single ring in the front and a derailer with multiple gears in the back. that's what most modern bikes use. you will need to replace the crankset to do that, and probably the bottom bracket.
    I discourage this on that particular bike. it's not worth the effort for the return on performance on a bike like that. it will quickly escalate into a Steamed Hams Situation.
    May 2020
    Ok, yeah I was looking to turn it into a simple "one by", mostly just to eliminate the chain slippage and just ride it as a beater or have as a backup incase a friend without a bike wants to ride with me.
    So yeah, just looking for a quick fix other than trashing it.
    Jan 2009
    quick fix: replace the crankset. You can do this for under $100. check around the classifieds. most cranksets can be changed to 1x, just not the really entry-level ones. most cranks have a way to remove and replace the rings.
    since 4/10/2009
    Reputation: Harold's Avatar
    If the chainrings are worn on a crankset with riveted chainrings, you have to replace the crankset anyway.
    I wouldn't call $100 for a crankset for such a bike "cheap" but you should be able to find a lot of stuff below that, especially on the used market, that will work.
  1. Cheap Fixed Gear 700c: Problems With Rebuilding Unsealed Huns
    By FueledByPBR in forum Wheels and Tires
    Last Post: 02-05-2016, 02:46 PM
  2. Cheap Fixed Gear Options
    By bank5 in forum Singlespeed
    Last Post: 09-24-2012, 07:26 AM
  3. Fixed/Fixed multi cog MTB hub
    By Mr.Bee in forum Singlespeed
    Last Post: 08-03-2011, 07:35 PM
  4. would a cheap fixed gear roadie be worth it?
    By ibanezrg520kid in forum XC Racing and Training
    Last Post: 01-21-2006, 08:36 PM
Members who have read this thread: 10
