Teocali sizing questions, help please!- Mtbr.com
Results 1 to 6 of 6
    Looking at the 2006 model of this
    http://www.mongoose.com/bikes/detail..._US&brandID=76
    Small size
    All the bikes I ride have 22.5 toptubes.
    Im 5'9
    the only part im concerned with is maybe the leg extension, I will be ordering this bike online
    Any owners out there? How does the FS sizing match up to standard hardtails with 22.5 top tubes?
    MORE Importantly, Can someone with a Small sized teocali measure the distance from the top of the seatpost (highest wjere ot seems reasonable fit) to the cranks? to get a measure of seat to crank or whatever?
    http://www.jensonusa.com/store/produ...e+Bike+07.aspx
    Here are some geometry charts from jensonusa.
    I keep looking at all the measurements, and they look right I think.
    Ok, took some measurements from my Hardtail, I know they aren't exactly standard measurements, but these are the areas of concern and what I am fit to.
    from the ground to the top of the rise in the handlebar, is about 41 inches
    from the top of the seat to the end of the crank (when the pedal is on the downstroke) is about 31 inches
    tt length is 22.5
    anyone help???
    STINKY TOFU
    Reputation: dragonhead08's Avatar
    I'm 5' 10 1/5 and i ride a med Teocali with a Thomson 90mm stem. I actually have the seat slide back a bit.
    achiever
    Reputation: redwarrior's Avatar
    I'm 5'5" with stumpy legs and ride a small. I have to run my seat pretty far up to get on top of the pedals. I'm guessing you'd be better off on a medium.
    Hello,
    I'm new to the Teocali family. I'm '5"5 and I ride a Medium. I thought I would be too big, but it's actually not bad at all. I actually had to slide the seat back a bit because the cockpit felt a little cramped. My former bike was a medum as well so maybe I'm just use it.
    My 2 cents,
