Rear Disc Options Schwinn 4-Banger- Mtbr.com
Results 1 to 8 of 8
    I'm tired of the Hayes rear 22mm mount disc brake and looking at a replacement such as the Avid Juicy 7 with a Hayes 22mm to 51mm IS adapter for my 98 Homegrown 4-Banger. Anyone successfully mount a different rear disc?
    smell my finger
    Reputation: joemamad's Avatar
    What you are gonna need is an "A-2-Z" brand adapter, 22mm to I.S mount. I have Avid Mechanicals mounted onto my 4-Banger. You have to use a 180,185 mm rotor because the adapter mounts the caliper farther out. The set up will work best with a 180mm rotor, with the 185mm rotor I have to shim the caliper with some washers to get proper clearance, but it works great.
    Reputation: RS VR6's Avatar
    Are these the Correct ones?
    http://www.pricepoint.com/detail/112...ke-Adapter.htm
    http://www.balleracing.com/Hayes/Hay...er22mmRear.htm
    Looking into the Avid BB7's for my hardtail Homegrown.
    smell my finger
    Here's one:
    http://cgi.ebay.com/A2Z-Rear-Disc-Br...QQcmdZViewItem
    I think you are going to need to use a disk brake caliper with a IS direct mount. These are different from most calipers because most (like the avids and hayes) use post mount to IS adapters. With the 4-banger, the brake caliper hangs off of the back of the drop-out so clearance is not an issue. On the hardtails and Sweetspots, the caliper and the adapter have to fit inside the rear triangle.
    The price point adapter pictured is not the one. The ballracing adapter might work but it is designed to "go the other way" from an IS mount on the bike to a caliper with the 22mm post mount.
    So will the Ebay one work with the Avid? Sorry...I'm still a bit confused with this.
    smell my finger
    I never tried it, so I can't really say, but it looks to tight. Check this:
    http://forums.mtbr.com/showthread.ph...ight=homegrown
    I guess I can get the bracket, go to my lbs and test fit it.
    Thanks for your help!
    smell my finger
    Great idea, let us know if it fits!
