HomeGrown Pictures Corner - Page 2- Mtbr.com
Page 2 of 2 FirstFirst 12
Results 201 to 286 of 286
  1. #201
    Feb 2010
    i got my first pinch the other day, it dropped the tire down to about 20psi, i was on a great feeling lap at the trail we ride most often (14 miles), it didnt feel too mushy or like it was going to damage the rim so i just didnt sit down for the rest of the trail to keep the weight forward...well i had my fastest ever lap time by 3 minutes. It was only my second time out on the single speed and i crushed the old time, which im giving most of the credit to the fast time, i crushed anyone else's time by about 4 minutes (1hr 12min 30sec). I am keeping a steady pace on the single speed, i am really loving it so far. I keep constant record of my times with my Garmin 405. I am running a 33t up front and 16 rear. i am going to go down to a 32 and 15 which will change my ratio from 3.9 to 4.0 and see how i do. So far i am loving this setup.
  2. #202
    Yeah, SS can be quite fast... I find I can do the same cadence using my big ring as I do the middle ring, so if you can do that, your times become alot faster!
    its hard to not be lazy though and drop to a smaller ring for a climb, and not shift up again at the top.
    Thats where SS is good. You maintain a better avg speed.
    Also, all my mates take the piss out of me for running 35-45psi in enduro's, but I've never ever had a flat at that pressure, and it rolls sooo much faster. The sacrifice of some cornering grip is totally worthwhile of higher pressures IMO.
  3. #203
    Feb 2010
    Quote Originally Posted by Bellsy
    i know what your saying, when i lost pressure it was very noticeable right away that i was slower on the flats, the climbs and downhills werent too terrible but the cornering was very nice, i normally run about 40 psi up front and 35 in the rear.
    when i went tubeless i also noticed a faster roll as well which was nice, you really feel the less rolling resistance. If you arent already tubeless you should give it a shot.
  4. #204
    Oct 2010
    I may have found a fork. I have the 97 homegrown with the white spun wheels on the last page. Does any one know steer tube length I need
  5. #205
    Quote Originally Posted by cemeb4dk
    The safest way is to simply measure your bike.
  6. #206
    Reputation: bridgestone14's Avatar
    Mar 2005
    yup mesure from the top of the crown of your current fork to the top of the stem. This will make sure you have more then enough. Typically falls in the 7 to 8 in range for a med.
    Looking for a Medium Scott Scale frame, preferably a 2012 in 26.
  7. #207
    Oct 2010
    Thanks Guys.
    I am looking at getting a 07 Mazz bomber mx pro. A local guy has it here and I can get it fairly cheap and it in mint condition.
  8. #208
    heres my baby ive had since brand new .
    <a href="https://www.flickr.com/photos/[email protected]/5176332380/" title="cars and bikes 120 by vanman150, on Flickr"><img src="https://farm5.static.flickr.com/4126/5176332380_67d2e3d4fd.jpg" width="282" height="500" alt="cars and bikes 120" /></a>
    in her current state
    <a href="https://www.flickr.com/photos/[email protected]/5175738309/" title="cars and bikes 121 by vanman150, on Flickr"><img src="https://farm5.static.flickr.com/4148/5175738309_1b7d6b248b.jpg" width="500" height="282" alt="cars and bikes 121" /></a>
    schwinn project underground .
  9. #209
    Crazy about Homegrowns
    Reputation: blue72beetle's Avatar
    Here's a picture from a couple weeks ago, on the 98 Carbon Homegrown.
    Just a couple minutes after this, I went OTB into a bunch of mud.
    Attached Thumbnails Attached Thumbnails HomeGrown Pictures Corner-208188_1822141667567_1060955673_32013307_1273718_n.jpg
  10. #210
    geek
    Reputation: DEADBEEF's Avatar
    May 2005
    here is my latest addition: 1999 homegrown pro singlespeed. I picked up the frame as a backup, but it was too pretty to leave on the shelf any longer.
    _____________________________________
  11. #211
    Quote Originally Posted by DEADBEEF
    Nice!
    I built one of those frames into a single speed myself. I loved it so much, I bought a second, identical frame just to keep as a backup. I'm also using the FC EBB on mine. Did you face your BB shell down to 68mm, or did you grind the granny mounts off the crankset?
  12. #212
    Mar 2005
    Looks like a dedicated single speed crankset to me. Great looking frame. I would really like a bass boat blue homegrown. Too many bikes already though.
  13. #213
    CTB
    CTB is offline
    Reputation: CTB's Avatar
    That's a very sweet bike there! Nice!
  14. #214
    geek
    May 2005
    Quote Originally Posted by bad mechanic
    Nice!
    no facing or grinding needed. the spot crankset has no granny tabs.
    Thanks for the comments!
  15. #215
    Quote Originally Posted by DEADBEEF View Post
    So, how do you like it?
  16. #216
    Aug 2005
    I built this up from a NOS frame I purchased a couple of years ago. I think it is a 1996. It is my primary ride.
    Attached Thumbnails Attached Thumbnails HomeGrown Pictures Corner-img_1372-3-1024x576-.jpg
  17. #217
    Quote Originally Posted by migeorgeco View Post
    Yup, '96 looks about right. You should really try putting a modern 80 or 100mm fork up front. In my opinion, it really wakes the bike up. Stock, the Homegrowns were kind of skittish, but a new fork bring the one-two punch of a suspension fork which actually works, and the longer fork relaxing the bike's angles.
    I still have a Judy XC of the same vintage stashed in the rafter of my work space.
  18. #218
    Aug 2005
    I would think 100mm would screw up the steering too much. I have one I could switch over (2003 Fox 100 rl), I may have to try it.
  19. #219
    Here's the thing, some Homegrowns were speced with a 63mm fork, and some with a 80mm fork. Both are listed as having a 71.5* head tube. Now, I strongly suspect Schwinn made both with the exact same geometry and just fudged the catalogs, but haven't been able to get my hands on a 63mm fork model yet to verify.
    Having put 100mm on several frames which cam with 80mm forks, in my opinion it's a brilliant change. If you have the means to try it, I highly recommend it.
  20. #220
    Mar 2005
    13" 2001 homegrown.
    Here is a little frame I had laying around. Finally had enough parts laying around to build it up. I know they are old 8speed parts, but they work just fine. It gave me an excuse to work on my wheel building skills too. I found some used xtr hubs and some NOS ceramic valiant rims. After buying the spokes and nipples, the wheels went together for about 110$. The fork still isn't the greatest despite my best efforts though. I might give it to a friend of mines little sister, who is only 4'11".
    Attached Thumbnails Attached Thumbnails HomeGrown Pictures Corner-dscn1805.jpg
  21. #221
    May 2010
    Schwinn 2001 Straight 6
    The paint was scratched up and cracked so I repainted it and build it up properly. If anyone needs to make decals I have the vector digital artwork for reprint.
  22. #222
    Mar 2005
    That is the new paint job and decals? That is incredible, did you paint it your self or have someone else do it? You spent a good amount of money on that build too, I hope it rides well.
  23. #223
    May 2010
    paint job
    Yes I did it myself in the back yard. Took like a month. Did it the hard way with multiple coats.
    I literally finished building it yesterday. I still need to connect the front brake caliper. The cable was too short so I went to the bike shop and they had a longer cable. So as soon I pick it up I'll go ride it for the first time.
  24. #224
    By the way, this September 11th is the 10 year anniversary of Pacific buying Schwinn.
  25. #225
    May 2010
    I'd like to think of it as the 10th year anniversary of when my Straight 6 was built. So for it's birthday I got those parts for it. And it looks very happy and full of life now.
  26. #226
    I'm selling an 18" Straight 6 frame in good condition. Interested?
  27. #227
    May 2010
    maybe
    Might be a little big for me I'm 5-9. But I'd like to see pics if you have them.
  28. #228
    Very nice!
  29. #229
    Reputation: Crazydad's Avatar
    There are some really nice tomatoes on here, but I do see one problem. A lot of them are way too clean..
    Here is me and my 97 after the ride today. I bought it new and it is still going strong. Other than things like chains/brake pads/tires, the only thing I have changed is the fork. It actually still has the original tube in the rear (of course now it will be flat tomorrow).
    Action shot:
  30. #230
    CTB
    CTB is offline
    Quote Originally Posted by 18hands View Post
    Very sweet! Put modern components on these things and they look as good as almost anything today. Not sure I put mine up with the new wheels/tires yet, so here it is:
  31. #231
    Here is my lil one. Does anyone know where I can get another frame like this? Any color, just want another one.
  32. #232
    Mar 2005
    CTB that is a great looking homegrown. That is a great build kit. Are you able to get many miles on it? What do you think of the Havens?
  33. #233
    I'll post mine when I've outgrown the 10 post limit......
  34. #234
    Hope
    Figured I'd join the Tomato Party !!!
    I bought the 17" frameset from Supergo back in '99 (when I was living in SoCal) and built it up with a mix of XT and XTR parts, a Cane Creek AD10 shock and Marzocchi Z2 Bam forks. The only new parts are the Conti Race King tyres, for now , I do plan to switch to discs front and rear using a B&S adapter and modern 152mm air shock with lockout.
    I'm currently riding trails around my home in the UK as part of rehab after nearly losing a leg in a motorcycle accident a few years ago and plan to enter some vet enduros when the leg strength improves.
    Cheers, Rob
  35. #235
    Nov 2006
    fork travel looks looong for this frame
  36. #236
    CTB
    CTB is offline
    Homeagain, I have the same frame and bought it from Supergo the same time you did! I had just racked up a lot of miles on my '98 Moab 2 and decided I wanted full suspension, so I bought the HG frame from Supergo, along with a Manitou SX-R fork in '99. Rode the resulting bike for something like 8 year with no changes.
    Brigestone14, thanks! This year's been a bit of a bust for riding due to weather and health issues, but I try to ride at least once a week in the summers, preferring twice a week. So far I like the Havens. They're only a tiny bit heavier than the Specialized Roval Traversee EL's I was using last year, but they have the advantage of not needing any rim tape to run tubeless. The Rovals are great wheels, too, but I got tired of messing up the rim tape every time I had to dismount a tire. Both the Havens and Rovals have quiet rear hubs (I hate the buzz of the new multi-engagement hubs), and I like the way the Havens look. Both are 21mm inside width, so I can run the wider tires that I prefer. So far no rear hub issues with the Havens, but I'm keeping an eye on them based on what I've seen on the web But I do like them so far.
    If interested, here's my complete build, as well as a link to the pictures of when we made my custom Ti rear shock mount, and more pics of the bike. Some are outdated, tho. I no longer have the Monkeylite bars, and the front skewer is now a vintage Homegrown piece with a machined tomato on it.
    https://s25.photobucket.com/albums/c...view=slideshow
    Crank: Shimano XTR M970
    Cassette: 11-34 XT
    Front D: Shimano XT from when the bike was made
    Rear D: Shimano XTR from when the bike was made
    Fork: 2008 Fox F100R
    Shock: 2004 Fox Float from a Cannondale Jekyll
    Brakes: Custom Avid Elixir CR Mags - available only for Specialized OEM. I liked that the color matched the original Hayes Mags, and they also have tool-free adjustment (unique to Specialized on the Mags).
    Post: Thomson setback
    Stem: Kalloy Uno. Bought for another bike, moved to this one as a test, saw no need to change it.
    Bars: No idea. No branding on them, and I inherited them with a bike I bought. But the bend fits me better than anything else due to 11- or 12-degree sweep.
    Grips: Ergon GC3's. I like old-school bar ends.
    Headset: Chris King
    Avid Thingamajig
    Tires: Conti X-King RaceSport 2.4, Conti RaceKing Supersonic 2.2
    Jagwire Ripcord cables
    Pedals: Eggbeater...SL's, I think. Been a while...
  37. #237
    Mar 2005
    ctb, I ebay a set of those exact same avid brakes and the reach adjustment is bent and needs to be replaced. I am a decent mechanic, and as far as I can tell, you have to press the lever pivot out of the lever. Have you ever had to take the lever off? I could use some advice if you have it.
  38. #238
    Quote Originally Posted by hellocook View Post
    The 'All Mountain' versions of the Homegrown Carbon bikes were fitted with 100mm Judy Xls resulting in slightly relaxed head angles. The 100mm Bam Z2s with heavy rated springs were a good choice back in the day, 12 years ago
    Cheers, Rob.
  39. #239
    CTB
    CTB is offline
    Quote Originally Posted by bridgestone14 View Post
    I wish I had some wisdom for you, but so far I haven't had to take my levers off. Sorry I couldn't help. I'll let you know if I learn something.
  40. #240
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    pardon me while i pick up my tongue
    '01 Straight 8
    '16 Balance
    '11 Jedi (for sale, small)
  41. #241
    Reputation: mbrock.40's Avatar
    During Build
    Here is a pic of my 2001 Factory when it was being built. Seatpost, stem and bars are different now, though.
    Too bad it's a 19" and not a 17". I am currently in the process of trying to sell the frame for something smaller.
    Better to be a rider for a moment than a spectator for a lifetime.
  42. #242
    Just got a sparkly seat for the HG.
    Some of the parts:
    Proshift derailleur
    Real levers (sandblasted - used to be turquoise)
    Raceface cranks
  43. #243
    Quote Originally Posted by j.les View Post
    Some of the parts:
    Proshift derailleur
    Real levers
    Raceface cranks
    That derailleur makes me all tingly inside. Awesome.
  44. #244
    Why the skinny, bald tires?
  45. #245
    Quote Originally Posted by bad mechanic View Post
    This was my road bike for a while.
  46. #246
  47. #247
    schwinn fanatic
    1998 Schwinn Homegrown Hard Tail
    Hey guys, I'm new here....but figured I would load a few pics of my '98 HG I snapped today in the sun! Hope you enjoy!
    Attached Thumbnails Attached Thumbnails HomeGrown Pictures Corner-10-1-11-071.jpg
  48. #248
    CTB
    CTB is offline
    I did enjoy. Very nice, and welcome!
  49. #249
    schwinn fanatic
    Quote Originally Posted by CTB View Post
    Thanks CTB....I appreciate it! Oh yeah....I already have bike envy over yours
  50. #250
    schwinn fanatic
    My '97 Factory Straight 6
    Hey guys, wanted to share this with everyone. It's my 1997 Factory Straight 6. Love this bike, probably the one I value most. All stock except for the neck, bars, grips, and headset.
    Breakdown:
    1997 Homegrown Factory 7005 frame/6061 swing arms
    Chris King headset
    Sun rims front and rear
    Hayes/DT front hub/rotor/caliper/lever
    Hope Big Un/C2 rear caliper/lever
    Maxxis tires
    Rock Shox Boxxer 6" travel front fork
    Rock Shox Coupe DeLuxe 2" travel rear shock
    Shimano XTR rear derailleur
    Grip Shift 8 spd shifter
    I hope you guys enjoy this as much as I do. Love these bikes, and thanks for letting me share!
    Attached Thumbnails Attached Thumbnails HomeGrown Pictures Corner-1997-straight-6-001-1024x683-.jpg
  51. #251
    Wow!! I'd kill to have that spec on my one!! Very very nice mate!!
  52. #252
    schwinn fanatic
    Quote Originally Posted by Bellsy View Post
    Thanks Bellsy, I really appreciate the kind words!
  53. #253
    Reputation: Buddha43's Avatar
    Oct 2011
    anyone in SoCal want a decent looking Straight4 check out this auction. 7 Used Bikes | Property Room
  54. #254
    Feb 2006
    Quote Originally Posted by Buddha43 View Post
    is it yours? and what size frame?
    '01 Straight 8
    '16 Balance
  55. #255
    Feb 2006
    i'm hungry for more...
    '01 Straight 8
    '16 Balance
  56. #256
    nice bike
  57. #257
    Quote Originally Posted by shwinn8 View Post
    Sorry man, but I haven't added anything new in a while. The two single speed Homegrowns are still doing great though. Currently I'm in the middle of upgrading my Sweetspot's shock to needle bearings, which is taking a bit of custom work to get done. It's amazing how a coupe simple tweeks can really make a Sweetspot downright plush.
  58. #258
    CTB
    CTB is offline
    B-Mech, tell me more of these tweaks. Believe it or not, I'm pondering building up a SS Sweetspot. The Sweetspot frame has a great deal of recession in jounce on the rear wheel, so that's a good thing for plushness. Since it's a URT, all that recession has zero effect on chain length. Which you already knew. I've just become aware of the Real World Cycling needle bearing kits, so maybe those can be adapted to the SS?
  59. #259
    B-Mech, tell me more. Believe it or not, I'm pondering building up a SS Sweetspot.
    It's about time!
    With a 2nd generation Sweetspot with the hollow pivot, the two main issues to address are misalignment between the front and rear triangle which binds the shock (less of an issue with coil shocks), and pivot bushings which are too wide, and therefore cause excessive friction. I posted a while ago about how to fix those issues:
    http://forums.mtbr.com/mongoose-schw...ly-661665.html
    I'm installing needle bearing because the mounting bushings are starting to wear out, and I might as well provide a long-term fix.
    By the way, don't forget to rebuild your Alps 4r before using it.
  60. #260
    Just found this....last of the HomeGrowns. A rarely used 2001 19" HG Comp with XTR rear and XT front derailleur and LX HollowTech cranks and Judy Race fork. Everything is stock except for the seat and pedals. It weighs 26lbs....probably was less with the original seat and pedals. It wasn't clear coated so has a few storage nicks.
  61. #261
    Feb 2006
    Look'n good!
    '01 Straight 8
    '16 Balance
  62. #262
    Feb 2006
    foot's almost better ..wake up to inspiration every morning!
    '01 Straight 8
    '16 Balance
  63. #263
    Feb 2006
    '01 Straight 8
    '16 Balance
  64. #264
    Feb 2006
    '01 Straight 8
    '16 Balance
  65. #265
    Feb 2005
    Homegrown Dual Suspension
    Greetings All,
    I am a long time Schwinn fan (mostly road bikes) and I am looking at getting a used Homegrown Dual Suspension like the one pictured (I'm getting older and my Specialized Jumpstumper hardtail has become too bone rattling). What are some of the things I should be aware of when buying a used dual suspension bike? Also, how easy is it to get replacement parts if needed?
  66. #266
    CTB
    CTB is offline
    Bikes like the Sweetspot really only have one replacement part - the swingarm bushings. You can still find them, either from old Schwinn stock, or I believe some of the bushing companies still make them. Might be something at McMaster-Carr, or Igus may have them. Sweetspots are pretty reliable overall. They don't deliver a super plush ride if that's what you're looking for, but compared to a hardtail, they're luxury.
  67. #267
    Mar 2005
    Just scored a '99 Homegrown complete this morning for $75
    Used but not abused. Small frame for my son but can't wait to get her tuned and cleaned up. Should like nice along side my Homegrown.
  68. #268
    Reputation: Rocket88R's Avatar
    Jan 2013
    Here's a nice tomato for ya!
  69. #269
    Feb 2006
    the last one is My favorite!
    '01 Straight 8
    '16 Balance
  70. #270
    Jun 2010
    I had one of these 4 Banger All Mountains. Mine was a 15". Loved that bike! I sold it last year and bought two HG's to replace it.
  71. #271
    Feb 2006
    $5 stays some of them buddha43 had in his post last year were stolen because i don't know what a straight 4 is
    '01 Straight 8
    '16 Balance
  72. #272
    Dec 2009
  73. #273
    Jul 2013
    HomeGrown Pictures Corner-schwinn.jpgHomeGrown Pictures Corner-schwinn1.jpgHomeGrown Pictures Corner-schwinn2.jpg
    My old Homegrown, built up back in 2000.
  74. #274
    Lost And Loving It
    Dec 2013
    HomeGrown Pictures Corner-img_20131225_111527.jpgClick image for larger version.
ID:	857466Oh I cant wait to post up pics of mine!
  75. #275
    GC3
    GC3 is offline
    Jan 2014
    My 98 Homegrown XT, Changing Fork and headset out this week, and possibly the cranks. I'm just getting back to riding and I'm worried the Kookas might be a bit dangerous.
    Attached Thumbnails Attached Thumbnails HomeGrown Pictures Corner-img_5442.jpg
  76. #276
    Reputation: buzzkill911's Avatar
    Aug 2013
    2001 Homegrown Factory Limited
    My Factory Limited commuter. Hit the trails for a few years with it but now it's my townie. Great bike to ride.
    Attached Thumbnails Attached Thumbnails HomeGrown Pictures Corner-homegrown.jpg
    Trails - 2012 Giant XTC Composite 1 29er
    Townie - 2001 Schwinn Homegrown Factory Limited
  77. #277
    Schwinn Decals
    Quote Originally Posted by buzzkill911 View Post
    Hi, Iīm a Schwinn Moab owner. It was stolen and I recovered but it was full painted (full black)
    I want to repaint it and need schwinn decals to put it, but canīt get it where I live (Argentina)
    Does anybody have or Know where to find schwinn decals?
    My sister will be in new york in one month and she can bring them
    Excuse my english
  78. #278
    Feb 2006
    Ebay
    '01 Straight 8
    '16 Balance
  79. #279
    Feb 2006
    15yrs ago I bought this Straight 8. 3yrs ago I regretfully sold it... the other day I bought it back!!!
    Attached Thumbnails Attached Thumbnails HomeGrown Pictures Corner-kimg2949.jpg
    '01 Straight 8
    '16 Balance
  80. #280
    Life's a Garden, dig it!
    Reputation: chuckha62's Avatar
    My Two Tomatoes
    Both SSs
    '99 Sweetspot SS converted to 27.5. 34:20 weighing in at ~24.5 Lbs
    '01 Hardtail SS running 32:18. She weighs a tick under 20 lbs, with Tubeless tires.
    "And crawling on the planet's face, some insects called, The Human Race..."
  81. #281
    Feb 2006
    Finally after 21yrs!! No not 21yrs to get a Homegrown, 21yrs to get the Gold'n silver Homegrown 4Banger!!.. lots of upgrades to be had! and so little money ... lol . it'll look good next to the Old Straight 8.. one more bucket list bike to go, the OG Homegrown, an American made Schwinn Stingray Cotton Picker or Grey Ghost
    Attached Thumbnails Attached Thumbnails HomeGrown Pictures Corner-kimg0712.jpg
    '01 Straight 8
    '16 Balance
  82. #282
    Mar 2005
    nice looking ride man. do you ride these or just hang them up.
  83. #283
    Reputation: Rusted Cluster's Avatar
    Jan 2020
    I'm glad to see my homegrown will be in good hands.
    Thanks Bryan.
  84. #284
    Feb 2006
    Quote Originally Posted by Rusted Cluster View Post
    Thanks Bryan.
    are you Sanddollar64 ? It's in great shape! I was worried about broken pivot tabs but all looks good!
    '01 Straight 8
    '16 Balance
  85. #285
    Jan 2020
    Yes, and Yes she is. I hope you get some great rides on her.
  86. #286
    Feb 2006
    great rides to come for sure! I need to go clipless, maybe tubeless, needs new cables and cable housings, brake pads, wider handle bar, and some other Nick nacks 1st. I'm super stoked!
    '01 Straight 8
    '16 Balance
Members who have read this thread: 25
