Freedrive Maintenance- Mtbr.com
Results 1 to 3 of 3
    achiever
    Reputation: redwarrior's Avatar
    My 05 Teo Elite developed a creaking noise over the past couple of weeks so today I decided to fix it. I was thinking it was something to do with the bottom bracket so I pulled the cranks and took the BB cups out one at a time. When I pulled the drive side cup with the platstic tube attached I noticed a pile of crap in the BB housing (not sure of the proper name for it). It turns out that the housing which also has a number of pivot points on it has a hole in it up near the top and no drain hole. This doesn't really make any sense to me. Why a hole up so high with none in the bottom. Anyway, next time I lube the pivots I may drill 1/8" or 3/16" hole to let the water out.
    Anyway, I got everything apart and re-lubed and the infernal creaking is gone. It's a pretty simple job but Id prefer to have some torque specs next time and some blue loctite. I may take some pics and post up a how to next time. I'll probably be replacing the BB in the late fall so I'll do it then.
    Red
    Reputation: dauwalt's Avatar
    Mar 2005
    My '05 Teocali Super just started creaking down there. I just thought the bearings were shot or needed maintenence. If I figure it out when I pull it apart I'll post.
    FYI, this is after about 2500 miles.
    achiever
    I had another creek start mid ride yesterday. It was driving me insane and couldn't ride until I figured it out. It turned out to be the rear derailluer cable housing rubbing on the frame near the bottom of the seat mast.
