Ml 7 , Ml 7.3, Ml 7.5- Mtbr.com
    Mar 2006
    Whats the difrence between these frames.
    thanks
    Hoops - Big and Small
    Reputation: Crash_Burn's Avatar
    Here's the cliff notes version
    7 = Paul took this many times to get it right
    7.3 = third version by Fox to make Paul happy
    7.5 = If your not in a hurry wait for the Durance
    You need to be more specific, there are way to many differences to really explain -
    Schipperkes are cool.
    Reputation: banks's Avatar
    ML7 was the start, 4" in the rear.
    Repasado 3" rear
    ML7.3 is the lastest 4" rear
    ML7.5 is a fully welded rear end with 5" in the rear [stiffer and lighter than the ML7.3]. There are now 2 versions; Matic for use with 5" front end and the Durance for use with 6" front end.
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    Short Lived Reposado
    Quote Originally Posted by banks
    Repasado 3" rear
    Was there a 40mm travel air shock? I though it was only lighter tube mix was the difference, oh yeah and those brake bosses.
