Water Bottle on Mount Vision XM8- Mtbr.com
Results 1 to 5 of 5
    Jul 2014
    None of my water bottles will fit in the water bottle cage on my Mount Vision.
    Is there a bottle cage which travels lower that can be mounted there and accept a normal water bottle?
    There is another place to mount a water bottle, but that's on the bottom of the tube, near the BB, where it will get spattered with mud and is not accessible while riding anyway.
    Nov 2013
    Having the same problem with my 2013 MV. Has anyone successfully mounted a bottle on the down tube (or did they just put the bottle mount screws there for looks)?
    2017 Scott Spark 930
    2016 Fuji Grand Fondo Classico 1.3
    2016 Felt F4X
    Jul 2014
    I eventually found a side loading bottle cage that fit a small water bottle at least.
    Sent from my SM-P900 using Tapatalk
    Nov 2013
    Quote Originally Posted by andytiedye View Post
    What cage did you get? I've tried a few now, none will hold a 21oz bottle. I even bought an adapter to move the cage down the down tube, but then the shock hits the bottle. No idea why they put the bolts on the frame if you can't mount a bottle, ugh!
    2016 Felt F4X
    Nov 2013
    PS, I'm on a small frame. Not sure if you're on a med or large?
    2016 Felt F4X
  1. Adding a second water bottle mount.
    By Douger-1 in forum Arizona
    Last Post: 03-22-2014, 03:57 PM
  2. No water bottle mount
    By Alias530 in forum General Discussion
    Last Post: 01-10-2014, 08:13 PM
  3. Adding a water bottle cage mount
    By Pauldotcom in forum Frame Building
    Last Post: 10-29-2013, 06:32 PM
  4. Handlebar Water Bottle Mount?
    By DropkickMurphy in forum Beginner's Corner
    Last Post: 08-22-2012, 01:58 PM
  5. Teocali water bottle mount
    By maloo in forum Mongoose-Schwinn
    Last Post: 07-11-2012, 03:50 AM
