Marin updates site with 2018 Hawk Hill Lineup - Thoughts?- Mtbr.com
    Reputation: onesojourner's Avatar
    Jun 2017
    So the specs are finally posted on the Marin site for all the Hawk Hill models.
    Hawk Hill 3
    Code:
    FRAME
    Series 3 6061 Aluminum Frame, 27.5 Wheels, 120mm Travel, MultiTrac Suspension Platform, 148x12mm Boost Thru-Axle
    FRONT SUSPENSION
    RockShox Revelation RC 27.5", 120mm Travel, Compression and Rebound Adjustment, Alloy Tapered Steerer, 110x15mm Boost Spacing, Maxle Stealth, 51mm Offset
    REAR SUSPENSION
    RockShox Monarch RT Debonair, 190x51mm, Debonair Air Sleeve, Rebound Adjustment, Custom Tune, Firm Pedal Platform Lever, 22.2mm x M8 Hardware
    RIMS
    Marin Aluminum Double Wall, 29mm Inner, Sleeved Joint, Disc Specific, Tubeless Compatible
    HUB REAR
    Formula, 148x12mm, Quad Sealed Bearings, Centerlock Disc, 32H
    HUB FRONT
    Formula, 110x15mm, Centerlock Disc, 32H
    SPOKES
    14g Black Stainless Steel
    TIRES
    WTB Breakout 27.5x2.35", TCS Light/Fast, Tubeless Compatible
    DERAILLEUR REAR
    Shimano SLX GS, Direct Attachment, 11-Speed
    DERAILLEUR FRONT
    SHIFT LEVER
    Shimano SL-7000R 1x11-Speed
    CRANKSET
    FSA V-Drive, Modular 1x, 32T Direct Mount Chainring, MegaTooth Technology, Boost Spacing
    BOTTOM BRACKET
    External Sealed Cartridge Bearings
    CHAIN
    KMC X11 Extra Light
    CASSETTE
    Shimano SLX M7000 Cassette, 11-Speed, 11-46T
    BRAKES FRONT
    Shimano Deore M6000 Hydraulic Disc, 180mm Rotor
    BRAKES REAR
    Shimano Deore M6000 Hydraulic Disc, 160mm Rotor
    BRAKE LEVERS
    HANDLEBAR
    Marin Mini-Riser, 6061 Double Butted Aluminum, 780mm Width, 4 Up, 9 Back
    STEM
    Marin 3D Forged Alloy, 45mm
    GRIPS
    Marin Single Clamp Locking
    HEADSET
    FSA No 57E, Sealed Cartridge Bearings, 1 1/8" x 1 1/2
    SEATPOST
    TranzX Dropper Post, YSP12 w/ 1x Remote, Size S 100mm Travel, All Other Sizes: 125mm Travel
    SADDLE
    WTB Volt Comp
    PEDALS
    EXTRAS
    TranzX Bolt-on Thru-Axle
    Hawk Hill 2
    Code:
    FRAMESeries 3 6061 Aluminum Frame, 27.5 Wheels, 120mm Travel, MultiTrac Suspension Platform, 148x12mm Boost Thru-Axle
    FRONT SUSPENSION
    RockShox Recon RL 27.5", 120mm Travel, Compression and Rebound Adjustment, Alloy Tapered Steerer, 110x15mm Boost Spacing, Maxle Stealth, 42mm Offset
    REAR SUSPENSION
    RockShox Monarch R Debonair, 190x51mm, Debonair Air Sleeve, Rebound Adjustment, Custom Tune, 22.2mm x M8 Hardware
    RIMS
    Marin Aluminum Double Wall, 29mm Inner, Pinned Joint, Disc Specific, Tubeless Compatible
    HUB REAR
    HUB FRONT
    SPOKES
    TIRES
    Vee Tire, Crown Gem 27.5x2.35", Dual Control Compound, Folding Bead, Tubeless Compatible
    DERAILLEUR REAR
    SRAM NX 11-Speed
    DERAILLEUR FRONT
    SHIFT LEVER
    SRAM NX 1x11-Speed
    CRANKSET
    FSA Comet, Modular 1x, 30T Direct Mount Chainring, MegaTooth Technology, Boost Spacing
    BOTTOM BRACKET
    CHAIN
    KMC X11 Extra Light
    CASSETTE
    SunRace 11-Speed, 11-42T
    BRAKES FRONT
    Shimano BR-M315 Hydraulic Disc, 180mm Rotor
    BRAKES REAR
    Shimano BR-M315 Hydraulic Disc, 160mm Rotor
    BRAKE LEVERS
    Shimano BL-M315 Hydraulic
    HANDLEBAR
    Marin Mini-Riser, 6061 Double Butted Aluminum, 15mm Rise, 780mm Width, 4 Up, 9 Back
    STEM
    GRIPS
    HEADSET
    SEATPOST
    TranzX Dropper Post, YSP15 w/ 1x Remote, Size S 350mm Length 100mm Travel, All Other Sizes: 400mm Length 120mm Travel
    SADDLE
    Marin Speed Concept
    PEDALS
    EXTRAS
    Hawk Hill 1
    Code:
    Same as 2017
    I really had high hopes for these bikes. The hawk hill 2 with a 10-42 cassette (XD Driver Hub) and a 28t chainring up front. That would give this bike awesome range. If you want more range GX Eagle is now less than $400 away.
    There is a problem with a build when you can literally build a nicer version of the bike yourself. Grab the hawk hill 1 Then add the following (prices from Jenson):
    Rockshox Monarch RL
    $234.99
    Shimano SLX RD-M7000
    $49.99
    Shimano SLX M7000 11 Speed Shifter Rear
    $29.49
    Shimano SLX CS-M7000 Cassette 11-46T, 11 Speed
    $59.99
    Shimano Xt/Ultegra CN-HG701 11 SPD Chain Silver, 11 Speed
    $28.99
    This a much nicer setup than the NX equipped Hawk Hill 2 and it will come in about 100 bucks cheaper.
    NedwannaB
    Reputation: JMac47's Avatar
    I like your component ideas.👍
    Wait whuuut, who did he tell you that!?!?....
    Reputation: broncbuster's Avatar
    Jun 2014
    Quote Originally Posted by onesojourner View Post
    Hawk Hill 3
    Code:
    FRAME
    FRONT SUSPENSION
    REAR SUSPENSION
    RIMS
    HUB REAR
    HUB FRONT
    SPOKES
    TIRES
    DERAILLEUR REAR
    DERAILLEUR FRONT
    SHIFT LEVER
    CRANKSET
    BOTTOM BRACKET
    CHAIN
    KMC X11 Extra Light
    CASSETTE
    BRAKES FRONT
    BRAKES REAR
    BRAKE LEVERS
    HANDLEBAR
    STEM
    GRIPS
    HEADSET
    SEATPOST
    SADDLE
    WTB Volt Comp
    PEDALS
    EXTRAS
    Hawk Hill 2
    Code:
    FRONT SUSPENSION
    REAR SUSPENSION
    RIMS
    HUB REAR
    HUB FRONT
    SPOKES
    TIRES
    DERAILLEUR REAR
    SRAM NX 11-Speed
    DERAILLEUR FRONT
    SHIFT LEVER
    SRAM NX 1x11-Speed
    CRANKSET
    BOTTOM BRACKET
    CHAIN
    KMC X11 Extra Light
    CASSETTE
    BRAKES FRONT
    BRAKES REAR
    BRAKE LEVERS
    HANDLEBAR
    STEM
    GRIPS
    HEADSET
    SEATPOST
    SADDLE
    Marin Speed Concept
    PEDALS
    EXTRAS
    Hawk Hill 1
    Code:
    Same as 2017
    Rockshox Monarch RL
    $234.99
    $49.99
    $29.49
    $59.99
    $28.99
    Forgot the dropper post. And there went your $100.
  1. Replies: 22
    Last Post: 02-13-2019, 12:10 PM
  2. Marin Hawk Hill
    By JMac47 in forum 27.5
    Last Post: 02-10-2019, 12:48 AM
  3. 2018 Marin Hawk Hill Jr
    By TwoTone in forum Families and Riding with Kids
    Last Post: 06-29-2017, 01:47 AM
  4. Giant Stance 1 vs Marin Hawk Hill
    By dereliecte in forum 27.5
    Last Post: 06-15-2016, 08:11 PM
  5. Bought a Marin Hawk Hill
    By Krunk_Kracker in forum Marin
    Last Post: 02-26-2013, 06:36 AM
