Front derailleur issues on XM8- Mtbr.com
Results 1 to 3 of 3
    Reputation: NoVA_JB's Avatar
    I've had my XM8 for a couple of months and the last 2 rides the front derailleur is rubbing in the lowest gear. When I get it on the bike stand I tune it a little and it goes away but then when I get back on it the rubbing comes back.
    I'm thinking it's due to the sag when I'm on the bike but can't figure out how to get it tuned properly.
    Has anyone experienced this problem?
    Jul 2014
    Are you tuning it with the little screws or by adjusting the cable? Try adjusting the derailleur (from the cable) so it's on the towards the bigger gears, not centred. Then if it slips a bit when you go for a ride it should be good. I had the same problem, but on a different bike. Not a high-tech fix but it worked for me.
    Good Luck!
    Yeah I was adjusting the H and L it was getting so bad that it was almost jumping gears but I'll try just with the cable and I can do that while riding the bike. I was worried that this type of suspension was sagging too much causing the erratic shifting
  1. NEWbie Front Derailleur Issues: HELP
    By Bodhi_1 in forum Tooltime
    Last Post: 03-13-2014, 05:49 PM
  2. XTR front derailleur issues on RIP 9 2011 frame
    By dokmachug11 in forum 29er Bikes
    Last Post: 09-01-2013, 06:22 PM
  3. RIP9 alloy - front derailleur issues?
    By Jisch in forum Niner Bikes
    Last Post: 08-08-2013, 02:31 PM
  4. 3x9 front derailleur on a 3x8 setup (to solve rockhopper 29 front shift issues)
    By samandkimberly in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-15-2013, 04:37 AM
  5. Tracer VP / X9 Front Derailleur / Issues
    By xnofriendsx in forum Intense
    Last Post: 09-12-2011, 11:09 PM
