Xeccon lense problem please look.- Mtbr.com
Results 1 to 7 of 7
    Reputation: SimonNI's Avatar
    Jan 2015
    Been out for a 5 night rides now and noticed this today while cleaning up. Is it anything to be worried about? Looks like the lense has been overly hot and started to melt. Has a bit of a rainbow round it too.
    Reputation: spankone's Avatar
    More likely condensation from being built in a humid factory. You can unscrew the bezel and clean the lens.
    Jan 2015
    Thanks will get on it now.
    Sent from my SM-G900F using Tapatalk
    Jan 2015
    All sorted. Thanks again
    no worries.
    Quote Originally Posted by SimonNI View Post
    Not sure which lamp you have but with my 1211 the first ride I did with it pretty much did the same thing. Basically in my case I figured the moisture rising off my head condensed onto the inside of the lens. I simply took the front off, cleaned the lens with glass cleaner and put the front back on. ( this time much tighter than it originally was ) I don't think it happened again after that but I forget because it's been a while since I last used it.
    Aug 2013
    If there's some moisture getting inside - probably you'll have to check/replace the O-ring seals...
  1. gas lense kits
    By ktm520 in forum Frame Building
    Last Post: 02-22-2014, 01:31 PM
  2. Found - Camera Lense (Polarizer) at Hillside
    By anchskier in forum Alaska
    Last Post: 09-24-2012, 11:41 AM
  3. Oakley Vented Lense - Worth it?
    By canuck_tacoma in forum Apparel and Protection
    Last Post: 09-14-2012, 04:34 PM
  4. action wide angle lense
    By laackund in forum Lights and Night Riding
    Last Post: 08-27-2012, 07:36 AM
  5. Contact Lense Wearers, Help
    By Lando47 in forum Endurance XC Racing
    Last Post: 10-19-2011, 10:44 AM
