Wide angle lens for Gemini Duo..anyone use one?- Mtbr.com
Results 1 to 6 of 6
    I like turtles
    Reputation: TiGeo's Avatar
    See that Action has these for the Duo. Does anyone have any experience with it? Thinking I will order it for $5 but was just curious if folks were running one or two.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro AF
    Reputation: MRMOLE's Avatar
    Quote Originally Posted by TiGeo View Post
    The advantage to this optic is that it has a very wide beam spread. If your looking for a lot of light around your front wheel or you do rolling hills and want more vertical illumination you might like this optic. It also dims the intensity considerably and was more of a power drain on my Duo/Yinding than I was willing to put up with (definitely don't won't to run two of these). Better option IMO from "Action" is Gloworm's wide angle optic for the "XS". Nice medium wide beam, minimal loss of light intensity, and enough throw to run two if you want but pricy (price of two Gloworm optics + $10 more will get you a Nitefighter BT21 which is a much better performing light).
    Mole
    I like turtles
    Thanks for the info Mole. You really think the BT21 is nicer than the Duo?
    Sent from my SCH-I545 using Tapatalk
    RAKC
    Reputation: tigris99's Avatar
    Its brighter and higher output, and much more "spread" on the beam pattern, good mix of throw and flood for the bars. Also far better heat management. Runs cooler with higher output that the Duo/Yinding.
    I don't know if I'd call it nicer but I will stick with better performing. Noticeably more power, wider beam pattern, more throw and the big one for me is a much easier to use power control button. This is really the only thing I dislike about the Duo and one of my favorite functioning features on the BT21. I'm sure I could cycle through the BT21's 4 modes twice for every time through the Duo's 3 modes. Maybe your friend will let you try out his new BT21 and you can judge for yourself.
    Buy the light if you like it, You deserve it!
    Mole
    I like turtles
    ^^^I definitely plan on trying his out...will see!
  1. Chromag Wide Angle
    By eurospek in forum 27.5
    Last Post: 03-05-2015, 07:08 AM
  2. Project Ultra Wide Angle
    By DurtGurl in forum Photography for mountain bikers
    Last Post: 10-26-2013, 01:12 PM
  3. Wide angle optic for MJ-880
    By fightnut in forum Lights and Night Riding
    Last Post: 09-20-2013, 05:11 PM
  4. Wide Angle Blues
    By rcracerdan in forum Videos and POV Cameras
    Last Post: 09-16-2012, 05:21 PM
  5. Best wide angle led light
    By tjohns14 in forum Lights and Night Riding
    Last Post: 02-23-2011, 03:47 PM
