Where do you mount your battery for handlebar light?- Mtbr.com
Results 1 to 21 of 21
    Reputation: BmoreKen's Avatar
    Sep 2004
    I was mounting on stem until I noticed the end piece of the battery case cracked from banging against the stem and/or head tube. Then I started mounting on the top tube until I noticed the paint finish was getting rubbed to a matte. One buddy mounts his on his seat post but mud and dirt gets all over the battery.
    What to do ?
    May 2005
    I mount my big battery (8 cell) under the seat so I don't notice the weight. I put it in a padded fabric bag so it keeps most of the junk off it.
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    Feb 2007
    I covered frame areas that might rub with helicopter tape (not sure what the real name is, but that's what it's called on ebay). Now I can mount anything anywhere and no worries about scratches or anything.
    RAKC
    Reputation: tigris99's Avatar
    I stick mine to my downtube. granted I use pouches mostly but hard cases I put closed cell foam adhesive pads on them so they dont scratch my frame or get jacked up. I couldnt imagine the weight of a pack on the stem.... On the Down tube above my bottle cage (not under the DT but on the top side of it) works great for me.
    I like turtles
    Reputation: TiGeo's Avatar
    Top tube..near the front. A second for "I can't imagine the weight of a battery on the stem".
    Sent from my SM-G900V using Tapatalk
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro AF
    I used to mount it under the stem, but as stems have gotten shorter, that doesn't work anymore. Now I mount it on the handle bar right in front of the stem. The magicshine straps work great for this setup.
    http://www.action-led-lights.com/col...j-6038-battery
    I like turtles
    Why wouldn't you mount it on the top tube? Just curious...a battery on the bar seems like it would throw things off.
    Apr 2014
    Water bottle cage
    I like bikes
    Dec 2014
    I'm still waiting on my NiteFighter BT40s but, when I get, it I'm going to put some ESI silicone tape on my top tube and mount the battery on that. Never used the stuff but it's supposed to only adhere to itself and come off easily.
    For me the battery on the bar is more convenient. The cable route is more compact and I don't have to work around the funky tube shape on my bike. The battery weight is miniscule and it's mounted dead center on the bar so I don't notice it at all.
    Feb 2006
    I put my 4-cell battery in a neoprene pouch (forgot where it came from) then strap it on top of top tube behind steerer tube. Neoprene bag keeps paint finish intact.
    Sep 2004
    Quote Originally Posted by NotAnotherHill View Post
    I'm going to try that ESI silicone tape.
    I'd also like to try getting the battery to hold on the topside of the top tube rather than the bottom side. Not sure how well it will work, though, as it seems it will naturally rotate around and down.
    I like turtles
    ^^^This is how I do it...but now I have one of the newer battery packs from action that has the great rubber straps so I don't have to use the Awesome Strap...nonetheless, this is bulletproof.
    Attached Thumbnails Attached Thumbnails Where do you mount your battery for handlebar light?-20131026_231547.jpg
    I like turtles
    Where do you mount your battery for handlebar light?-uploadfromtaptalk1445632713145.jpg
    New battery mounted same way. This is why I like short cables on the battery and light like my Gemini and MS battery...some of the cheapos have cords that are WAY too long.
    I would mount mine under the seat if I wasn't using a dropper. I mount it on the seat tube right above the suspension rocker. I forget it's there most of the time. The cord is wrapped around the brake cable up to the stem, almost invisible. I've started trying to get weight as low and out of the way as possible. My spare tube, C02, and multi tool now get velcroed to the down tube. I try to use my pack only for water. I might be moving my battery to the down tube again but somehow it stays very clean on the seat tube, much cleaner than it did on the down tube for the short time that it was there. I don't care if my spare tube gets nasty but I try to protect the battery.
    '08 Hardrock HRXC
    '09 Epic Comp
    '14 Trance SX -
    May 2005
    Quote Originally Posted by TiGeo View Post
    I'd be concerned about jewel clearance in the event of a quick need to dismount.
    I like turtles
    Never get close.
    Reputation: Psycho1's Avatar
    Aug 2014
    Water bottle cage
    I like turtles
    I've mounted it on the underside but its not as clean due to the cables. I don't like lots of cables for some reason so close to the stem is best for me and this is as good as it gets on my bike.
    Just Ride !
    Reputation: C.M.S's Avatar
    Stem , but my battery is in a nice padded xeccon pouch .
    Hit the trails with your bike and get freaky. :cornut:
    Reputation: kenjihara's Avatar
    Mar 2006
    I use Solarforce L2M flashlights with conventional 18650 rechargeable batteries. I strap the light under my handlebar with two Livestrong bracelets.
    Sent from my SCH-I545 using Tapatalk
  1. ITUO Wise- GoPro Compatible Handlebar Mount-Fits 25.4-35mm Handlebar
    By ITUO Manufacturer in forum Lights and Night Riding
    Last Post: 05-06-2016, 03:53 PM
  2. Replies: 1
    Last Post: 02-09-2015, 11:34 AM
  3. Replies: 18
    Last Post: 11-24-2014, 01:21 PM
  4. A good quick release handlebar mount light for commuting
    By bikedreamer in forum Lights and Night Riding
    Last Post: 12-02-2013, 10:03 PM
  5. ISO Ideas for Battery Storage (Handlebar mount lights)
    By Montana Rider in forum Lights and Night Riding
    Last Post: 04-20-2012, 03:35 AM
