What Model Number is this Niterider?- Mtbr.com
Results 1 to 8 of 8
    Reputation: BikingScott's Avatar
    I would like to know what model of Niterider I have. It's a double light that are LEDs.
    I've looked at the NR catalogue, and mine looks the same as several of their later models.
    I think mine is about 1~2 years old. So I am guessing it may be either a PRO-1200,1800, or 2200. But it could very well be one of the Higher Pro series...3600Enduro or DIY.
    I'm attaching pics, but to me they all look alike.
    Thanks in advance for any help.
    Attached Thumbnails Attached Thumbnails What Model Number is this Niterider?-image.jpg
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    Looks like a PRO 1200 since it has two Cree MC-E emitters.
    Quote Originally Posted by kwarwick View Post
    Kwarwick,
    Thank You!!! I think you nailed it. I was trying to find orig. receipts, but could not find them.
    Thanks Again,
    Biking Scott.
    May 2005
    That light uses reflectors made by Fraen. One narrow and one wide. The Fraen narrows were one of the best reflectors for the MC-E emitter. If you could find another narrow one to replace the wide one you will get a fair bit more throw and still have plenty of spill for close in since the MC-E is a very wide beamed LED.
    The MC-E was popular about 6-7 years ago for the DIY crowd. Does NR still use it in recent products?
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    Thanks for all the good info! I'm thinking of listing it for sale and I just want to make sure I am describing it correctly.
    I cannot find any model/serial numbers anywhere on the outside. Does anybody know if that info is stamped on the inside of the casing?
    Is it ok to remove the 4 Allen screws that are holding the lenses cover on?
    I'd avoid disassembling if at all possible. It can be done, but you run risk of damaging seals, leaving finger oils on surfaces, cracking lenses. I took my old trinewt apart to repair broken wiring & managed to chip lens putting it back together.
    Goats Rule!
    Could be a pro 1200 or 1400. Early 1200's didn't have the NR logo printed on them, 1400's did. If you can post a picture of the cable connector it will help - the 1200/600 had a slightly different connector than what was used from the Pro 1400/700 series forward (still used to date).
    This is the best photo I could get of the Connector
    Quote Originally Posted by KingOfTheHill View Post
  1. how can I know model with serial number
    By adrimirko in forum Beginner's Corner
    Last Post: 04-17-2015, 11:17 PM
  2. Identification of Cateye Astrale Model Number
    By jdave5917 in forum GPS, HRM and Bike Computer
    Last Post: 03-05-2015, 01:14 PM
  3. How to tell model year from serial number?
    By manpurse in forum Niner Bikes
    Last Post: 10-10-2012, 07:04 AM
  4. Replies: 2
    Last Post: 08-18-2011, 02:59 PM
  5. SRAM Chains - model number confusion
    By Steve.E in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-18-2011, 06:35 AM
