USB wall charger question.- Mtbr.com
Results 1 to 12 of 12
    Reputation: FISHLEG's Avatar
    Hey folks!
    Just got a couple Niterider Lumina 750 lights and its easier for me to charge them via a wall outlet.
    Will any wall adapter work? Like the one that came with my LG phone?
    Or is there something more specific I need?
    Don't want to harm the batteries/light.
    Leeann Tweeden is looking for me.....
    Co Springs
    Reputation: bachman1961's Avatar
    Oct 2013
    I have that same light, just use a phone charger.
    The output rating on most phone chargers are 1 , 1.5 and some are up to 2 amps.
    Slower charging is probably ideal but those 3 ratings will be fine. Can it take more ? Not sure.
    If you have something like a 5.0 amp output off and a/c to USB, avoid that unless you confirm specs on the light that it's safe. Fast-charging the lamp may affect battery life for recharges.
    ADDED - The manual shows 0.5 amps = 5 hours to full charge and over that ampere is "intelli charge" to full power in 2.5 hours. It may have a smart circuit for protection on bigger output. The manual it comes with is quite vague.
    bachman must spread some Reputation around before giving it to himself again. :madman:
    Guest
    I've used USB chargers for everything from old Blackberry's to my Surface to a car adapter for years, no damage to the lights yet. Mine are approaching 5 years old and going strong.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    if it outputs 5~ volts it will work fine
    what matters is amps. if it has low amps like .5, .8. 1...anything below 2.1 then it might take some time to charge. if it had 10 amps that is fine, the light will draw what it needs
    it's the output volts you need to worry about, as long as that matches
    what the light needs, you are fine
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Ok sounds good.
    Thanks much!
    well this is interesting.....
    I tried my phones wall charger and it wouldn't charge the light.
    Then I tried a USB cord on my computer (from a kindle) and it wouldn't charge it either.
    I had to use the specific USB cord that came with the light via my computer.
    Reputation: Cuyuna's Avatar
    May 2017
    Quote Originally Posted by FISHLEG View Post
    Hey folks!
    The voltage for all USB charger outputs is the same. There are differing levels of current output, though. For lights or other high-current batteries your problem is going to be not enough power (longer charge time) rather than too much (damage). I use a Anker USB charging bricks ($13) for my Specialized Flux Experts and other such stuff for charging in the garage, I use a power strip with USB sockets in the workshop.
    May 2005
    NightRider has a reputation of making lights that only work with their proprietary accessories. Wonder if that's what is going on here?
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    EAT MORE GRIME
    Nov 2013
    Quote Originally Posted by Vancbiker View Post
    yeah that has to be it
    My fenix usb chargeable said I have to use the provided cord to charge it...but
    whew my ordinary phone micro usb does fine.
    I just went ahead and ordered the Niterider brand USB adapter to be on the safe side.
    Sep 2017
    If the adapter/light would be conform with the USB specifications, it would work with every cable/adapter.
    USB charging
    Offering cheap 2 electronics for 10x the price seems greedy.
    https://www.niterider.com/product/usb-ac-adapter/
    Reputation: Arebee's Avatar
    Sep 2012
    I have two Lumina 650s (2-3 years old) and a Mi-Newt 350 (6+ years old) and I've used everything from 1 piece Blackberry chargers (no detachable cord) to iPhone plugs and any cord that's lying around the house. I've also plugged them directly into computers and my car's cigarette adapter via USB. Not once did I have an issue with charging and the batteries are still going strong.
    AreBee
  1. awesome FAKE Samsung USB charger
    By androgen in forum Lights and Night Riding
    Last Post: 08-10-2013, 10:06 AM
  2. USB Charger from light battery
    By baker in forum Lights DIY - Do It Yourself
    Last Post: 07-17-2013, 07:18 AM
  3. AA powered USB charger?
    By J-No in forum Lights DIY - Do It Yourself
    Last Post: 11-02-2012, 01:07 PM
  4. dynamo hub iphone/generic USB charger
    By digilux in forum General Discussion
    Last Post: 08-09-2012, 11:25 PM
  5. BikeCharge Dynamo ( USB Charger )
    By raptor_quasar in forum Bikepacking and Bike Expedition
    Last Post: 05-18-2012, 02:47 AM
