upgrade to gemini duo wider flood?- Mtbr.com
Results 1 to 11 of 11
    Reputation: BmoreKen's Avatar
    Sep 2004
    I'm running a Gemini Duo on my bars with one flood optic and find I still don't have the beam width I'd like for tight and twisty mid-atlantic singletrack. The flood optic dramatically reduces the light output. Considering moving the Duo to my helmet, but then what makes sense for the bars, then? Currently running Glowork X1 on helmet but not uber-impressed with that beam pattern, either.
    Really I just wish the Duo had a wider beam pattern.
    Suggestions?
    Dec 2012
    Quote Originally Posted by BmoreKen View Post
    Suggestions?
    Gloworm X2 with two wide-angle lenses on the bar. You can continue using your Duo on the helmet with two standard lenses for greater throw.
    Reputation: MRMOLE's Avatar
    Suggestions?
    What flood optic are you using? There are several I can think of and they all work very differently. May have a solution for you depending on which flood optic you're using.
    Mole
    Sep 2004
    Quote Originally Posted by MRMOLE View Post
    Mole
    I'm using the flood optic available through action-led.
    This: http://www.action-led-lights.com/col...for-gemini-duo
    This: Wide Angle Lens for Gemini Duo and Xera ? Action-LED-Lights
    OK, I have that optic. Spreads light everywhere (large amount of vertical spread that wastes lumens). IMO the Duo doesn't make enough power to support the coverage area of the optic (very wide but too dim to be useful). I've had better luck using Gloworms X2/XS wide angle optic. It's more efficient than either the flood or stock optic you currently use and while it spreads the beam horizontally it doesn't vertically so your not wasting lumens on coverage areas that don't help you (more efficient + wider horizontal only beam = very little light intensity loss with a wider beam). Using 2 of these optics you'll loose a little throw (your helmet light is a great thrower so you should be covered) and a little light around the front wheel (not sure how important this is to you since I ride in the desert where there are no roots). You should gain a slightly wider beam that's a little less intense in the middle but much brighter at the outside edges (left and right) of the beam.
    Mole
    Gloworm X2 & XS Wide Angle Optic ? Action-LED-Lights
    Sep 2004
    Interesting. I'd actually replaced the X2 with the duo because of recurring issues with the switch wires coming loose. Any others? Magic shine?
    Understand your problems with Gloworm wire/remote. I own 2015 X2 & XS, both had to be warrantied for remote issues (seem to be OK now).
    The new XS spot and wide angle optics however are the best I've run across to date (flood optic that comes with the lights is junk though). The wide angle optic I recommended is nothing like the flood that came with your X2 FYI. Just wanted to make sure you weren't using your X2 to estimate what the beam pattern would look like.
    Mole
    Sep 2004
    Mole
    After I got the X2 back from Action, who promptly took care of the issue, I compared the X2, with the supplied flood optic, to the Duo and decided on the Duo. So I sold the X2 to a friend. Hmmm, I wonder if he's using it...
    Just to be clear, you're recommending the X2 with the wide angle optic you linked, rather than the Duo with the linked wide angle optic? Ideally I could find a good lens for the Duo.
    RAKC
    Reputation: tigris99's Avatar
    Both lights if they have the same optics will have the EXACT SAME beam pattern. X2 just has higher output than the duo (and I think the x2 looks way cooler lol)
    I was suggesting you use the wide angle optic in your Duo. I've run this optic in a Yinding, Duo, X2 V3.1 (only X2 version it will fit), XS, BT21 and it works well in all these lights. You'll be shocked how much brighter your light will be with the Gloworm Wide angle compared to the flood optic your using now.
    Mole
    Sep 2004
    Right on. Thanks. I'll give that a shot.
    BTW, took some shots in the fog this morning that I thought were interesting. You can really see the difference in power coming through the two lenses: normal on the left and wide angle on the right.
    [url=https://flic.kr/p/CbosqP]
  1. Going with wider rim up front but is wider on rear as important?
    By MarkyMarksXC in forum Wheels and Tires
    Last Post: 08-31-2015, 11:38 AM
  2. Any prevailing wisdom on wider rims? (upgrade)
    By db9 in forum Eastern Canada
    Last Post: 03-08-2015, 05:25 PM
  3. Spam flood
    By musikron in forum Site Feedback/Issues
    Last Post: 10-28-2013, 04:34 AM
  4. Replies: 10
    Last Post: 05-11-2013, 12:37 PM
  5. CREE XM-L T6 LED - Can I Get Better Flood?
    By djonesax in forum Lights DIY - Do It Yourself
    Last Post: 02-13-2013, 01:04 AM
