Super easy Bell Super light/gopro mount mod- Mtbr.com
Results 1 to 10 of 10
    Jan 2014
    Idea! Super easy Bell Super light/gopro mount mod
    Hi, don't know if this is the right place for it but maybe it'll help someone.
    I've found it's incredibly easy to mod the gopro mount on top of a Bell Super helmet. You just need a good cable tie and a short rubber o-ring (usually supplied with lights). You will not have any trouble mounting the gopro either.
    I'll let the pictures do the talking, but found that the angle of the light is absolutely perfect. There's little movement as well.
    Album Helmet mount - Album on Imgur
    Super easy Bell Super light/gopro mount mod-1.jpgSuper easy Bell Super light/gopro mount mod-2.jpgSuper easy Bell Super light/gopro mount mod-3.jpgSuper easy Bell Super light/gopro mount mod-4.jpgSuper easy Bell Super light/gopro mount mod-5.jpg
    RAKC Industries
    Jan 2017
    Cool idea. Looks like it works well.
    Vancbiker here makes GoPro mount adapters for the cheap Chinese lights too, not just the brand name lights. Saves modding the helmet mount and their pretty cheap.
    Sent from my XT1565 using Tapatalk
    Life on a bike doesn't begin till the sun goes down.
    Jan 2014
    Thanks RAKC. It's good to have options. Wish I'd have thought of this sooner!
    May 2005
    Quote Originally Posted by RAKC Ind View Post
    .....Vancbiker here makes GoPro mount adapters for the cheap Chinese lights too, not just the brand name lights. Saves modding the helmet mount and their pretty cheap.
    Thanks for the plug.
    Lots of folks with SSX2 (and clones) have converted to GoPro mounting with one of my adapters.
    Name:  gopro mount for ssx2 lighthead.jpg
    This is the ABS plastic option.
    For those in warmer climates, I have an aluminum heatsink version for the SSX2 that reduces light temperature by 10-18 degrees. Lets you run longer on a high setting and not overheat the light.
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    BTW, Looks like that is a MIPS helmet. The way you mounted it you have basically made the MIPS capability nonfunctional which will prevent it from helping prevent concussion in a fall. You will need to have the ties not constrain the yellow slip plane liner in the helmet. Run the ties between the yellow slip plane and the EPS foam of the helmet.
    J.
    Super easy Bell Super light/gopro mount mod-2017-04-18-10.35-am.jpg
    Jan 2014
    Good catch - thanks
    Reputation: bullit43's Avatar
    Dec 2010
    Hi there,i took off my camera support and canīt find any tutorial how to mounting it again,anyone one knows or have pics of how to do it?
    Quote Originally Posted by ButtersNZ View Post
    Very nice mod. Interesting Gopro mount, where did you get that? Never seen one like that before.
    I do have a couple questions; I see the zip tie used to hold the back down but what is holding the front of the mount down? ( adhesive? )
    FWIW you can probably convert the SStorm X2 to Gopro without too much problem. Of course if the O-ring is working for you probably not worth the trouble.
    Dude, you need a better helmet light. The SStorm X2's are so outdated. Not to mention a very narrow beam pattern for MTB helmet use. ( yes I do own an old X2 so I know ). None of my business I know but if you can afford a Gopro camera you can afford a much better helmet lamp.
    Nov 2012
    The front of the mount has tabs that go into he vent holes. However these are rather shallow. The velcro strap is actually quite long and is meant to be threaded through a front hole as well. Take a look at advert pics of the Bell Super 2/R to see the intended (and often not followed) use of the mount.Super easy Bell Super light/gopro mount mod-7059502.jpg
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    I don't like the light on the top of my Bell Super 3 as the visor creates too much of a shadow. I use a Vancbiker GoPro adapter and GoPro slide mount attached to my visor. Light is now out in front of my eyes and super easy to get on and off
    Super easy Bell Super light/gopro mount mod-amoeba-bell-super-3.jpg
    Super easy Bell Super light/gopro mount mod-2-amoeba-bell-super-3.jpg
  1. 3D printed light mount for a Bell Super helmet
    By burbskate in forum Lights and Night Riding
    Last Post: 05-23-2016, 09:45 PM
  2. Super Easy DIY Handlebar Mount for GoPro
    By rbwen in forum Washington
    Last Post: 05-03-2016, 12:21 AM
  3. Bell Super 2R Go Pro Mount
    By Beto10 in forum Apparel and Protection
    Last Post: 12-09-2015, 02:24 PM
  4. My Mod of Bell Super GP Mount
    By root in forum Apparel and Protection
    Last Post: 10-19-2014, 12:37 AM
  5. Replacement Bell Super GoPro mount?
    By kpm700 in forum Apparel and Protection
    Last Post: 08-09-2014, 10:10 AM
Members who have read this thread: 14
