Specialized Flux Expert lights- Mtbr.com
Results 1 to 18 of 18
    Reputation: BrianMc's Avatar
    A review:
    REVIEW: Specialized Flux Expert Bicycle Headlight - Photo Intensive
    Review: Specialized Flux Expert Taillight
    I had a chance to test the same pre-production units used in these reviews.
    SIGNUP HAS ENDED - Pass Around/Giveaway-Specialized Flux Headlight and Taillight
    My last posts have not cleared the moderator, so here is the first of my last two videos:
    In case anyone is looking for new lights and has that kind of scratch ($100 for the taillight, $275 for the headlight).
    BrianMc
    The Second video
    The same section of street where I first tested my lights.
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    ^^Nice lights! I like how the Flux can be run either on the internal battery or with an external battery for more battery life. I could see bringing just the headlight on a late afternoon trail ride (just in case), or on a commute, then using the battery pack on longer (or colder) rides. The taillight looked less impressive.
    Reputation: rogbie's Avatar
    For that kind of money, I'd rather buy something from any other company and not give it to the litigious and unreasonable company that is Specious-ized.
    Quote Originally Posted by mtbxplorer View Post
    It is no Dinotte 300! It is half the price of the new Dinotte Quad Red:
    NEW Quad RED Taillight with built in battery – DiNotte Lighting USA Online Store
    It is also four times the price of my HotShot. So not cheap. The HotShot, Planet Bike Turbo, and (as it is about the same) the PDW Radbot 1000 are at least comparable in a straight line. One on the back of the helmet might be the ticket as the head angle would not be as large an issue. Still, I have no pressing desire to own one.
    Quote Originally Posted by rogbie View Post
    Sorry, I know nothing of this. Do you have a link?
    Bicycle Retailer
    and
    Velonews
    Velonews
    And there are many blog posts dedicated to the ridiculous nature of Specialized's operating procedure:
    Bikeportland
    BikesnobNYC
    etc.
    It's a big history to delve into, but the shady actions of Specialized start at the companies beginning.
    Alize could be confused with Allez? Because it starts with A and is five letters? Really? I could understand "All-A's". Maybe the new name should have been Ahsol. Or: YGTBKMe. The Volagi fiasco seems a disgraceful way to bully former employees who disclosed all on departure. Drop the "iz" and it is Special ed. CB may have that right. Too bad it is a nice light.
    Jan 2014
    I am a recent purchaser of this light and very happy with it. For me wi even the 400 lumen low setting is perfect for my commutes. My biggest selling points were;
    Its all self contained
    Easy on easy off and can centrally mount
    wide beam pattern
    Gripes are;
    wish it had either a 600 or 800 lumen steady output
    extra mounts are $45 cdn so
    Jan 2014
    Now that I have used the light for a week I have an issue with battery life. After 30 minutes of use at 400 lumen setting the battery indicator is red, meaning less than 20%. This is troubling because on that setting it should get 6 hours. Though my commute at night isn't long enough to fully drain it.
    ^ Even under cold temps, that is not expected. I assume the charger is bringing it up to 8.4 volts (2 or 4 cells), or 11.6 (3 cells), or 12.8 (4 cells) whatever that pack is? If it is then it sounds like it is time for a fix under warranty. I ran one at about 20 F at the highest setting for over two hours without a recharge. Now you get to find out if they are as good as Dinotte or Cygolite in warranty work. Since they are pricey Specialized should be at least as good.
    Fen
    Fen is offline
    Mar 2014
    I have both the front and rear. The front I am pretty happy with. It's not as amazing a beam as the reviews I read made it out to be, but it's as good as anything else I've used. The hi / low beam is a bit of a gimmick I'd say as you really don't see much further / better with high beam on than with low in my non scientific tests. It's nice to have some confidence it isn't being obnoxious to other people when it's aimed at a useful height however.
    The rear is a different story. First one I had turned itself off during a ride 3 out of 5 times I used it. Battery level was fine as I'm talking 2 x 45 minute commutes and one 1.5 hour ride for fun (and charging it between), and it happily turned back on with a green battery indicator colour every time.
    I returned it to the LBS and they replaced it saying it was a fault with the light sensor. The replacement is better in that it's remained on for all but 2 of about 6 rides. This morning on the way to work I used a different mode (not the automatic light-sensing one) and it was off when I arrived. I'm calling that out as useless, so it'll be going back to the LBS again tomorrow. I'm not sure if I want to try another one or just go for a refund - I'll probably wait to see what they suggest.
    Overall after a handful of weeks with them I'd say the front isn't worth the money and the rear is junk (based on current experience). If I do get another replacement and it's fault-free I'll try to remember to post back as it's a nice light and my review would be totally different if it offered the basic functionality of remaining in operation until turned off or the battery runs flat.
    Note that the tested model was a pre-commercial example. I can't say whether it is representative. I did not use them long enough to pick up your sort of issue. The cyclist who won the pair, has not reported on his use over the last 6 months.
    Performance-wise I like my HotShot better than this tail light and my DIY taillights blow it away.
    May 2015
    Been running the flux expert and tail light for 3 night rides now. I'll say this on high I've got no problems riding at night. Heck on trails I've never ridden it was remarkably easy to find the trails by head light, was actually harder the next day.
    The remote is nifty, but honestly I might just stop using it. On trails it's difficult to tell the difference between Lo/high and high/low. More of a gimmick. I just want low, high, pulse and flash. The light horn is cool.
    The one thing I did find pleasantly surprising is that to conserve battery I was able to run the pulse setting on double track and smooth single track trails with no issues.
    Bicycle Retailer
    and
    Velonews
    Velonews
    Bikeportland
    BikesnobNYC
    etc.
    That sort of puts Trek into the same company: Trek Sues CA Winery for Use of Name | Bicycle Retailer and Industry News
    TREK Bikes v CROSSTREK Cars Trademark Blog
    And Trek does the same thing as Specialized does by bullying the dealers into not selling other top line brands; for example Trek doesn't want their dealers selling Specialized, or Cannondale, and they have to carry Trek related line of companies products which is why you see Electra brand of bikes in Trek stores as well as Bontrager and LeMond.
    And then there's this: Trek
    So what you're saying is we need to also avoid Treks?
    SO WHAT Specialize and Trek does this? it's nothing different then what a car company does to their dealerships; it's nothing different then what a car company would do to a small non related company using one of their names on a their products. Clint Eastwood sued Eastwood insurance agency for using a cowboy image, an image that looked nothing like Clint, but since it was the image of a cowboy along with the business name Mr Eastwood sued and won. This sort of stuff goes on all the time, if you stop buying from companies that do this sort of thing you'll be buying very little of anything.
    Sep 2017
    Idea! Flux Elite StVZO Headlight
    Besides the in-development version of the Flux Elite and Taillight meeting the german StVZO regulations there's a kickstarter project for a similiar lamp with external battery (and DC5521 plug like magicshine).
    specializedeuropebvhelp.zendesk.com/hc/de/sections/202726689-Beleuchtung
    specialized.com/de/en/flux-elite-stvzo-headlight/p/130646?color=220115-130646
    specialized.com/de/en/flux-expert-stvzo-taillight/p/130523?color=220459-130523
    forums.mtbr.com/lights-night-riding/outbound-lighting-focal-series-discussion-1055278.html
    I read that early Flux Experts had battery issues. The use of newer high efficiency LED's to compensate for the mirror losses makes the OL light interesting.
    Reputation: Outbound's Avatar
    Aug 2017
    Quote Originally Posted by angerdan View Post
    Thanks for the shoutout!
    Direct link to the project is here: https://www.kickstarter.com/projects...sting-bike-lig
    OutboundLighting.com
    Professionally Engineered LED Bike Lights
    Assembled in Chicago, IL
  1. Turner Flux v. Specialized Camber
    By AceMulder in forum Turner
    Last Post: 06-02-2014, 10:48 PM
  2. Specialized Vice vs. Specialized Tactic vs. Fox Flux vs. 661 Recon
    By Innota in forum Apparel and Protection
    Last Post: 12-31-2013, 06:45 AM
  3. Replies: 10
    Last Post: 06-23-2013, 01:08 PM
  4. Turner Flux or Specialized Epic Carbon
    By Jackbflyin in forum XC Racing and Training
    Last Post: 10-09-2011, 03:00 PM
  5. Replies: 10
    Last Post: 08-05-2011, 08:33 AM
