Sizing help please- Mtbr.com
Results 1 to 3 of 3
    Downcountry AF
    Reputation: blaklabl's Avatar
    Mar 2011
    Sizing help please
    Hey gang, I need some guidance.
    I run some “retro style” handlebars on my singlespeed that have a cross brace. The space between the “bar clamp” portion and the cross brace (available space” is 2”). I need a light that will fit in there with at least a little room to spare, so it doesn’t tap against the brace in rough terrain. My MS 872 barely fits, but I was looking for another light as it seems to have developed a short and cuts out intermittently.
    The new Magicshine lights just look taller/too tal to fit in there when you factor in the bar mount, but maybe I’m wrong. I have no way to verify that because no one sells them locally. One other important point is that the bars are a 22.2mm diameter, so 25.4 and larger bar clamps won’t fit because I can’t shim them up tight enough to prevent movement. I’ve had the most luck with o-ring type mounting.
    Looking for something in the 900-1500 lumens range, around $150 with a battery. I’ve attached a couple pics that maybe you can visualize better. Thanks for any advice you can give ~
    If anyone has a picture with a 902/906 next to an 872, even better.
    Sent from my iPhone using Tapatalk Pro
    MTBR: Your dad's online mountain bike forum.
    May 2005
    If you get a 902/906 light you can convert it to GoPro mounting.....
    http://forums.mtbr.com/lights-night-...tml?highlight=
    and use it with this mount....
    For a perfect fit on your 22.2mm bars.
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    Downcountry AF
    Mar 2011
    Sorry, I just realized my pictures from Tapatalk didn't upload to the web, fixed original post.
  1. Replies: 8
    Last Post: 10-06-2016, 06:56 AM
  2. e-sizing help please...
    By ferday in forum 29er Bikes
    Last Post: 09-16-2012, 06:43 PM
  3. Met Parachute helmet sizing help please
    By peligro in forum All Mountain
    Last Post: 06-25-2012, 07:39 AM
  4. Switching frames, sizing help please
    By Boberinoe in forum 29er Bikes
    Last Post: 04-17-2011, 03:27 PM
  5. Sizing Help for 26er Fly TI, Please!!
    By myitch in forum Motobecane
    Last Post: 01-06-2011, 05:34 AM
