self contained Helmet Light- Mtbr.com
Results 1 to 9 of 9
    I just bought the solar storm2 and for $30 it works great. I would like a helmet light but without running a battery back to my camelbak. Are the self contained bright enough only need 2 hours of light max.
    lamer
    Reputation: llamma's Avatar
    I have what I believe is the Lezyne Super Drive XL. It is super bright and lasts +2 hours on the lower setting. It works great as a helmet light because the beam is very focused. I actually use it only on the lower setting as the focused beam can make the darker areas outside of the beam hard to see at the highest setting. It wouldn't work very well on the bars while mtn biking, but I do use it for commuting that way. It's not overly heavy, but it is noticeable when mounted on my helmet. The "Loaded Box" version comes with the helmet mount and extra battery, along with the normal 2 handlebar mounts.
    Lezyne - Engineered Design - Products - LED Lights - Super Drive XL
    Thanks for feedback, however I do not see a helmet mount that come with the lezyne
    lamer
    If you buy the "Loaded Box" version it comes with a helmet mount. From the description on the website:
    "It is also available as part of a Fully Loaded package with CM handlebar mounts, a CM helmet mount, a spare battery pack, a Micro USB charging cable, and CM storage case."
    If you want just the light you can buy the mount separately here: Lezyne - Engineered Design - Products - LED Lights - Composite Helmet Mount (XL Lights)
    May 2005
    You ought to check into the Amoeba light made by Scar on this forum. It is not "self contained" but has a battery pack on a short cable. Mount the light toward the front of the helmet and the battery toward the back. Might have better balance that way. It also sits lower on the helmet than the all in one lights, it is really tiny.
    Amoeba - The simplest "light" form
    Action LED Lights
    Reputation: Action LED Lights's Avatar
    Have you though about something like the Gemini XERA or Gloworm X1? With a 2 cell battery mounted on the back of the helmet they are a great light weight setup with 950 lumens and 2 hours of run time.
    Jim Harger
    Action LED Lights
    www.action-led-lights.com
    Exposures Diablo is what I use for night riding.
    I bought a solar storm 3 and put that on the bars and using the solar storm two for my helmet the 2 of them worked great together however the solar storm 2 is not self contained
    Apr 2014
    How much is solar storm 3 ?
  1. Best Self-contained Tail Light
    By Lugano in forum Lights and Night Riding
    Last Post: 06-23-2014, 12:55 AM
  2. Which self-contained single 18650 with proper mount bike light?
    By am7 in forum Lights and Night Riding
    Last Post: 05-06-2014, 11:44 AM
  3. My short search for a self-contained commuter light
    By pigmode in forum Lights and Night Riding
    Last Post: 01-18-2014, 11:33 AM
  4. Self-contained rechargeable front light for roadbike
    By Flyer in forum Lights and Night Riding
    Last Post: 10-09-2013, 08:18 PM
  5. Self contained helmet mount lights for commuting
    By ese002 in forum Lights and Night Riding
    Last Post: 09-20-2013, 08:37 AM
