Sanguan K20 2000 lumen- Mtbr.com
Results 1 to 18 of 18
    Reputation: RS VR6's Avatar
    Picked up a set yesterday. Mounted them up real quick. Just by handling them...the quality of the lights look pretty nice. It comes with the typical accessories that lights come with. Battery is pretty big. It uses a dial strap type mount to attach the light to the bar. Also comes with the rubber band type mount also.
    Haven't used it yet. Going to put it on the road bike and testing it out in a few hours.
    Edit...
    Found some specs.
    LED Lamp: 2pcs CREE XM-L2 U2 LED
    Max Brightness: 2000 Lumens
    Power Supply: 4400mAh 4-cell Rechargeable Battery Pack
    Mode Settings: 10%-40%-70%-100%
    Running Time: 20H-15H-4H-2H accordingly
    Body Material: Alloy
    Charge Time: 3 - 4 hours
    2 Hours on full brightness
    Green/Blue/Red light indicate battery level
    Protection for shortcut and overcharge
    Cold resistant/waterproof wire connector
    Got a chance to use them tonight. The light pattern seems pretty good. At least better than the Sefas TL500 and Niterider MiNewt I have. The aluminum button is easier to press on the fly than the silicone buttons on my other lights. Lights have four settings.
    This is at full power. Lol...maybe I should have aimed the light higher.
    I don't know why I say this but judging from the top button ( on the lamp ) and the front of the lamp...I'm guessing these are BT21 clones ( although the lamp body is obviously different )
    Yeah, I hope it's pointing down because otherwise that would be a lousy output from a lamp claiming to supply 2000 lumen.
    Button on the BT21 looks like it's got a rubber cover?
    The light was aimed low. I'll try and go out to the same spot and raise the light higher. Plus the camera on the Nexus 5 sucks. The beam seems to be a bit narrow? I don't have much experience with lights...so I don't know what's really good or bad. I picked them up at Interbike.
    Few more detail pics.
    Green is high, Blue for mid, and Red for low battery.
    RAKC
    Reputation: tigris99's Avatar
    I looked at the price tag for it.....$147???? Better be close to 2k lumens and brand name cells in that pack cause your pics of included bits is what comes with the cheap Chinese lights too. Head, battery and handlebar mount are the only places that can justify extra expense.
    Btw they usually have apps that improve the camera so you can fully adjust settings. That hoe I do beam shots, with my phone and the app that allows me change everything to better see the full beam effect.
    Jan 2013
    Quote Originally Posted by RS VR6 View Post
    Looks nice and bright, but yeah you should aimed it a bit higher.
    Aug 2013
    Could you please comment a bit more about the battery, please? On the last picture, it looks like the case is easily accessible: four point at the corners resemble screw holes covered by rubber plugs...
    Yes, the BT21 button is silicone covered. It is a bit spongy but I've not had any problems with the one I have. Then again I haven't used it a whole lot.
    Hard to tell from the photo, is the lamp using mini reflectors or optics? If mini reflectors that might explain if the beam pattern is a bit narrow. (?)
    The wires in the rear of lamp look very stout although there does appear to be quite a bit of extra wire. The battery pack looks like it is housed in a hard shell similar to what DiNotte does with their batteries.
    Quote Originally Posted by -Archie- View Post
    I pulled one of the spongy covers out and there is a screw hole under it. I didn't take it apart though.
    Maybe the cells inside can be replaced/upgraded?
    I don't usually press the button too often when I ride. It's something I noticed on my test ride when I kept switching modes. The aluminum button took less pressure press. No big deal.
    I have no idea when I look at the reflector on what type it is. To me it's chrome and shiny.
    The cable does seem pretty long. I have yet to unravel the cord on the light. The one on my MiNewt is crazy short. Like stem to bar length short.
    Pic of the bottom of the light. Its got a spring loaded button to release the light from the mount. It also comes off so you can switch to a mount that uses the rubber bands.
    The top of the battery. Its got a recess on top. Like a spot for a brand label to go.
    Couple more night shots. My neighborhood isn't dark enough.
    Light pointed higher...haha...
    You can see the light on the side of the house in front of me.
    The Garmin casts a pretty big shadow.
    Aug 2013
    Thank you!
    Seems so. It would bi nice to find this battery as a separate item then.
    BTW, manufacturer says it's possible to put Samsung cells on request...
    RAKC
    for the price tag and they dont have brand name cells????
    Aug 2013
    No. But they claim only high-quality cells are used, though:
    Bike Light Battery Pack Full Lists from Sanguan
    Each bike light battery pack from SANGUAN is built with Class-A battery cells. Each battery cell is 2200mah in capacity and 3.7v in voltage.
    Probably, the same BAK ones as MagicShine is using...
    RAKC
    I do have to say the pointed up pick the output looks alot better. Wish these companies would figure out what only a few have, ditch the cool white emitters.
    Reputation: targnik's Avatar
    Jan 2014
    I own one of these and love it ^^
    I use it on my helmet... I have a USB chargeable 350 lumen light for handle bars (and back up)
    Sent from my Kin[G]_Pad
    "Mountain biking: the under-rated and drug-free antidepressant"
    Mar 2011
    Are the batteries user replaceable?
    Jan 2014
    Quote Originally Posted by Pilsner1 View Post
    Yup
    Sent from my LG-V500 using Tapatalk
    RAKC
    Cells are not changeable inside the case, you can use other battery packs but not replace the cells inside the pack.
    And tbh. There is a lot better lights out there for the money. I had one of these and gave it away because these suck compared to other $100 lights.
    Sent from my XT1565 using Tapatalk
  1. Sanguan sg-t2200 problem
    By murrdogg11 in forum Lights DIY - Do It Yourself
    Last Post: 01-14-2015, 10:26 PM
  2. Watt vs Lumen
    By Cajun Rich in forum Lights and Night Riding
    Last Post: 11-08-2013, 01:37 AM
  3. Lumen Question
    By 2HEAVY in forum Lights and Night Riding
    Last Post: 09-22-2012, 09:41 AM
  4. 800 Lumen MCE light from DX
    By ozlongboarder in forum Lights and Night Riding
    Last Post: 01-31-2011, 09:45 AM
  5. lumen meter?
    By Goldigger in forum Lights DIY - Do It Yourself
    Last Post: 01-20-2011, 07:56 PM
