Replacement battery to mount on helmet- Mtbr.com
Results 1 to 2 of 2
    I quit e-MTBR
    Reputation: OldManBike's Avatar
    I bought a Yingding (this) that I have mounted on my helmet. I've been using the stock 4-cell battery attached to my helmet (cord's not long enough to reach my pack). That's not an especially delightful set-up for obvious reasons, so I'm finally getting around to looking at a better battery set-up, but I'm no light guru.
    I see 3 options:
    - an extension cord,
    - a new 4-cell battery with a longer cord, or
    - a new 2-cell battery mounted to the helmet
    Assuming I go the 2-cell-battery-on-the-helmet route, is this a reasonable choice?
    MJ-6008 2200mAh Waterproof Battery – Action-LED-Lights
    RAKC
    Reputation: tigris99's Avatar
    All depends on the run time you need. That magicshine pack is low on capacity so yinding at best will run around an hour on full charge. Good pack, just low capacity.
    If you need more run time, 3400mah 2 cell will give you 1.5+hrs run time. More than that your looking at an extension cable. You wont find a pack with cord long enough to go to jersey pocket.
  1. Replies: 1
    Last Post: 02-09-2015, 11:34 AM
  2. battery pack on helmet
    By ImaginaryFriend in forum Lights and Night Riding
    Last Post: 01-10-2015, 12:06 AM
  3. Tripod mount Contour Roam 2 onto Magicshine helmet mount?
    By khaytsus in forum Videos and POV Cameras
    Last Post: 07-31-2013, 06:35 PM
  4. Custom helmet mount for magicshine mj-880 using go pro mount
    By awareham83 in forum Lights DIY - Do It Yourself
    Last Post: 12-27-2012, 05:13 PM
  5. Light AND battery on helmet
    By xjbaylor in forum Lights and Night Riding
    Last Post: 01-04-2011, 04:26 PM
