Post pics of your helmet/light setup.- Mtbr.com
Results 1 to 50 of 50
    It's a Nightfighter bt21. I was planning on trying mine tonight, at least enough to get the light pointed in the right direction. But, it's raining here in So. Cal., go figure. It like never rains here in the summer.
    Reputation: Ofroad'bent's Avatar
    Here's my Yinding with Vancbiker's GoPro mount and low profile mounting
    Small 2-cell pack mounts on the back of the helmet. I have a Hunk Lee pack and also some Fenix 2-cell battery cases.
    Come on guys, let's see em!
    May 2005
    Dual XML light with LEDDNA optics. ~65 grams including mount and remote switch. Running at at 3.5A on high so ~1800 lumen. Gets the job done.
    Attached Thumbnails Attached Thumbnails Post pics of your helmet/light setup.-dscn1079.jpg
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    RAKC
    Reputation: tigris99's Avatar
    Depends on the weather as to which one i use, but the bt21 balances out the pack better. Since yinding is modded though both push about the same light. But its restricted to cool weather only cause it get HOT fast.
    Apr 2014
    Appel's setup from the Yinding thread deserves mention here.
    Original/Real Yinding YD 2xU2 found - Page 33- Mtbr.com
    Hope he doesn't mind me reposting one of his images:
    Inspired me snap up a Giro Fathom helmet on ebay the other day - Thank You Appel! (The Fathom is the same as the Atmos, but with a removable MTB style shade added).
    Quote Originally Posted by Vancbiker View Post
    You are the king of low-profile lighting!
    Reputation: arphaxhad's Avatar
    Attachment 1004072
    Dual MJ-808 on homemade mount, batteries in waist mounted hydration pack.
    Just to note, The 808's are kinda spotty, and the exposure meter on the GoPro can't compensate enough so the center is washed out, so when I film at night, I have to put wide angle lenses on to get pretty good results
    Trial LED XXX
    1700 lumens
    Post pics of your helmet/light setup.-uploadfromtaptalk1438302985843.jpgPost pics of your helmet/light setup.-uploadfromtaptalk1438303020321.jpgPost pics of your helmet/light setup.-uploadfromtaptalk1438303049975.jpgPost pics of your helmet/light setup.-uploadfromtaptalk1438303084084.jpg
    =Tapatalked on the go=
    Reputation: Rakuman's Avatar
    Post pics of your helmet/light setup.-img_20150731_102620334.jpg
    I always type in bold cuz I'm blind as a bat
    For the Rich there is therapy!!!! for the rest of us we have Mountain Biking
    Reputation: garrybunk's Avatar
    Feb 2014
    Finally got my helmet light mount situation figured out. I used one of these GoPro style "wrist mounts" (seems Rakuman is using the same strap). Here's my BT21 mounted:
    Still have to do the battery pack. Thinking Fenix two cell case with velcro attached to it & helmet in addition to a velcro band wrapped around it. (These velcro bands are so convenient to have on hand!)
    -Garry
    "My Bike Lights" Thread on BLF teardowns, measurements, and beamshots. Moving my photos, PM or post up if you can't see them.
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    Night owl, where is the battery? Do you have a picture of the battery?
    Aug 2015
    My BT21 mounted on my MET Parachute using the standard velcro helmet strap. I keep the battery in my pack. With the FF helmet, I do not even notice the weight of the lighthead on the helmet.
    I also use the light on a Giro Feature trail helmet for rides on trails that are not as high consequence as my usual local ride. The Feature has few vent holes, but it does mount fine.
    I use a pair of Cygolite Expilion 700s on my bars to compliment the BT21 helmet light.
    Post pics of your helmet/light setup.-img_0599.jpg
    Jan 2013
    as posted on another thread: quad XP-L Solarforce L2P 2800 lumensPost pics of your helmet/light setup.-helmet-light.jpg
    smartass
    Reputation: amish_matt's Avatar
    My new setup, Gloworm X2:
    Post pics of your helmet/light setup.-img_1160.jpg
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    Dec 2009
    Quote Originally Posted by amish_matt View Post
    How did you fix the mount to the helmet? Double side tape? 3M velcro?
    smartass
    It's a GoPro mount, uses the standard double sided tape.
    I like turtles
    Reputation: TiGeo's Avatar
    Mine. Gemini Xera with a GoPro mount. The POC makes this a little challenging with the MIPS but I just fed the strap under the MIPS and it shouldn't impact it's functionality. I also could use an adhesive mount on the front but I think the shape of the helmet and vent design will make that difficult.
    Post pics of your helmet/light setup.-uploadfromtaptalk1447197051344.jpg
    Sent from my SM-G900V using Tapatalk
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro AF
    Can I ask you guys why/how are you running the battery packs on the helmet? Isn't that unGodly heavy?
    I've always put the battery pack in a back jersey pocket, poked a small hole through the back of the pocket and run the cord up the inside of the back of my jersey, out the neck and to the helmet light. No cords flopping about in back of you.
    Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
    smartass
    Two cell packs are plenty slim and light, it's no problem. I prefer the freedom of not having a cable running from my helmet to my pack/jersey.
    I like turtles
    I would think a 2-cell would be fine on the helmet but 4? Noway. No biggie to toss it in my jersey pocket and run the cord down my back inside my jersey.
    May 2005
    Post pics of your helmet/light setup.-lights.jpg
    Gloworm on the helmet and a Gemini Olympia on the bars (I only run one at a time, 2 is overkill)
    Reputation: patski's Avatar
    Dec 2005
    Dec 2005
    Quote Originally Posted by TiGeo View Post
    I'd hate to fall on a 4cell in my jersey pocket, anyone make a "nice" 4 cell flat pack for 5.5mm connectors?
    I like turtles
    ^^^I'd hate to fall on one attached to my helmet....but agree a flat 4-cell would be great!
    Feb 2014
    Someone recently posted one found on Ebay that was a flat set of "use your own cells" type complete with protection circuit, but it had no case or anything.
    -Garry
    Feb 2015
    I'm sure some of you guys have seen videos by "Rinoa Super-Genius" before, he tears apart a lot of laptop batteries for 18650 cells, but he also made an interesting helmet light!
    https://www.youtube.com/watch?v=2UkGZyb1maY
    Highly amusing :P
    Light freak
    Jun 2005
    Post pics of your helmet/light setup.-amoeba.jpg
    Let's keep this going. Here's a BT21 on a Met Paradhute. It seems to be aimed in the right direction when I'm wearing the helmet. I'll try it tonight.
    Aug 2015
    Nice low profile solution! Here is how I have mine mounted using the stock O-ring base, in case the Velcro winds up not working for you long term. My range was too dirty for staging a pic though, so the coffee table will have to do
    It takes some careful persuading to get the O-ring mount situated without damaging the visor, but once installed it is bomb-proof. It leaves some flexibility for vertical aim.
    Post pics of your helmet/light setup.-img_0851.jpg
    Post pics of your helmet/light setup.-img_0852.jpg
    Quote Originally Posted by Mentor View Post
    Oh yeah, I see how you did that. That's a pretty good idea. I must ride with my head down, I don't feel like I do, but I have to aim my light pretty high to keep light on the trail. I did a test ride last night and it all went well. This picture is a BT21 on my helmet and a BT70 on the bars, with the diffuser lens. I'll try the other lens next time.
    May 2005
    @Mountain Cycle Shawn and Mentor;
    Great improvements over the setups you posted earlier in this thread.
    Reputation: MRMOLE's Avatar
    Newest helmet set-up. Ituo XP2, very nice light with extremely good GoPro style helmet mount included as part of the light kit (XP2 & XP3).
    Not sure if they sell or are planning to sell this as an accessory, but they should.
    Mole
    Post pics of your helmet/light setup.-001.jpg
    Post pics of your helmet/light setup.-003.jpg
    May 2005
    Quote Originally Posted by MRMOLE View Post
    Mole
    Nice looking mount! Will it mount further forward, say just above the visor?
    Depends on where the vent holes are on your helmet. Would have mounted just behind the visor if I'd used the next forward vents on this Kali. Mount is LowPro style so keeps the light as low as possible wherever you mount it.
    Mole
    Light freak
    Jun 2005
    Post pics of your helmet/light setup.-image-1-.jpg
    Post pics of your helmet/light setup.-image-2-.jpg
    Quote Originally Posted by scar View Post
    Oh, I like that! I wonder if I could take the cover off my battery, plastic dip it and mount it like you did?
    Dec 2005
    Quote Originally Posted by Mountain Cycle Shawn View Post
    Yes, It works great, I also put a piece of double sticky velcro on it and my helmet.
    I like it!
    NightRider
    Reputation: gipsyman's Avatar
    Nov 2014
    Gemini Olympia mount
    On my helmet I have a Noctigon*XP-G2*S3*3D triple board in a Gemini Olympia with a polished lens. It is attached to the helmet with a 3/16" machine screw through a short GoPro mount to the Vancbiker mount. I run a power cable inside my jersey to a 4 cell battery in my backpack or fanny pack. A Gloworm XS from ActionLed is on the bars.Attachment 1083282Attachment 1083283
    A little update. I bought a Cateye Loop Combo Commuter Light Set and modified the red light a little to go on the back of my helmet.
    This is my old setup - three sets of good old Troutie lights - but have swapped that all for just one really powerful bike mounted light
    Post pics of your helmet/light setup.-5679781150_5d5f87f97a_z.jpg
    Reputation: Zomby Woof (MCM700)'s Avatar
    Here's mine. It's a Serfas True 1000. I got it for a bargain price too from Jenson USA at $119. Anyway, I keep the battery pack in my camelback.
    RAKC
    Man those are big ass lights for so little output. Look cool but the Ituo xp3 and glowworm xs do so much more for the size
    Sent from my XT1565 using Tapatalk
    MTB Addict
    Quote Originally Posted by tigris99 View Post
    But what about for the price? More lumens can be nice, but when you get a really good deal on something that's good enough, take it. I managed to snag a pair of the 900 lumen Sigma Powerled Evos for $80 each recently. They could be brighter, but they're enough light, they have good runtime and they were cheap.
    RAKC
    Even for the price you can get a bit more lumens in a lot smaller light. Not saying anything bad about the lights, just that so much is out there now for those prices and those sizes. That serfas is huge and heavy compared to most lights these days.
    It's not just about lumens, at least to me, but weight and size play a big part for me too. I'm glad I got into night riding when products tech had evolved into what I have now.
    Nothing wrong with catching a sale, but a monster light like that serfas, on the lid for that little output and such with that form factor makes me thing "no way in hell" lol. But hey if it works, it works. Though with my neck, the smaller/lighter triples and a 2 cell pack are pushing it. And forget a 4 cell or having a GoPro on the lid with the light. Neck pain and headache shortly after first rough section.
    MTB Addict
    I agree with that being a lot of weight on the head. I'd probably snag something like that on sale to use on the bars, but find something lighter for up top.
    try the TrailLED XXX . It's about 70gms
  1. Amoeba helmet light on a POC helmet
    By scar in forum Lights and Night Riding
    Last Post: 04-30-2015, 01:46 PM
  2. Good Helmet light to pair with my bar light?
    By walkman in forum Lights and Night Riding
    Last Post: 11-25-2014, 06:36 PM
  3. Good light setup? MJ-880 + helmet mounted light?
    By Muffinhead in forum Lights and Night Riding
    Last Post: 11-07-2012, 11:10 AM
  4. Pics of your 1 by setup
    By MTB-fanatic in forum Cyclocross
    Last Post: 07-25-2012, 01:07 AM
  5. Share your Light Setup (Pics)
    By Metacomet in forum Lights and Night Riding
    Last Post: 03-15-2012, 08:23 AM
