One 1100 light vs two 800 lights- Mtbr.com
Results 1 to 6 of 6
    Wondering if it is better to go with one 1100 lumen light vs two 800 lumen lights. I am looking at the cygolites for what it is worth. I am done with cables and want self contained. Whats your opinion? 1100=$65 and 2x800=$85....
    Downcountry AF
    Oct 2013
    2x800's, no question. One on your head, one on your handlebar.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    What onepseed said. Also if a light fails you wont be in the dark. Always 2 lights
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Oops. I forgot to mention, I have a helmet light, these are for my bars. Thanks. Jeff
    Reputation: MRMOLE's Avatar
    Quote Originally Posted by telejefe View Post
    Problem with most high output single cell self-contained lights is the battery capacity is similar to the less powerful ones and they trade higher initial output for poorer performance in the later parts of the run cycle (Bontrager Ion 1300 is one exception though). The 2 800's will have higher initial output but also maintain the outputs consistency much better than the single 1100 with the only drawback being price and double the weight. Here's a couple of output vs. runtime graphs than might be of interest to you and a link to the site where you can compare other lights they've tested.
    We Test Lights | Technical Comparison |
    Click on graphs to expand!!
    Cygolite and Bontrager products generally do well in output consistency but every light model is a little different so best to check the exact model your looking at (if it's tested here).
    Beam pattern is also a major consideration. I've ridden with people using Luminas and they have a nice fairly wide beam for a single emitter light although I much prefer my Ion 1300 (wider and more throw). Cygolites I've seen have been pretty narrow focused but they've been the commuter models. I wish I had more information on this for you but you should be able to at least shine whatever your considering around the parking lot of your LBS to get an idea of what to expect. Would confidently recommend the Bontrager Ion 1300 though it's a little more expensive ($100 retail) or another option you might like is the Ravemen PR1200 (Dual emitter/dual cell 1200 lumen self-contained light with a full 2 hr. runtime and a nice wide beam @ $90).
    Mole
    https://www.rakclighting.com/collect...led-bike-light
    Good info. Thanks for the responses.
  1. Replies: 28
    Last Post: 05-13-2016, 01:09 PM
  2. Replies: 5
    Last Post: 12-03-2015, 03:36 PM
  3. Two Days....Two Rides....Two Vids
    By Jaydude in forum Colorado - Front Range
    Last Post: 03-08-2011, 05:37 PM
  4. AM/CX Any way to part one out for $1100?
    By ajmongoose in forum Bike and Frame discussion
    Last Post: 03-12-2007, 08:09 PM
  5. Lights Lights Lights
    By alizbee in forum Lights DIY - Do It Yourself
    Last Post: 02-09-2006, 10:14 PM
