NiteRider Sol Charging issue- Mtbr.com
Results 1 to 3 of 3
    Reputation: amillmtb's Avatar
    Jun 2005
    I am having a problem with my Niterider Sol light and the charging process. When I plug in the charger the red "charging" light turns on, but goes off after about 5-10min even though the battery is still plugged in. I recently got a new charger because I misplaced the original, but it is the same one (Sol/SolMate). Has anyone else had this problem with your light? If so, how did you fix it?
    Thanks for your help!
    I have the exact same problem. Unit worked great last year, but after summer storage I'm only getting a light indicator for the first 15 min after connecting to charger. If I leave battery on charger for full 8 hrs I only get about 20 min of light output then fades quickly.
    I have contacted NR and waiting for response. From everything I read on their site, this battery does not need any conditioning.
    Reputation: zen bicycle's Avatar
    If it is a NIMH battery and It sat unused all summer it could be dead. If li_ion it could be the PCB or a dead cell causing the charger to think it is charged.
    Either way sounds like a new battery pack is in the future for you.
