NiteRider Lumina 1200 Boost- Mtbr.com
Results 1 to 67 of 67
    Anybody using those? I'm thinking about purchasing this light,but I'm not sure if they are good enough for using in the trails. I'm not planning on doing long night rides . I only intend to use them to extend rides a little beyond sunset time and to ride back home trough bike paths and fire roads. Long time ago I had the NiteRider blowtorch HID that I used for the ocasional 24 race. How would you compare both? I'm sure light technology has improved a lot in the last 15 years or so... Anyway, I guess I'm trying to decide if the Lumina 1200 is good enough to use on the trails or if it is only useful for road/commute.
    Aug 2010
    I have two 1100 boosts and they are well made and work fine. They are cool white led's, I am going to try a more neutral light to see if I can get better contrast. Mine are good for about 3 hours at half power FWIW.
    Jun 2013
    I just got it, but haven't tried it out on the trails yet. I'm using it mounted on my helmet and it seems kind of heavy but definitely seems bright enough. For the trails I'm going to use to in conjunction with a handlebar-mounted light, but for urban rides I'd probably use the Lumina only.
    Aug 2005
    Quote Originally Posted by Pilas View Post
    The 1200 is a decent bar mounted light for the purpose you mentioned. It’s too heavy for helmet in my opinion. A 1200 on the bar and 850 micro on the helmet is a nice combo for inexpensive single cell all in one lights.
    Aug 2005
    Quote Originally Posted by matadorCE View Post
    Makes a much better bar light. Get an 850 micro for the helmet. Much lighter.
    Reputation: MRMOLE's Avatar
    For your intended usage this light should work fine. I don't own a Lumina and am not a big fan but they seem to be well liked by their owners, are inexpensive, and backed by a solid company with excellent customer service. Personally not being particularly impressed their beam pattern from riding with some Lumina users and from testing I've seen here's some links I think might be of value to you. First one is to a testing site that shows runtime vs. output and important if your considering the Lumina 1200 or any other single cell self-contained light. Initial output may be fine but dims gradually (or rapidly in the case of most of the Lumina lights) as battery charge diminishes.
    We Test Lights | Lumina 1100 Boost Test and Review
    If you plan on using the light helmet mounted and want self-contained (not my preference) I would Look at the Bontrager Ion 1300 ($100) + helmet mount ($20). I'm currently testing this light and it has a much more stable output throughout it's runtime + excellent output + a much smoother beam that's a little wider (compared to any Lumina I've seen).
    http://forums.mtbr.com/lights-night-...a-1086506.html
    If you plan on using your light bar mounted I'd look at the Ravemen PR 1200/900 ($90/$75) or Ituo Wiz20 ($120). The 2 Ravemen lights have very nice beam patterns that work excellent for bike paths and off-raod. Wiz20 makes a little more power, has adjustable beam via changeable optics and programmable presets. Having 2 battery cells gives all these very stable output till the very end of their charge which is over 2 hrs for all of them.
    https://www.rakclighting.com/collect...emen-pr-series
    http://forums.mtbr.com/lights-night-...a-1056844.html
    https://www.amazon.com/gp/product/B0...p_bw_cr_x__a_w
    Mole
    Reputation: sturge's Avatar
    I've been using Lumina's for years...started out with 600 lumen model, had a 750 and now a 900. I'm in New England and only use them in cold fall/winter temps using helmet mount. They are fine for my tight, wooded singletrack rides of about 2hrs. Been meaning to get a 'micro' version for helmet and put the bigger one on bars for better results but have done fine so far without. Good company, will repair and send back at a reasonable price if you have issues.
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...:thumbsup:
    high pivot witchcraft
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    I have 2 Lumina 900 Boosts I bought for myself and my daughter, in case we bumped up against darkness this season. First season we didn't get caught out there. I use one (alternating between the 2) for winter commuting now. BRIGHT WHITE light. But again, it's only commuting on a dark bike path. Not ripping down some tightly treed singletrack.
    Great build quality and inexpensive.
    After going through all the usual all-in-one economy lights, I definitely like the NiteRiders the best. Some of the others, which will go unnamed, cannot be fastened to my 35 mm mountain bike bars, and take a huge amount of force to slide them off the bar mount. The NiteRiders have been great so far, and their battery longevity has been stellar (despite the shitty reviews that are continually posted/linked at this site).
    That said, if I can grow a pair so I can get out in the mountains at night and not worry about the cougars, bears, zombies and spirits, I will spend some more serious cash and buy a nicer set up. Something a little more in the cork sniffing category.
    Thanks to all of you for sharing your thoughts. I did get the light and tried it last night. I was pleasantly surprised. More than enough light to navigate the trails. The only negative is the fact that you only get 1 hour of light while on Boost mode, so you can't really do any long night rides. I suppose you can turn the setting to low while climbing, and switch to Boost for descending...
    I used mine with the handlebar mount. I think it would be too heavy to use with helmet mount. It may be a good idea to combine with a smaller helmet one as suggested previously on this thread...
    Jun 2013
    Quote Originally Posted by MrGT View Post
    Thanks for the suggestion. I don't do night rides on the mtb very often, so I'm thinking right now it will be 'good enough' but I'll see how I like it after a couple of rides.
    Sep 2018
    I'm wondering if there is a way to put in a better battery to extend the shelf life??? Also, do you feel the Boost 1200 gives you a wide enough beam for the handlebars?
    My guess is you would be fine using the 1000 lumen high setting for most trail situations. That alone would give you an extra 30 min.+ you still can use low on the climbs and boost if you feel the need for more light.
    Mole
    Sep 2018
    Thanks Mole, that makes sense. I'm fairly new to this whole mountain biking thing so this will be my first winter having to night ride. I live in South Florida where the local trails are relatively flat, not a whole lot of climbing! They are, however, rather narrow, curvy and lined with trees and bushes so I want to make sure I get a light that covers me without breaking the bank.
    Quote Originally Posted by jason5543 View Post
    Based on my experience yesterday, this light will work fine. If you use it on your handlebar, be aware that it is a bit more difficult while cornering at night. It may help to have an additional helmet light so you can see where you are looking, versus seeing only what the handlebar is pointing at.
    I saw this on the Niterider Lumina 1200 site.
    With the all new custom engineered collimator optics, the Lumina™ 1200 Boost projects a beam pattern that provides a generous widespread and even beam pattern of 1200 brilliant lumens!
    Wondering if any of you 1200 owners that also own older Lumina's have noticed a difference? I also saw some beam shots that looked to have a wider and smoother beam but haven't been able to find them again (sorry).
    Mole
    Oct 2018
    Anybody using those? I'm thinking about purchasing this light,but I'm not sure if they are good enough for using in the trails. I'm not planning on doing long night rides . I only intend to use them to extend rides a little beyond sunset time and to ride back home trough bike paths and fire roads. Long time ago I had the NiteRider blowtorch HID that I used for the occasional 24 race. How would you compare both? I'm sure light technology has improved a lot in the last 15 years or so... Anyway, I guess I'm trying to decide if the Lumina 1200 is good enough to use on the trails or if it is only useful for road/commute.
    You stated how you intend to use the light, however consider that you may enjoy the night rides and end up spending more times on different trails.
    This is my first season doing night rides. I have a Lumina 950 boost helmet mounted and an E-Lume 1200 on the bar. The setup is plenty of light. The 1200 bar light is very bright, however it induces shadows as it is a horizontal light for the most part. Having a complimentary light on the helmet can help reduce shadows due to the increased angle of light beam.
    Having never used lights before I feel my combination actually works well. The Lumina has a great round spot beam with a dimmer flood that further extends beyond the spot. Neither beam is 'narrow' so to speak. The Serfas seems to do a good job of lighting up the width of the trail nicely. Perhaps because it is bar mounted and more of a horizontal illumination it appears to be a wider spread than the Lumina.
    I can run the pair of lights on low for climbing. Medium for medium quick paced singletrack and I switch to full power on faster descents.
    My rides last around 2 hours to 2.5 hours and the first 30 to 45 minutes haven't required a light yet. Come next week the entire ride will probably require a light. So far the lights haven't seemed to be nearly dead by the end. I assume that with changing the power levels throughout the ride will allow me full 2.5 hours of use.
    Both of my lights take about 2.5 hours to fully charge using a 2a charger from full dead.
    My rides are typically only single track dirt. I have done 2 or 3 road bike rides on a bike path. Actually yes, 2 rides with just a helmet mounted niterider which is perfectly fine. And one ride with both lights mentioned above.
    Niterider does have a special requirement to enable boost mode, at least my 950 boost does. You must quickly double-press the button to engage Boost. Not a deal breaker but is something you should be aware of. On is low, then press for medium, press for high, then double-press for Boost. The next click drops it back down to high.
    One last thing to consider. The Lumina will interfere with my wireless CatEye bike computer when bar mounted. The Serfas can be bar mounted without interfering with the bike computer. If you happen to have a wireless computer you may wish to test for interference before your first night ride.
    Aug 2005
    Yup. Boost mode sucks the life out of it quickly. Only run the lumens you need to see well. Climb on low, and if you take a quick break, shut them off or at least turn to low. My friends have them and never use boost mode. Get an 850 micro for your helmet. They are inexpensive and will help see while you turn your head as another poster said. I feel bar and helmet are the perfect combo on the trail. I wouldn’t ride without both. Never have.
    Reputation: patski's Avatar
    Dec 2005
    Quote Originally Posted by mtnbkrmike View Post
    I have the Lumina 900 Boost taillight combo and two clips, one for my road bike and one for MTB. Mostly for the dawn/dusk hours. Works great on the road bike, pops out of the mount(I tried both mounts) on bumpy MTB trails.
    I hear ya...Big difference between cougars/bears vs zombies/spirits! I see plenty of wildlife in CT but none have fangs and claws that will rip your head off. That would def factor into my decision to ride at night if I was in your area.
    Mar 2015
    Quote Originally Posted by sturge View Post
    I actually don't think it's that bad, wildlife-wise. I have researched the issue as well as I can, and I have found no evidence that the risk of an encounter is worse at night than during the day.
    On a ride I did last night I bumped right up against darkness. I got out late and was pushing myself hard from the word go. During the ride I got more freaked out over seeing a wheelbarrow and shovels sitting the middle of nowhere than anything else. I had visions of some freaky dudes waiting to pounce on me and use the tools to dig my grave. LMFAO!
    On my way out, I saw about 3 groups of 2 coming in with lights. They all looked super stoked. I need to challenge my comfort zone on this I think.
    Only run the lumens you need to see well. .
    This.
    I've been nightriding very regularly since 1994, and have never, ever found I needed the amount of light put out by a NR 1200 on boost. Maybe if I decided to go poach some lift-accessed stuff, but for regular trail riding, I have yet to find a need for anything beyond the second power level of 550, and the 275 is fine for most stuff. Set up is single light on the helmet.
    Maybe it's because I've been doing it for so long and am very comfortable riding at night, but it seems to me that a lot of folks lighting 'requirements' are wild overkill. I guess if you're running mainly long, very high-speed downhills you'd bump up against some battery life issues, but using a little common sense management on the 1200, I'm having zero problems getting well over 4 hour burn times from mine.
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
    Dec 2005
    Quote Originally Posted by slapheadmofo View Post
    I've been nightriding very regularly since 1994, and have never, ever found I needed the amount of light put out by a NR 1200 on boost. Maybe if I decided to go poach some lift-accessed stuff, but for regular trail riding, I have yet to find a need for anything beyond the second power level of 550 .
    My "comfortable" lumen level has gone up steadily since I turned 60. Current running my NW Gloworm XS & X2 on medium.
    May 2005
    Quote Originally Posted by patski View Post
    This ^ is absolutely the truth. 20 years ago ~400 lumen was enough for the 24 hr races I did on all but the fastest downhill sections of the course. Now I usually use ~1500 between helmet and bar lights for most riding and will bump up to 3000 or so for fast DH sections.
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    Is that due to eyesight or reflex issues?
    I definitely run a bit more light than when I was younger; bitd I was actually pretty comfortable doing a fair amount of Jedi riding. Pretty rare for me to shut down the lights completely these days unless I'm somewhere fairly open and moonlit.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    Quote Originally Posted by Vancbiker View Post
    Holy crap! I'd imagine that it's not too different from riding in the day at that point. Not sure how I feel about that...too much light kind of kills the whole woods-at-night vibe for me personally.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    May 2005
    Part of those high levels, is that it is really easy and cheap now to have lots of light. Back in the olden days, those of us with only a pitiful 400 lumen NR halogen were envious of the more well-heeled that could afford dual lights. We got by, but knew more would be better.
    Also there is a weird effect with how a human sees light. It takes like 4 times the actual light for it to appear twice as bright. Maybe others with more understanding of that will chime in.
    Dec 2005
    Hey! Eyesight! The darker it gets the less I see.... try finding black gloves on the floor in my car... or gearbag... or..
    I'm as fast as always....
    Jun 2013
    I finally got a change to try this light on the trails, and I'm pleasantly surprised. I've only had a light with a dual beam and a stand-alone battery on the trails at this point.
    My ride was on a flat XC trail with plenty of tight turns, and the light did great. It has a wide beam pattern with good white light and a nice hot spot in the center. I wore it on the helmet and while it's a bit heavy, but it didn't cause me any noticeable discomfort. My ride wasn't that long, so I didn't test out the total run time. I also didn't see any noticeable step-down in light output but I only ran it in the mid and high settings, and never used Boost mode.
    What I'm not a fan of is the helmet mount from Niterider -- it feels pretty cheap and fragile. Since the 1200 is heavy, it seems that the mount may not hold the light well on faster, rougher, and technical trails. I'm definitely more a fan of the magicshine-type helmet mount vs. the Niterider mount for both holding the light firmly and the mount being able to be mounting securely on the helmet.
    Aug 2005
    Grab a micro 850 for your helmet, use 1200 on bar, 850 much lighter.
    Since the 1200 is heavy, it seems that the mount may not hold the light well on faster, rougher, and technical trails. .
    Haven't had any of those issue, even with the older lights which are heavier.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    Jun 2013
    The issue is not so much with the light, as the mount just sucks IMO. Using the tightness of a metal bolt to keep plastic parts from moving is a recipe for cracked plastic parts from my experience, unless it's designed correctly. I'd much rather have a gopro type mount or something more robust.
    I think I've got 4 or 5 years on my current mount. Hafta crank down the screw once in awhile but it's held up remarkably well. (Probably just cursed it.)
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    Lumina's seem to be a very popular and high volume seller so I decided to get the 1200 version and do a comparison with the Bontrager Ion 1300 I picked up about 3 mo. ago. Backordered from Peformance Bike, no problem. Got this email today, WTF? Anybody have any idea why they wouldn't carry this light anymore?
    Mole
    Performance Customer Service
    To:[email protected]
    Nov 8 at 5:41 PM
    Dear Richard Warsinske,
    Thank you for your recent order with Performance Bicycle. Upon fulfilling your order, we discovered that our remaining inventory of the following item(s) had been depleted and is/are no longer available.
    Item # 406391/NCL NiteRider Lumina 1200 Boost Headlight
    Regrettably these items will not be restocked and have been cancelled from your order. We would, however, like to assist you in choosing an alternate item. If you would like to please contact our customer service department at 1-800-727-2433 and please reference your order number.
    We do apologize for any inconvenience that this may have caused.
    Kind Regards,
    Performance Bicycle Customer Service
    Jun 2013
    Quote Originally Posted by MRMOLE View Post
    Mole
    Either Lumina has switched to a newer model or Performance just sucks. From past experience ordering online, I'd say it's the latter.
    I though the 1200 was the latest model. New model with more battery capacity would be a big improvement. I emailed Performance back asking if the 1200 was no longer available from Niterider or if they were no longer going to sell Niterider products and got this response.
    Nov 8 at 9:34 PM
    Dear Richard,
    Thank you for your email. We apologize for the confusion. We were notified by our merchandisers that the item was no longer going to be restocked. It should be removed from the site shortly. Please let us know if we can be of any further assistance.
    Regards,
    Brady
    Customer Service Specialist
    Mole
    Mole
    REI has them in stock...
    Guidosan
    Could you contact Niterider and see if they are still producing this light? Seems odd that the latest version light is coming off the shelf. Just wonder if they are having quality issues and are discontinuing manufacturing. REI and other stores may have them, but that could just be due to stock that hasn't been sold yet. Let us know what happens.
    As well as a million other places...
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    Jun 2013
    Niterider site has them in stock, probably Performance not carrying Niterider anymore or not carrying these types of lights.
    I've got the 2019 OLED version and it is good for what you suggest. I am in the same boat in that I only occasionally need a light for the last few minutes of a ride. I would add a helmet mounted light of the same power if I were riding more often at night, and trying ride real hard. The boost feature does make a little difference. I like how the OLED helps eliminate some of the guesswork of what the light is doing.
    I was just in my local performance shop to pick up the rest of my order but unfortunately (as expected) they were unable to provide any additional information as to why the Lumina 1200 would not be restocked. As several of you have noted these are available almost everywhere but not for the current price I would have gotten so with "Black Friday" around the corner I think I'll wait to see what kind of deal I can find.
    Mole
    I know most places have these lights but don't normally check REI's site. Thanks for mentioning them as checking their site while searching revealed a doable price for me ($75). Ordered the Lumina 1200 Boost @ 7:58 pm on the 10th and it was at my door @ noot today (12th, WOW). Time to put it on the charger so it's ready to start doing tests tonight. I plan on doing max. lux, est. max lumen from bounce test lux readings, and output vs. runtime for the top 3 modes. I also own a Bontrager Ion 1300 I will be comparing the Lumina to. Will take a few days since the runtime tests are time consuming + light requires a recharge between tests but will post results as I get them. Initial impression, REI was awesome to deal with!!!
    Mole
    First night with the 1200 I didn't get to ride with it but did do some testing last night and this morning. Was happy to get runtime curves done for both boost and high modes and redid my Ion 1300 at the same time. Hope to ride tonight an get some impressions of the beam pattern, UI, mounts and so on. The fact that the flash modes are not in the main mode program is a big plus over the Ion so point Niterider on that one. Output curves speak for themselves and definitely point Ion on this. Only indoor test left I want to do is the ned mode but that will take a good block of time but will get to it eventually. Here's what I got along with the output chart for the Cygolite Metro 1100.
    Mole
    Black: Lumina 1200 turbo mode
    Lavender: Lumina 1200 high mode
    Red: Bontrager Ion 1300 high mode
    Blue: Cygolite Metro 1100
    Click to enlarge
    Aug 2005
    Mole
    Black: Bontrager Ion 1300 high mode
    Click to enlarge
    Thanks Mole, awesome!
    But do you mean red line for the Ion 1300?
    Yes, Thanks! Edit complete.
    Mole
    Aug 2005
    Mole
    Awesome...
    Do you have access to the Giant Recon 1600?
    I’d be curious to see a similar comparison.
    Awesome...
    Didn't even know there was such a thing. Looks like a nice light though.
    Mole
    Lumina 1200 First Ride
    Good first ride with the 1200 Boost last night. Had it on the bars with the Ion 1300 I've also been testing for 30mi. of side streets, MUPs and a little trail. Was surprised how much cooler the tint of the Lumina was which ended up being good and bad. My eyes are fairly glare sensitive and in the boost mode in the trail section and on the lighter crushed granite MUP surfaces reflective glare made the high mode a better choice for visibility so that was the bad. Cooler tint proved to be an advantage in the lower modes though. Normally I prefer about 750 lumen's from my bar light for the type of ride I did but with the whiter (brighter appearing) cooler tint + excellent beam pattern the Lumina's 550 lumen med. mode worked great making longer rides possible.
    Now about that beam pattern.
    I noticed reading the spec. page on the Lumina they mentioned a new type of optic being used. Compared to my buddy's older OLED 800 lumina the 1200 has a wider beam with much smoother coverage. Perfect for the ride I did and also superior to the Ion 1300's narrower but equally smooth beam, at least for bar use.
    Only negative experience on last nights ride was the bar mount. Slide clip had a little play and the durometer of the rubber used for friction was too soft IMO. It seemed like it took 10 times as long to put the mount on (twist, twist, twist) as the similar Ion mount and still had play if you grabbed the light. I didn't notice any rattling (from the clip) or movement in the light while riding but I didn't ride any surface I would describe as rough either. I think I may just remove the rubber shim and put some friction tape on the ID surface of the mount and try that.
    Mole
    May 2005
    ......Only negative experience on last nights ride was the bar mount. Slide clip had a little play and the durometer of the rubber used for friction was too soft IMO.
    K-Edge makes a really nice GoPro adapter for the Lumina series. Would be an easy way to avoid issues with the factory mount.
    Jun 2013
    I picked up a Lumina 1000 since I liked the 1200 so much but wanted something a bit lighter for the helmet mount. The 1000 finally came in the mail, and while the weight difference isn't significant it is lighter and will feel more comfortable once put on the helmet mount. I'm still not a fan of the helmet mount, but that's a personal preference thing.
    I don't believe there is a weight difference in the 1200 / 1000. You would need to go to the Lumina micro and I think the max on that is the Micro 850. Those are definitely smaller.
    Jun 2013
    Quote Originally Posted by mb323323 View Post
    I don't have a scale but I can tell a small difference between the two, but maybe it's all in my head LOL
    Jun 2013
    Mole
    Performance announced bankrupcy today, so now it makes sense that they said the light wouldn't be in stock anymore (along with everything else).
    After my encouraging first ride the last couple of nights have been a bit of a let down . Wednesday night I got my 2nd ride in with this light but this time used it exclusively for the same 30 mi. distance but a different route (99% paved MUP). The plan was to test out the med. mode more which would be the appropriate mode for a route of that distance at the speeds I usually travel at. Initially the med. mode was working great as with the first ride, I'd kick it up to high on some of the negative grades for a little extra distance coverage but it probably would have been fine with the beam just adjusted a little higher (on the fly adjustments not an option for me with this mount system). As the ride continued though I became increasingly less comfortable with the output level and ended up doing the last few miles on the high setting so a little disapointed. Last night I had some time and charted a output vs. runtime curve which explained the problems I had the previous nights ride. Output curve in the med. mode is flatter than high/boost but still graadually dips down and starting from a low/comfortable level by the later parts of the ride it had diminished enough that I was happier running set on high. Hadn't noticed this on the first ride because lighting duties had been split with my Ion so I could compare it with the 1200 which only saw operation at higher levels of battery charge. If like me you do longer rides this is probably something you should consider if thinking about purchasing this light. So here's the output chart I did showing Med, high, and boost .
    Mole
    Boost = Green
    High = Red
    Med. = Black
    May 2005
    This ^ has been my issue with the Lumina series. The inability to sustain the high level for the majority of the runtime is deceptive advertising at best. IMO, what they really have here is a 500-600 lumen light.
    That's exactly true. Like anything else it's only as good as its weakest link which in this case is the battery. Lights with a battery that can only handle a stable 600 lumen's for 1.5 hrs. can be bumped up to 1200 lumen's at the start will pay with super short runtimes or dismal output for the last half of its total runtime. Niterider gets picked on because they seem to be one of the worst performing in the regard but truth is most all of the single cell self-contained lights suffer from the same thing just to a lesser extent. Coming from a high performance separate lighthead/multi-cell battery pack point of view this characteristic seems unacceptable but in reality there's a huge amount of these lights sold and from what I've noticed a lot of very happy owners. I do hope the manufacturers quickly move to larger capacity batteries like the one in my Bontrager Ion 1300. Until then these new Lumina's offer the same good quality, low price, excellent customer support that has made them so popular with a major improvement in beam quality (wider, smoother coverage) from previous models.
    Mole
    Lumina Beam Pattern Update
    Interesting ride with the Lumina 1200 last night (45 mi., 60% lights on). My friend George brought his older 800 OLED Lumina along and as expected the beam on my 1200 was wider and smoother but shocked how really different they appear side by side. I wouldn't call the 1200 a flood beam but that's what it looks like compared to the older model. New beam pattern is much better (IMO) if a wider view is what your looking for but it probably does cut down a little on the throw. I'm wondering if lens cover/reflector are interchangeable and/or available which would allow adjusting the beam pattern on these lights? I'm posting a link to a UK site that has side by side beam pattern shots of both the 1200 and 1100 Lumina plus lux readings on the beam pattern and a wall shot of each light (and many more lights). Unfortunately the beam shots were done at different ltimes so setup is slightly different but good enough to show the difference in beam width. Enjoy!
    Mole
    https://lights.road.cc/index-wide.php
    ***Lights are arranged by yr. so 1200 in with the 2018 models and 1100 with the 2017's***
    Bike magazine review of the 1200 Lumina.
    Mole
    https://www.bikemag.com/gear/accesso...200-boost-100/
    Niterider Sale at REI
    20% off all Lumina series lights including the new dual emitter 1800. Good discount price for their latest models.
    Mole
    https://www.rei.com/product/143486/n...ont-bike-light
    Feb 2019
    I must say, I have been impressed with my Nite Rider Lumina 1200 Boost. I have only used it in the winter (purchased Dec 2018) and have used it exclusively on the trail at night, and found it to be great on the trail as a bar light. I have also paired it with a helmet light, and found both to be perfect for my needs.
    I actually was impressed out of the battery life. I typically go for rides of about and hour to an hour and 15 mins in the winter, and I could get about 3 rides before I needed to charge it. Very impressed (I typically use it on medium setting; never on high setting or Boost). Overall, very impressed and I would recommend.
    Feb 2019
    I am NOT a fan of the provided Nite Rider handle bar mount. I don't find it secure at all, and would love to use something use.
    I have seen the K-Edge Garmin mount, but that goes below the outfront Garmin mount (and below the Garmin, correct)?
    Does anyone know of other mounting options for the Nite Rider Lumina 1200 on a bar?
    Quote Originally Posted by RiltonHuggles View Post
    K-edge Gopro adapter is only option I know of if you don't want to use a Niterider mount. I've never tried one of these but it says it's compatible with other Gopro interface mounts which gives you a pretty wide selection.
    Mole
    https://www.rei.com/product/143494/n...k-edge-adapter
    Time for Mr Mole to do a run time / output graph I think.
    Love the Lumina line for the simplicity of just throwing the light on and going. But I gotta say compared to the new Ituo XP3 I recently got, my Lumina's look dim. They're not and are great durable lights but man kinda opened my eyes so to speak as to what else is out there.
    Feb 2019
    Thanks MrMole!
    However, with this mount, you still have to use it with a outfront mount and on the bottom, correct?
    Just wondering if there is a mount that you can just use on the bar for it...
    Mole
    Thanks MrMole!
    Here's my favorite bar mount setup for self-contained lights. This setup is bulletproof + allows for horizontal adjustment of aim. Made by Vancbiker (post #55). Send him a private message for details. I think they're around $35 but worth it IMO if you want a rock solid mount especially for a heavier light.
    Mole
    Feb 2019
    Interesting!! Thanks MRMOLE. I think I might have to check out these mounts and contact Vancbiker! Looks like an interesting mount! Does he also also have helmet mount options?
    Mole
  67. #67
    Unfortunately no helmet mounts from Vancbiker.
    Mole
  1. NR Pro 1400 w/ Lumina 900 or Dual Lumina 900’s
    By NVRGVUP in forum Lights and Night Riding
    Last Post: 08-02-2018, 03:03 PM
  2. niterider lumina boost-how to?
    By TheGweed in forum Lights and Night Riding
    Last Post: 10-19-2016, 06:39 AM
  3. Replies: 4
    Last Post: 04-11-2014, 12:41 PM
  4. Niterider Lumina 650
    By jrss13 in forum Lights and Night Riding
    Last Post: 11-30-2012, 10:23 AM
  5. NiteRider Lumina 650
    By cycle alaska in forum Lights and Night Riding
    Last Post: 11-18-2012, 08:40 AM
Members who have read this thread: 76
