New Magicshine EAGLE M2 2400 lumens- Mtbr.com
Results 1 to 14 of 14
    Reputation: pabcor's Avatar
    Works with usual Magicshine batteries, with 6 leds XP-G2 and wireless control.
    lucespotentesparatubici: Foco Magicshine EAGLE M2 2400 lumens
    Looking for power lights?, see here
    Reputation: spankone's Avatar
    Looks promising. Although my eagle 600 mount doesn't fit oversized bars
    Works with same single mount.
    EAGLE M2 2400 lm (left, smaller and lighter) and EAGLE F3 3000 lm (right)
    Quote Originally Posted by pabcor View Post
    EAGLE M2 2400 lm (left) and EAGLE F3 3000 lm (right)
    The M2 looks interesting ...But...
    I'm curious as to how the modes work. The real question though; Do all the LEDs light for all modes? I read the description on the link but it really didn't explain very well. Perhaps someone who owns one has more low-down on how the modes work.
    No, pres M key to shift light modes, there are three light modes: high-low beam - high beam - low beam (3 leds XP-G2 on M2 and 2 leds XM-L2 on F3 for example)
    Press + key to increase brightness suceessively, brightness grades are 10%-25%-50%-75%-100%
    Press - key to decrease brightness successively, brightness grades are 100%-75%-50%-25%-10%
    Press any key for 0.5 second to turn off the light.
    Bottons are on light head (2 bottoms) and remote control (3 bottoms).
    Reputation: Sirius9's Avatar
    Apr 2013
    Buttons are on light head (2 buttons) and remote control (3 buttons).
    cheers
    Okay, not sure I understand ( ? )..press the M-key to access either H/L--L--H. Then you press the + or - to vary intensity. I think I understand that you can vary either the flood or spot LED's...BUT when in H/L mode can you vary intensity with the + or - or do you have to leave H/L to do that?......OR....if you vary the intensity of the two separate modes High ( the upper leds ) or Low ( the lower leds ) does the lamp memorize the previous settings if you chose the H/L setting with the M button? Any of this correct?
    Now if any of this is true I really don't see the advantage of running this type of lamp if the mode selection is so complicated. If you have to press so many buttons to change settings you might as well run two separate lamps ( one more spot , one more flood ) with a Y-adapter battery cable.
    Action LED Lights
    Reputation: Action LED Lights's Avatar
    The modes are the top led's (Spot optics), the botton LED's (flood optics), or top and bottom together. In each mode the + and - buttons increase or decrease the brightness.
    Hope that helps.
    Jim Harger
    Action LED Lights
    www.action-led-lights.com
    Yes to first question. leds H are clear (far spot). lens L are market (wide spot).
    Last question yes (memorize the previous settings (mode and intensity)) if the battery was not disconnected.
    Thanks Action Led Lights
    Quote Originally Posted by Action LED Lights View Post
    Hope that helps.
    Thanks Jim. Okay, that makes sense. If you want to adjust output of both and High and low Led's you can leave in H/L setting and just change the + or - to change intensity. That can work.
    Nov 2012
    Looks pretty good to me. I like the fact that it uses the standard round Magicshine connector. It probably draws less current than the F3, which I believe uses an 8 cell battery.
    Action LED Lights
    Quote Originally Posted by varider View Post
    It draws less current than the F3 but of course has less output. Still, at 2400 lumens it would drain a 4400mAh pack pretty quick. (probably about 1 hour)
    Jim Harger
    Action LED Lights
    Oficial runtime 2 hours at 100% with 6200mAh battery included (4 elem. Panasonic).
  1. Magicshine Eagle F3
    By ghostchili in forum Lights and Night Riding
    Last Post: 12-17-2014, 05:57 PM
  2. Color Cables for 2400 Lumens CREE XM-L T6 LED +2x XPE R2 LED Bike
    By bichito in forum Lights DIY - Do It Yourself
    Last Post: 07-16-2012, 10:29 AM
  3. Color Cables for 2400 Lumens CREE XM-L T6 LED +2x XPE R2 LED Bike
    By bichito in forum Lights and Night Riding
    Last Post: 07-15-2012, 02:47 PM
  4. Led lumens, output lumens, hot lumens, cold lumens :)
    By Dominik.M in forum Lights and Night Riding
    Last Post: 08-15-2011, 03:48 PM
  5. New "Magicshine" 2.0 1200 lumens/8.4v 6400mAh
    By Sebastian78 in forum Lights and Night Riding
    Last Post: 01-12-2011, 08:01 PM
