need powerful light for Kask Rex helmet- Mtbr.com
Results 1 to 5 of 5
    Aug 2015
    Can anyone recommend a powerful headlight for my Kask Rex helmet. Did my first night ride with only a bar mounted light and had a blast! I did however notice the advantages of having a light at the height of top of your helmet. My budget is up to $125. Thanks!
    Quote Originally Posted by 288GTO View Post
    The Kask Rex helmets I saw on-line on Amazon show that the helmet has some kind of plate on the top that hides a port for mounting a "camera or light", according to the spec. I have no idea what that means though. They don't show it mounted with a light or camera. However, if the helmet is fitted with a built in Gopro mount than all you need to do if find a lamp that is Gopro mountable and you're set.
    There are lots of lamps suitable for helmet use. While not all include a Gopro mount, many can be converted to a Gopro mount by using an adapter. One of the regular posters on this forum makes and sells Gopro adapters and already has many for some of the most popular lights. Look him up, he goes by the name, "Vancbiker".
    Reputation: Hunyak's Avatar
    Dec 2014
    Kask Rex will accept a GoPro mount.
    Jan 2011
    I picked up the same helmet just the other day. There's a built in gopro buckle on the top with a cover that you have to slide off. I use a yinding light with narrow optics and one of the cheap gearbest nightfighter gopro mounts on it. Strapped one of the KD panasonic 2x18650 battery packs on the back, the extra weight isn't really that noticeable- helmet carried the weight great.
    I run the yinding on medium most of the time and that seems bright enough for my trails, and gives plenty of runtime with the 2 cell battery pack. It can run hot on high, so you may want the gopro mount from 'vancbiker' that Cat mentioned above for the extra heat sinking. The tint matches the cheap BT40s clone nicely and makes for a good budget setup!
    May 2005
    @Cat.. Thanks!
    Since the GoPro fitting on that helmet is right on the crown, it is a good candidate for the LoPro version of my adapter. Shown in this thread at post #229.
    GoPro light adapter with fins for additional heatsinking - Page 3- Mtbr.com
    For the Yinding and SSX2 and Ituo XP2 and XP3 it works very well to mount the light lower on the helmet making it less likely to catch a branch.
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
  1. Anyone tried out the new Kask Rex Helmet ?
    By NorthSideOf50 in forum Apparel and Protection
    Last Post: 03-18-2016, 12:35 PM
  2. Replies: 41
    Last Post: 05-24-2014, 12:13 PM
  3. Anyone have experience with KHS T-Rex?
    By bikeisgood in forum Families and Riding with Kids
    Last Post: 04-06-2012, 09:03 AM
  4. I want LIGHT and powerful for my helmet
    By motard5 in forum Lights and Night Riding
    Last Post: 11-18-2011, 10:47 AM
  5. Rex Patrick memorial ride
    By marinjp in forum Colorado - Front Range
    Last Post: 03-31-2011, 09:41 PM
