My first build :yikes: and battery's:o- Mtbr.com
Results 1 to 3 of 3
    Hello, First of all A massive thankyou to all you fellow bikers, for posting ALL the helpfull info on self build lights, it is brilliant.
    My Question is this: I am about to build a single Led Cree MC-E Star, (my first project...) I want to have it helmet Mounted. I am planning to use a 700Mah powerpuck to drive it. First of all am I right in thinking that the LED will take the power,I know it will need some serious heat sinking.... also what is the smallest Battery you would recommend I am looking for a minimum burn time of approx 4hrs ish give or take for draw from the driver????
    Is there A way of calculating a Battery's life ? If this works I am planning to do a second build for my bars, and the battery thing eludes me...
    If this is successfull I will post Pics and Project online I think This is fantastic...
    Reputation: sdnative's Avatar
    FYI, Probably want to put this over in the DIY bike light area.
    MCE, good cooling ...Hmmmm
    I might know of a really REALLY good design you might be able to use as a base for your project.
    Hmm, where did that link go?
    Quote Originally Posted by sdnative
    Ha ha thankyou, I will Take a look, And move To the Diy Area.
